DDL generation and dbdefinition xmi [message #434022] |
Sun, 17 September 2006 13:06  |
The issue is related to the defaultPrecision, defaultScale, defaultLength
attributes of the predefinedDataTypeDefinitions element in the
DatabaseVendorDefinition XMI file.
It seems that none of these default values is considered during DDL
generation. All I could see during debugging is that the DDL generation
always uses the default values from ColumnImpl.
This is quite a major issue: for example there is no way to map BigDecimal
to something like NUMERIC(12,2) (it will always come as NUMERIC(0,0)).
Am I missing something? Any comments, ideas will be extremely appreciated.
Best Regards,
Tzanko
Re: DDL generation and dbdefinition xmi [message #434029 is a reply to message #434022] |
Tue, 19 September 2006 12:36  |
This appears to be a limitation of our DDL Generation functionality. This
code was contributed to the project and is no longer being maintained. As
a result of this, and given that all of the JPA runtime implementations
already implement DDL generation from Entities, we have decided to remove
our DDL generation support and instead integrate with the JPA runtime
support from the Dali UI.
Due to this change in direction, we don't plan on enhancing the current
DDL generation code now or in the future unless someone is able to commit
to maintaining this functionality.
You may want to try using the DDL generation available in the JPA runtimes
to get around this issue, or use a DB tool to modify your column
definitions as appropriate after table generation from Dali.
Neil
Tzanko Stefanov wrote:
> Best Regards,
> Tzanko
Re: DDL generation and dbdefinition xmi [message #589230 is a reply to message #434022] |
Neil
> Best Regards,
> Tzanko
FUDForum. Page generated in 0.36898 seconds
