Home » Eclipse Projects » Mylyn » Hello world for Mylyn monitor
Hello world for Mylyn monitor [message #50420] Wed, 18 June 2008 10:42 Go to next message
Hi all,
I'm trying to get familiar with the Mylyn monitor. Our marketing
department would like to know which parts of our Eclipse RCP application
have been used most frequently. So I thought the Mylyn monitor could do
this job.
I had some difficulties to find any example on how to create a simple
Hello world example where I can track the usage of some buttons or text
fields and afterwards use the Mylyn monitor reporting tool to show the
results of the usage.
I would be grateful if someone could post a link or a simple example on
how to use the monitor.
Regars,
Eugen
Re: Hello world for Mylyn monitor [message #50448 is a reply to message #50420] Wed, 18 June 2008 12:50 Go to previous messageGo to next message
Originally posted by: zx.code9.com
Have you looked at the Eclipse Usage Data Collector that ships with
Ganymede packages now?
http://www.eclipse.org/epp/usagedata/
~ Chris
Re: Hello world for Mylyn monitor [message #50476 is a reply to message #50448] Wed, 18 June 2008 14:26 Go to previous messageGo to next message
> Cheers,
> ~ Chris
Hi Chris,
I had indeed a look at UDC and it looked really interesting but as there
was no "developer guide" on how to use this tool for own RCP applications
I thought I'll give Mylyn monitor a try. But as I already described I
didn't find some examples either.
If you are able to provide an example on how to use UDC in own RCP
applications and how to report the usage results I would be really
grateful for your help!
Eugen
Re: Hello world for Mylyn monitor [message #50504 is a reply to message #50476] Wed, 18 June 2008 15:08 Go to previous message
> applications I thought I'll give Mylyn monitor a try. But as I already
> described I didn't find some examples either.
The best you can get right now is probably the code:
http://www.eclipse.org/epp/usagedata/faq.php
There is a Team Project Set file which will give you the code.
You can try to ask the question on the EPP newsgroups where the UDC
project is hosted. I'm sure the EPP guys along with Wayne Beaton can
help you with your needs.
Good luck.
~ Chris
Re: Hello world for Mylyn monitor [message #590199 is a reply to message #50420] Wed, 18 June 2008 12:50 Go to previous message
~ Chris
Re: Hello world for Mylyn monitor [message #590205 is a reply to message #50448] Wed, 18 June 2008 14:26 Go to previous message
> Cheers,
> ~ Chris
Hi Chris,
Eugen
Re: Hello world for Mylyn monitor [message #590214 is a reply to message #50476] Wed, 18 June 2008 15:08 Go to previous message
Good luck.
~ Chris
Previous Topic:Migrating 'Task Repository' username/password
Next Topic:'Move To' copies instead of moving
Current Time: Thu Nov 06 19:55:34 EST 2025
Powered by FUDForum. Page generated in 0.05279 seconds
