Home » Eclipse Projects » Technology Project and PMC » quick q regarding eclipse 1.0
quick q regarding eclipse 1.0 [message #41060] Wed, 08 January 2003 12:40 Go to next message
Originally posted by: jochs.weirdtable.org
does anyone know if 1.0 will work with a 1.4 level VM? The instructions say
1.3 level not 1.3 or higher...
thanx in adv.
-J
Re: quick q regarding eclipse 1.0 [message #41312 is a reply to message #41060] Thu, 09 January 2003 11:12 Go to previous messageGo to next message
Originally posted by: jared-eclipse.mn.rr.com
Short answer - I don't know.
1.4 didn't exist when Eclipse 1.0 shipped, so it was never tested. However,
if the VM is backwards compatible with 1.3 classes (as it's supposed to
be), it should just work.
- Jared
> say 1.3 level not 1.3 or higher...
Re: quick q regarding eclipse 1.0 [message #41343 is a reply to message #41312] Thu, 09 January 2003 12:32 Go to previous message
Originally posted by: daniel_megert.oti.com
Depends on what you mean with "works". You might be able to run it but
you will not be able to code against 1.4 features (e.g. assertions)
inside Eclipse.
Dani
>- Jared
Re: quick q regarding eclipse 1.0 [message #588534 is a reply to message #41060] Thu, 09 January 2003 11:12 Go to previous message
- Jared
Re: quick q regarding eclipse 1.0 [message #588543 is a reply to message #41312] Thu, 09 January 2003 12:32 Go to previous message
inside Eclipse.
Dani
>- Jared
Previous Topic:Setting Focus on a Preference Page
Next Topic:A Tool Variable with no extension
Current Time: Sat Nov 08 00:02:56 EST 2025
Powered by FUDForum. Page generated in 0.04484 seconds
