Home » Modeling » Epsilon » Passing Parameters into ETL from Ant
Passing Parameters into ETL from Ant [message #526545] Mon, 12 April 2010 04:51 Go to next message
Originally posted by: c.k.holmes.lboro.ac.uk
I can pass model references from Ant into ETL via:
<epsilon.etl src="${EtlFile}">
<model ref="${SourceName}" as="Source"/>
<model ref="${TargetName}" as="Target"/>
</epsilon.etl>
What's the syntax required to allow me to pass in variables (constants
as far as ETL is concerned) from Ant?
e.g. I could enable/disable logging from ETL via a Boolean declared in Ant:
in Ant:
<property name="LoggingEnabled" value="true"/>
<!-- pass in property LoggingEnabled -->
</epsilon.etl>
in ETL:
rule Blah
transform sourceThing : Source!Thing
to targetThing : Target!Thing {
if (LoggingEnabled) {
'rule: Blah invoked'.println();
How do I declare 'LoggingEnabled' in Ant? How do I pass 'LoggingEnabled'
into to ETL? And how do I access 'LoggingEnabled' from within ETL?
Chris
Re: Passing Parameters into ETL from Ant [message #526640 is a reply to message #526545] Mon, 12 April 2010 09:43 Go to previous messageGo to next message
Hi Chris,
You can use <parameter/> nested elements to pass parameters to Epsilon
programs via ANT tasks (all parameters are strings so you'll have to
transform them to booleans, integers etc. using the respective
asBoolean(), asInteger() methods):
<epsilon.eol>
LoggingEnabled.asBoolean().println();
<parameter name="LoggingEnabled" value="true"/>
</epsilon.eol>
Dimitris
On 12/04/2010 11:51, Chris Holmes wrote:
> </epsilon.etl>
> in Ant:
> </epsilon.etl>
> in ETL:
> rule Blah
> Regards
> Chris
Re: Passing Parameters into ETL from Ant [message #527190 is a reply to message #526640] Wed, 14 April 2010 08:03 Go to previous message
Hi Dimitris,
Many thanks, I implemented it like this:
<epsilon.ecl src="${EclFile}" exportmatchtrace="matchTrace">
Enable or disable transformation logging messages
Provide referenced model components to ECL transformation
<model ref="${LeftModel}" as="Left"/>
<model ref="${RightModel}" as="Right"/>
</epsilon.ecl>
Thanks for your help.
Best Wishes
Chris
Dimitris Kolovos wrote:
> Hi Chris,
> <epsilon.eol>
> </epsilon.eol>
> Cheers,
> Dimitris
>> Hi,
>> </epsilon.etl>
>> Ant:
>> in Ant:
>> </epsilon.etl>
>> in ETL:
>> rule Blah
>> Regards
>> Chris
Re: Passing Parameters into ETL from Ant [message #588255 is a reply to message #526545] Mon, 12 April 2010 09:43 Go to previous message
Hi Chris,
<epsilon.eol>
</epsilon.eol>
Dimitris
> </epsilon.etl>
> in Ant:
> </epsilon.etl>
> in ETL:
> rule Blah
> Regards
> Chris
Re: Passing Parameters into ETL from Ant [message #588305 is a reply to message #526640] Wed, 14 April 2010 08:03 Go to previous message
Hi Dimitris,
</epsilon.ecl>
Best Wishes
Chris
> Hi Chris,
> <epsilon.eol>
> </epsilon.eol>
> Cheers,
> Dimitris
>> Hi,
>> </epsilon.etl>
>> Ant:
>> in Ant:
>> </epsilon.etl>
>> in ETL:
>> rule Blah
>> Regards
>> Chris
Previous Topic:Problem resolving object slots from ECL
Next Topic:[eugenia] specifying compartments in an abstract class
Current Time: Wed Jul 23 12:50:15 EDT 2025
Powered by FUDForum. Page generated in 0.33224 seconds
