Home » Modeling » Epsilon » ETL problem
ETL problem [message #589163] Tue, 11 May 2010 14:11 Go to next message
Hello.
I'm trying do a transformation using ETL.
I have this model, created by a other previous transformation:
<?xml version="1.0" encoding="ASCII"?>
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:pimnat="afpl.nat.pim">
<pimnat:Policy id="fw2">
<rule>
<filter interface="eth1" direction="out" action="deny">
<matches ipsrc="10.1.1.0/24" ipdst="10.10.10.2" protocol="*" prtsrc="*" prtdst="*"/>
</filter>
</rule>
<rule>
<filter interface="eth2" direction="in" action="deny">
<matches ipsrc="10.1.1.0/24" ipdst="10.1.1.3" protocol="tcp" prtsrc="*" prtdst="23"/>
</filter>
</rule>
</pimnat:Policy>
</xmi:XMI>
And two rules for try. This is the first one:
rule trasnform_policie
transform f: Source!Policy
to p : Target!Policy{
"policy".println();
and it's working ok.
And the second one:
rule trasnform_policie2
transform f: Source!Rule
to p : Target!Filter_Rule{
f.println();
"hello".println();
But when I executed this rule, nothing hapen
The problem is that ETL is not taking <rule> like Source!Rule, but I don't know why. I have checked the metamodel and I think every is ok.
Any idea?
Thank you very very much for your help!!!
Re: ETL problem [message #589167 is a reply to message #589163] Tue, 11 May 2010 14:19 Go to previous messageGo to next message
Hi Jose Miguel,
Is perhaps Rule an abstract class? If so, you should add a @greedy
annotation to your second rule:
@greedy
f.println();
"hello".println();
If this is not the case, could you please send me your metamodels, ETL
and a sample model so that I can have a look at this?
Dimitris
Jose Miguel wrote:
> Hello.
> <rule>
> </filter>
> </rule>
> <rule>
> </filter>
> </rule>
> </pimnat:Policy>
> </xmi:XMI>
> "policy".println();
> And the second one:
> f.println();
> "hello".println();
> Any idea?
Re: ETL problem [message #659250 is a reply to message #589167] Fri, 11 March 2011 11:49 Go to previous message
Hi Dimitris,
I've got the same problem with some of my rules. everything looks fine in my .ecore model.
I have tried the @greedy, but it doesn't work either.
Can you please help me ?
Asieh
Previous Topic:[EVL] Validation on EMF editor
Next Topic:Epsilon, Eugenia with GMF
Current Time: Sat Jul 26 03:56:26 EDT 2025
Powered by FUDForum. Page generated in 0.21427 seconds
