Home » Eclipse Projects » Dali » errors using Dali 0.5
errors using Dali 0.5 [message #434007] Sat, 26 August 2006 21:11 Go to next message
I am trying to use Dali 0.5 within eclipse 3.2 with WTP 1.5 as required.
My target platform is JavaSE 5, in fact I want to create an eclipse RCP
app that accesses a derby database via toplink essentials.
I have a persistence.xml which lists the required properties. I also
have an orm.xml file which I currently only use to declare a sequence
generator. I am seeing the following problems:
1. I use the following sequence generator annotation on an entity class:
@Id
@GeneratedValue(strategy=GenerationType.SEQUENCE, generator="JPAX_SEQ")
the generator is declared in orm.xml as
<sequence-generator name="JPAX_SEQ"/>
now, in the source editor, I always see an error marker on the @Id
annotation, saying "Generator name 'null' not defined".
2. I see intermittent NullPointerExceptions, and recently a
FileNotFoundException on an entity class file from the JavaBuilder (I
lost the stacktrace, will post when I get another one)
can anybody comment?
thanks,
Christian
Re: errors using Dali 0.5 [message #434010 is a reply to message #434007] Sun, 27 August 2006 09:17 Go to previous messageGo to next message
as a follow up, heres one stack trace. There was also an error when
requesting code completion inside an annotation
at
org.eclipse.dali.orm.adapters.java.JavaPersistentTypeModelAd apter.processSourceTypeChildChanged(JavaPersistentTypeModelA dapter.java:353)
at
org.eclipse.dali.orm.adapters.java.JavaPersistentTypeModelAd apter.sourceTypeChanged(JavaPersistentTypeModelAdapter.java: 302)
at
org.eclipse.dali.orm.adapters.java.JavaPersistentTypeModelAd apter.synchWithJavaDelta(JavaPersistentTypeModelAdapter.java :284)
at
org.eclipse.dali.orm.adapters.java.JavaPersistenceFileModelA dapter.synchWithJavaDelta(JavaPersistenceFileModelAdapter.ja va:129)
at
org.eclipse.dali.orm.adapters.java.JavaPersistenceFileModelA dapter.handleEvent(JavaPersistenceFileModelAdapter.java:76)
at
org.eclipse.dali.orm.impl.PersistenceFileImpl.handleEvent(Pe rsistenceFileImpl.java:199)
at
org.eclipse.dali.orm.impl.PersistenceModelManager$ElementCha ngeProcessor.elementChanged(PersistenceModelManager.java:403 )
Re: errors using Dali 0.5 [message #434014 is a reply to message #434007] Mon, 28 August 2006 16:40 Go to previous messageGo to next message
Hi Christian,
For diagnostic purposes, can you check your Plugin Details for the full
version string of the "Dali Core" plugin. If it is dated pre-06/27 there
is an update available that should solve the first problem you are having,
and possibly some of the exceptions you have been seeing as well.
We don't actually support the orm.xml in 0.5, but we tried to prevent as
many false problem messages as possible.
Let me know what you find,
Neil
Christian Sell wrote:
> Hello,
> @Id
> thanks,
> Christian
Re: errors using Dali 0.5 [message #434017 is a reply to message #434014] Mon, 28 August 2006 20:56 Go to previous messageGo to next message
Hello Neil,
what exactly do you mean by "full version string", and how am I supposed
to find it? When I go to Help->About->Plugin Details, I get a list of
plugins, but nothing that looks like the figures you mention
thanks
christian
Re: errors using Dali 0.5 [message #434018 is a reply to message #434017] Tue, 29 August 2006 11:44 Go to previous messageGo to next message
In the Plug-in Details, there should be a list of the installed Dali
plugins, each with a Version string in the format of [0.5.0v+date].
Another thing you could check is the zip from which you installed the
plugins or the plugins themselves, which shoud be dated. We only appended
the date to the version string for the last couple of milestones, so if
the Dali plugins don't have dates on the plugin zips or in the Plug-in
Details, this would indicate that they are old.
To get the final 0.5 release, uninstall your current dali plugins from the
plugins folder and visit the WTP Update Site or
www.eclipse.org/dali/downloads.html.
Neil
> Hello Neil,
> thanks
> christian
Re: errors using Dali 0.5 [message #434020 is a reply to message #434018] Tue, 29 August 2006 13:08 Go to previous message
strange, I wonder where I got the plugins with the plain 0.5 from. They
looked so official..
I have now installed R-0.5-200606282232
Christian
> appended the date to the version string for the last couple of
> milestones, so if the Dali plugins don't have dates on the plugin zips
> or in the Plug-in Details, this would indicate that they are old.
> the plugins folder and visit the WTP Update Site or
> Neil
>> Hello Neil,
>> thanks
>> christian
Re: errors using Dali 0.5 [message #589086 is a reply to message #434007] Sun, 27 August 2006 09:17 Go to previous message
at
at
at
at
at
at
at
Re: errors using Dali 0.5 [message #589111 is a reply to message #434007] Mon, 28 August 2006 16:40 Go to previous message
Hi Christian,
Neil
> Hello,
> @Id
> thanks,
> Christian
Re: errors using Dali 0.5 [message #589122 is a reply to message #434014] Mon, 28 August 2006 20:56 Go to previous message
Hello Neil,
thanks
christian
Re: errors using Dali 0.5 [message #589132 is a reply to message #434017] Tue, 29 August 2006 11:44 Go to previous message
Neil
> Hello Neil,
> thanks
> christian
Re: errors using Dali 0.5 [message #589143 is a reply to message #434018] Tue, 29 August 2006 13:08 Go to previous message
Christian
> Neil
>> Hello Neil,
>> thanks
>> christian
Previous Topic:Dali/WTP/DTP integration roadmap.
Next Topic:Dali EJB ORM JavaPolis talk
Current Time: Sun Jul 20 22:57:34 EDT 2025
Powered by FUDForum. Page generated in 0.52474 seconds
