Home » Archived » EPF » Problems encountered using the new EPF Wiki 1.5 RC1
Problems encountered using the new EPF Wiki 1.5 RC1 [message #590050] Wed, 06 August 2008 04:08
I recently installed the EPF Wiki in C:\InstantRails2.0 (closely following
the EPF wiki install guide). I spent yesterday experimenting with it. When
I ran InstantRails.exe the first time, it asked if I would reset the
configuration files. I only worked when I answered "OK".
Without a user guide at hand I stumbled into some roadblocks.
The \templates 20080828\ project site seemed to work just fine on the
surface, but ...
From the front page of http://myepfwiki/
I choose "Create new page in ..." - "Templates"
I get the error: No such file or directory -
C:/INSTAN~1.0/rails_apps/EPFWiki/public/bp/templates_2008082 8/new/guidances/termdefinitions/term_definition_template_A11 83691.html
I don't have a C:/INSTAN~1.0 directory :(
Seem like some of the configuration files have not been reset!?
I then tried to publish a site from EPF 1.5M3 and import it into EPF Wiki.
The published site is a directory of static web files. I then zip it and
try to import. I get one folder level too much. OK, I must zip, not the
containing folder but the files inside directly.
Another options seems to be to copy the site folder directly into:
C:\InstantRails2.0\rails_apps\[EPFWiki]\public\wikis
Initially the Wiki tells me there are 0 pages in this newly created site.
I look at the \templates 20080828\ project site and notice that it has a
folder "new" containing all the content. Magically, when I rename a folder
such as \base_concepts\ (containing OpenUP base concept definitions) to
\new\, suddenly I am told the Wiki has found 560 pages. As I browse
through the list of pages, I can see that the Wiki has only found the
pages within the \new\ folder.
I then try to create a new page:
So it seems, that my new Wiki has the same wrong configuration as the
default \templates ...\ project.
What to do!?
I then do a search for files with text matching "INSTAN~1.0" inside
C:\InstantRails2.0
I find a log file, unzip_upload.log:
Archive: C:/INSTAN~1.0/rails_apps/EPFWiki/public/bp/Publish2..zip
creating:
C:/INSTAN~1.0/rails_apps/EPFWiki/public/bp/Publish2./Publish 2/
inflating:
C:/INSTAN~1.0/rails_apps/EPFWiki/public/bp/Publish2./Publish 2/about.htm
I then make an educated guess that C:/INSTAN~1.0 must refer to
C:\InstantRails1.0 as the file structure referenced mathced that of
C:\InstantRails2.0
I wonder if I could make the Wiki work simply by renaming
C:\InstantRails2.0 to something where C:/INSTAN~1.0/rails_apps becomes a
valid filelocation?
What have I been doing wrong in my installation process? Any ideas out
there?
Kristian
Previous Topic:Use EPF to Document Eclipse Processes
Next Topic:Questions for outputs
Current Time: Sat Jun 07 16:27:45 EDT 2025
Powered by FUDForum. Page generated in 0.03445 seconds
