Home » Eclipse Projects » Plugin Development Environment (PDE) » Drag and Drop between 2 opened editors
Drag and Drop between 2 opened editors [message #41465] Thu, 22 January 2009 02:37 Go to next message
My application writing needs are to enable drag & drop between 2 opened editors.
While there is the possibility to open both editors side by side, it's not a well known feature, and sometimes not desirable.
What I would like is enable the user to work on several open editors, and, from time to time, initiate a drag operation from editor A, hovering the mouse over the tab showing the label of editor B,
which will then be opened to allow the drop operation to be done on editor B.
I don't know :
- if it is feasible at all ?
- if yes, where to plug things/start with ?
IS THERE a correct way to do this in a plug-in, so that I don't violate some "good behaving rules" ?
Thanks in advance if you can answer to my questions,
Re: Drag and Drop between 2 opened editors [message #41478 is a reply to message #41465] Thu, 22 January 2009 06:30 Go to previous messageGo to next message
Hi Laurent,
This request for enhancement is already opened in the Eclipse bugzilla,
see https://bugs.eclipse.org/bugs/show_bug.cgi?id=37595 . You may want
to 'ping' the Platform UI guys to know what is the current status of
this bug (it doesn't seem to be targeted for the 3.5 release yet...),
and CC yourself to the bug.
BTW, note that such a question should have been asked on the
eclipse.platform.rcp newsgroup, since it's related to how the editors
should work :)
Ben
Laurent Petit a écrit :
> Hello,
> editors.
> hovering the mouse over the tab showing the label of editor B, which
> I don't know :
Re: Drag and Drop between 2 opened editors [message #41510 is a reply to message #41478] Thu, 22 January 2009 07:35 Go to previous message
Benjamin CABE wrote:
> Hi Laurent,
OK, I'll do that, thank you for the information!
> should work :)
Ah, ok.
Thansk,
Laurent
> Cheers,
> Ben
>> Hello,
>> opened editors.
>> I don't know :
Re: Drag and Drop between 2 opened editors [message #590114 is a reply to message #41465] Thu, 22 January 2009 06:30 Go to previous message
Originally posted by: benjamin.cabe.anyware-tech.com
Hi Laurent,
should work :)
Ben
> Hello,
> editors.
> I don't know :
Re: Drag and Drop between 2 opened editors [message #590120 is a reply to message #41478] Thu, 22 January 2009 07:35 Go to previous message
> Hi Laurent,
> should work :)
Ah, ok.
Thansk,
Laurent
> Cheers,
> Ben
>> Hello,
>> opened editors.
>> I don't know :
Previous Topic:Drag and Drop between 2 opened editors
Next Topic:Where can I find the exported jars ?
Current Time: Fri Jul 25 22:45:41 EDT 2025
Powered by FUDForum. Page generated in 0.25575 seconds
