Home » Modeling » Epsilon » Debugging ETL
Debugging ETL [message #587891] Mon, 29 March 2010 10:06 Go to next message
Originally posted by: c.k.holmes.lboro.ac.uk
I'm running an ETL transformation via Ant, passing in various parameters
such as Source and Target to tell ETL what to transform and where to put
the result. What type are these parameters? And what operations can I
run on them to confirm that they are as expected?
The parameters are pssed into ETL from Ant viz:
<epsilon.etl src="${EtlFile}">
<model ref="${SourceName}" as="Source"/>
<model ref="${TargetName}" as="Target"/>
<model ref="${ReferenceName}" as="MessageSet"/>
</epsilon.etl>
Chris
Re: Debugging ETL [message #587899 is a reply to message #587891] Mon, 29 March 2010 11:02 Go to previous message
Hi Chris,
Are you referring to parameters passed to Epsilon programs via the
<parameter> tag or to ANT variables such as ${SourceName}? Could you
please also elaborate a bit on what sort of checks you'd like to run?
Dimitris
Chris Holmes wrote:
> </epsilon.etl>
> Regards
> Chris
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Previous Topic:Syntax of iterate operation
Next Topic:Debugging ETL
Current Time: Fri Jul 25 11:12:08 EDT 2025
Powered by FUDForum. Page generated in 0.26754 seconds
