Home » Archived » M2M (model-to-model transformation) » [ATL] Java code
[ATL] Java code [message #58852] Tue, 21 August 2007 04:54 Go to next message
Originally posted by: eric.maes.thalesgroup.com
Is it possible to use Java code in ATL transformations ?
I need to call a specific Java method that computes a field value for an
output model from a value of an input model.
If it is possible, where does the classpath is specified ?
Re: [ATL] Java code [message #58901 is a reply to message #58852] Tue, 21 August 2007 09:21 Go to previous messageGo to next message
--------------080500070301050908010904
It is not possible to call external Java code during an ATL transformation.
William Piers
Eric MAES a
Re: [ATL] Java code [message #58926 is a reply to message #58901] Tue, 21 August 2007 09:45 Go to previous messageGo to next message
--------------000009010208090908030601
Sorry, I was wrong. There is a way to implement additional methods.
A previous post was explaining that, see
http://dev.eclipse.org/newslists/news.eclipse.modeling.m2m/m sg00519.html
William Piers a
Re: [ATL] Java code [message #59463 is a reply to message #58926] Fri, 24 August 2007 12:19 Go to previous message
I hadn't seen this reference.
Thanks for your answer.
Previous Topic:[ATL] Metamodel reference
Next Topic:[ATL] Empty generated model
Current Time: Sat Nov 08 07:16:04 EST 2025
Powered by FUDForum. Page generated in 0.04426 seconds
