Share Model Editing example [message #589677] |
Thu, 17 November 2005 08:49  |
I am not able to use Share model editing example.
This is how I tried:
I am running a local server by using startserver.cmd.
First user:
I created a simple project and connected to server by ECF menu for that
project.
I created Data Graph model and opened an ecore file.
Second user:
I ran another instance of eclipse by using another workspace.
Created a new simple project, connected to same local server by using ECF
menu.
Created data graph model and linked (Advance -> link to file in file system)
it with the same file in first workspace and opened same ecore file.
Now, any change I make & save, is not reflected automatically to another
user.
I am not sure what I am doing wrong, any thoughts?
Re: Share Model Editing example [message #590768 is a reply to message #590747] |
Sun, 20 November 2005 09:43  |
Thanks for info.
Bug 117214 has been added to the database.
Parvez
Scott Lewis wrote:
> Hi Folks,
> I think there is a newly introduced bug in the graphshare example
> application. I will take a look at it tonight (Fri) and this weekend. I
> don't suspect it will be difficult to fix once I reaquaint with that code.
> We (ECF) are anticipating doing an 0.5.2 build within the next couple of
> days (certainly before next Thurs). I will try to make sure the fix for
> this issue gets into 0.5.2. I would appreciate it, though, if someone
> (Parvez?) could submit this as a bug report via bugs.eclipse.org...to
> the ECF bug area?
> Thanks!
> Scott
> Parvez Chauhan wrote:
>> I do have EMF already installed.
>> Isaac Xu wrote:
>>> I know It must be installed EMF for share Graph, hope useful.
>>>> First user:
>>>> that project.
>>>> Second user:
>>>> using ECF menu.
>>>> system) it with the same file in first workspace and opened same
>>>> ecore file.
>>>> another user.
FUDForum. Page generated in 0.05404 seconds
