Home » Eclipse Projects » DTP » Eclipse Data Tools
Eclipse Data Tools [message #39400] |
Thu, 29 November 2007 13:44  |
I have just loaded Eclipse Europa with WTP, I downloaded the all in one
zip eclipse-jee-europa-fall2-win32.zip and installed it into a new windows
XP professional 2000 with SP2. Everything went well. I then added tomcat
and actually created some projects and then added the Derby plugins. But
when it came time to create a Derby database, I tried:-
Window > Show View > Other and it's not showing the Data Tab. Right after
CVS is Debug.
I did an Eclipse -clean, I created a new workspace, I have even
re-installed it on another drive and nothing I do gets the Data view, so I
cannot create any databases.
Anybody have any idea what might be causing this ....
thx
Re: Eclipse Data Tools [message #39555 is a reply to message #39525] |
Tue, 04 December 2007 15:31   |
Originally posted by: john.graham.sybase.com
peter H Roberts wrote:
> So it appears that version 3.2 uses connectivity and not data. I have been
> able to use this, and it's fine.
> The one issue I have is that the databases I create do not seem to be
> stored all the time. If you close eclipse and then reload it, the
> databases created on the databases tag do not seem to be saved.
Peter,
In the Data Source Explorer view, you create a connection profile,
connect, see the contents, restart Eclipse, and the connection profile is
no longer present? If so, can you take a look in your eclipse\features
folder for "org.eclipse.datatools.connectivity.feature" and let me know
what version stamp is there? (It will look something like "1.0.0.20079261")
John Graham
Eclipse Data Tools Platform PMC Chair
Re: Eclipse Data Tools [message #39800 is a reply to message #39555] |
Tue, 11 December 2007 00:04  |
Originally posted by: paul.n.woods.gmail.com
John,
I was going to respond to you in a prior thread, but the problem you
describe with Peter here is exactly what is now happening to me on
3.3.1.1.
When I create the profile and connection, everything works great.
Shutdown Eclipse though, restart, and it's all gone.
The version stamp / directory you referenced is
org.eclipse.datatools.connectivity.feature_1.5.1.200709261
Eclipse Version: 3.3.1.1
Eclipse Build id: M20071023-1652
I am on Linux, using HSQLDB.
Thanks again,
Paul
> Peter,
> is no longer present? If so, can you take a look in your
> eclipse\features folder for "org.eclipse.datatools.connectivity.feature"
> and let me know what version stamp is there? (It will look something
> Regards,
> John Graham
Re: Eclipse Data Tools [message #588856 is a reply to message #39400] |
Mon, 03 December 2007 08:58  |
Re: Eclipse Data Tools [message #589202 is a reply to message #39525] |
Peter,
John Graham
Re: Eclipse Data Tools [message #589303 is a reply to message #39555] |
John,
3.3.1.1.
Thanks again,
Paul
> Peter,
> Regards,
> John Graham
Current Time: Sun Jul 20 21:50:18 EDT 2025
Powered by FUDForum. Page generated in 1.07510 seconds
