| Re: How to view multiple markers? [message #53287 is a reply to message #53237] | Mon, 06 June 2005 11:01  |  |
| Eclipse User  |  |  |  |  | Sian January wrote: > In Eclipse try 'Window' > 'Preferences' > 'Java' > 'Editor', select the
 > Hovers tab then check 'Enable annotation roll-over...'.  That may be
 > what you are looking for.
 Yes, that's exactly what I'm looking. Thanks much Sian!
 -barry
| Re: How to view multiple markers? [message #588533 is a reply to message #52536] | Fri, 03 June 2005 04:21  |  |
| Eclipse User  |  |  |  |  | Hi Barry,
 If you right click on the marker you will see one or more sub-menus
 related to the type of the marker (e.g. if it is an advice marker you
 will see 'Advised By'.)  This menu will contain all the pieces of advice
 that advise that line (or equivalent, depending on the relationship).
 Sian
 Barry Kaplan wrote:
 > When there is a gutter annotation indicating multiple markers, how does
 > one actually get to see the markers?
 > thanks
 > -barry
| Re: How to view multiple markers? [message #588562 is a reply to message #52696] | Fri, 03 June 2005 12:22  |  |
| Eclipse User  |  |  |  |  | Sian January wrote: > Hi Barry,
 Ah! At the bottom. I see now. This marker overlay is a bit messy. Often I can't tell if I have a breakpoint marker at a line because other markers are occluding it. It would be so nice if a hover tooltip would popup all the marker info.
 thanks!
 -barry
| Re: How to view multiple markers? [message #588703 is a reply to message #52829] | Mon, 06 June 2005 05:19  |  |
| Eclipse User  |  |  |  |  | Barry Kaplan wrote: > Sian January wrote:
 >> Hi Barry,
 >> advice that advise that line (or equivalent, depending on the
 >> relationship).
 > thanks!
 > -barry
 Sian
| Re: How to view multiple markers? [message #588716 is a reply to message #53237] | Mon, 06 June 2005 11:01  |  |
 -barry
FUDForum. Page generated in 0.06094 seconds
