Home » Archived » Eclipse Communications Framework (ECF) » Running Collaboration Server Windows
Running Collaboration Server Windows [message #589284] Tue, 11 October 2005 06:57 Go to next message
I try to install an ecf server on Windows 2K.
I use Startserver.cmd, there is an error :
cd %PN%
jar xvf org.eclipse.ecf.provider_0.4.0.jar =====>> What's this
command.
cd %~dp0
Christian
Re: Running Collaboration Server Windows [message #589289 is a reply to message #589284] Tue, 11 October 2005 11:53 Go to previous messageGo to next message
Hi Christian,
> cd %PN%
> command.
> cd %~dp0
Due to a build strangeness (which is happily going away shortly), the
org.eclipse.ecf.provider plugin had to be built as a jar (rather than in
a directory, etc). So, since not running in Eclipse, this unjars the
org.eclipse.ecf.provider jar so that the server classpath can include
the provider.jar (which is inside the org.eclipse.ecf.provider_0.4.0.jar.
Clumsy, I know, but it's just a temporary work around. It won't be in
the next release of ECF (0.5.0).
Scott
Re: Running Collaboration Server Windows [message #589296 is a reply to message #589289] Tue, 11 October 2005 12:02 Go to previous messageGo to next message
Hi Christian,
I forgot to also say...if you unjar this jar manually (into a directory
org.eclipse.ecf.provider_0.4.0 in the plugins directory) then you can
just comment this line out (jar xvf...) and start the server without it.
Scott
Scott Lewis wrote:
> Hi Christian,
>> cd %PN%
>> this command.
>> cd %~dp0
> Scott
Re: Running Collaboration Server Windows [message #589304 is a reply to message #589296] Wed, 12 October 2005 06:44 Go to previous message
Hi Scott,
Thank you very much.
After I send my message, I unjar this manually. The server start and that
goes.
Christian
"Scott Lewis" <slewis@composent.com> a
Previous Topic:Anonymous CVS Access not working
Next Topic:Stable build 0.5.0
Current Time: Mon Jul 28 03:35:09 EDT 2025
Powered by FUDForum. Page generated in 0.04785 seconds
