Home » Modeling » Modeling (top-level project) » plugin for reverse engineering
Re: plugin for reverse engineering [message #379985 is a reply to message #379674] |
Fri, 23 March 2007 12:50   |
Hi back!
Since there's been some outside interest, I've decided to make a plugin
out of the jar-to-UML code:
http://ssel.vub.ac.be/ssel/research:mdd:jar2uml
Hopefully it can be useful for you!
Dennis
Ed Merks schreef:
> Dennis,
> Cool. Thanks for sharing that!
> Dennis Wagelaar wrote:
>> Hi Sandrine, Ed,
>> I've written a small command-line tool that takes a jar file as input
>> and generates a UML file. I use it to generate UML models of the
>> different Java API versions.
>> It's still in a brainstorm stage, but you can take a look at the code
>> to get an example. The code (and some generated models) are available
>> here:
>> http://ssel.vub.ac.be/viewcvs/viewcvs.py/PlatformKit/platfor mkit-java/
>> Regards,
>> Dennis
>> Ed Merks schreef:
>>> Sandrine,
>>> Not that I know of, no.
>>> sandrine wrote:
>>>> hi,
>>>> Is there any plugin for reverse engineering from .class ?
>>>> thanks.
Re: plugin for reverse engineering [message #379987 is a reply to message #379985] |
Fri, 23 March 2007 13:31  |
Dennis,
I saw that on the other newsgroups and was hoping to get a chance to
play with it some time. Since there is an Ecore importer for UML, this
indirectly provides a way to build an Ecore model...
> Hi back!
> plugin out of the jar-to-UML code:
> Regards,
> Dennis
> Ed Merks schreef:
>> Dennis,
>>> Hi Sandrine, Ed,
>>> input and generates a UML file. I use it to generate UML models of
>>> the different Java API versions.
>>> code to get an example. The code (and some generated models) are
>>> available here:
>>> Regards,
>>> Dennis
>>> Ed Merks schreef:
>>>> Sandrine,
>>>> sandrine wrote:
>>>>> hi,
>>>>> thanks.
Re: plugin for reverse engineering [message #586791 is a reply to message #379671] |
Thu, 01 March 2007 13:02  |
Hi Sandrine, Ed,
It's still in a brainstorm stage, but you can take a look at the code to
get an example. The code (and some generated models) are available here:
Dennis
Ed Merks schreef:
> Sandrine,
> sandrine wrote:
>> hi,
>> thanks.
Re: plugin for reverse engineering [message #586808 is a reply to message #379672] |
Thu, 01 March 2007 13:50  |
Dennis,
> Hi Sandrine, Ed,
> here:
> Regards,
> Dennis
> Ed Merks schreef:
>> Sandrine,
>> sandrine wrote:
>>> hi,
>>> thanks.
Re: plugin for reverse engineering [message #590054 is a reply to message #379674] |
Hi back!
Dennis
Ed Merks schreef:
> Dennis,
>> Hi Sandrine, Ed,
>> here:
>> Regards,
>> Dennis
>> Ed Merks schreef:
>>> Sandrine,
>>> sandrine wrote:
>>>> hi,
>>>> thanks.
Re: plugin for reverse engineering [message #590064 is a reply to message #379985] |
Dennis,
> Hi back!
> Regards,
> Dennis
> Ed Merks schreef:
>> Dennis,
>>> Hi Sandrine, Ed,
>>> available here:
>>> Regards,
>>> Dennis
>>> Ed Merks schreef:
>>>> Sandrine,
>>>> sandrine wrote:
>>>>> hi,
>>>>> thanks.
Current Time: Wed Jul 23 00:48:55 EDT 2025
Powered by FUDForum. Page generated in 0.11143 seconds
