| java.lang.NoClassDefFoundError: javax/resource/ResourceException [message #37986] |
Thu, 20 May 2004 00:44  |
Originally posted by: shorty7uk.yahoo.co.uk
I am using VE to create a simple WebSphere MQ application.
When I run the program as a Java Application within VE, I am getting this
error:
It appears to be on this statement within the code.
qm = new MQQueueManager(tabProducer.getQueueMgr());
If I run the application outside of VE from a command prompt - the
application works fine.
I assume this is a simple classpath problem within VE but so far I haven't
been able to resolve this and would appreciate any pointers as to what I
may have missed within VE.
| Re: java.lang.NoClassDefFoundError: javax/resource/ResourceException [message #38244 is a reply to message #38147] |
Thu, 20 May 2004 11:17  |
Originally posted by: shorty7.yahoo.co.uk
Jeff,
I found the problem. I had to include in the Eclipse build path
connector.jar from the MQ java lib. that is where javax/resource resides.
Jeff Myers wrote:
> David,
> The problem is the WebSphere MQ classes are referencing code in the
> javax.resources package which isn't included in the base J2SE JRE as far
> as I know. (It shows up in
> http://java.sun.com/j2ee/sdk_1.3/techdocs/api/ not
> http://java.sun.com/j2se/1.4.2/docs/api/ ) So even though you're trying
> to write a simple J2SE app, you're referencing code that requires J2EE.
> It's puzzling that it works correctly from the command line if the J2EE
> stuff isn't in the classpath.
> - Jeff
> David wrote:
> > Jeff,
> > I only have the one JRE installed.
> > This is not a J2EE app - so no, I don't have this library (at least not
> > knowingly), it is a simple java app invoking WebSphere MQ using the MQ
> > base classes. I import com.ibm.mq.*
> > David
> > Jeff Myers wrote:
> >>Is your Eclipse Java project set up to use the same JRE as you're
> >>invoking from the command prompt? Do you have the necessary J2EE
> >>libraries included in your Java project, the library that contains the
> >>javax.resource package?
> >>Note: Run As->Java Application is the exact same launcher as used by a
> >>normal JDT Java file. There's nothing specific to VE if you're having
> >>problems with the Java Application launcher.
> >> - Jeff
> >>>error:
> >>>Thanks
| Re: java.lang.NoClassDefFoundError: javax/resource/ResourceException [message #588910 is a reply to message #37986] |
Thu, 20 May 2004 08:46  |
- Jeff
> error:
> Thanks
| Re: java.lang.NoClassDefFoundError: javax/resource/ResourceException [message #588928 is a reply to message #38081] |
Thu, 20 May 2004 09:38  |
Jeff,
David
> - Jeff
> > error:
> > Thanks
| Re: java.lang.NoClassDefFoundError: javax/resource/ResourceException [message #588938 is a reply to message #38114] |
Thu, 20 May 2004 10:01  |
David,
- Jeff
David wrote:
> Jeff,
> David
>> - Jeff
>>>error:
>>>Thanks
| Re: java.lang.NoClassDefFoundError: javax/resource/ResourceException [message #588986 is a reply to message #38147] |
Jeff,
Jeff Myers wrote:
> David,
> - Jeff
> David wrote:
> > Jeff,
> > David
> >> - Jeff
> >>>error:
> >>>Thanks
FUDForum. Page generated in 0.05102 seconds
