Home » Modeling » Epsilon » Syntax of iterate operation
Syntax of iterate operation [message #523789] Mon, 29 March 2010 06:54 Go to next message
Originally posted by: c.k.holmes.lboro.ac.uk
I would like to use the EOL iterate operation on a collection of objects
of type OrderedSet, however I'm having difficulty understanding the
syntax of the operation.
e.g.
var msbs : OrderedSet(Integer) := self.getFields().collect(field |
field.msb).asOrderedSet();
var maxMsb : Integer := 0;
msb := msbs.iterate(msb : Integer; x : Integer = 0 | msb.max(x));
The iterate operation fails to parse, although I think this conforms to
the format identified in the Epsilon book. This form also fails to parse:
msb := msbs.iterate(msb; x=0 | msb.max(x));
I'm obviously doing something daft, can someone correct my mistake?
Chris
Re: Syntax of iterate operation [message #523791 is a reply to message #523789] Mon, 29 March 2010 02:18 Go to previous messageGo to next message
Hi Chris,
Alas, this seems to be a bug. Could you please file a bug report and use
"for" loops instead of "iterate" until we get this fixed?
Dimitris
Chris Holmes wrote:
> e.g.
> Regards
> Chris
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: Syntax of iterate operation [message #523795 is a reply to message #523791] Mon, 29 March 2010 07:35 Go to previous message
Hi Dimitris,
OK, will do.
Best Wishes
Chris
Dimitris Kolovos wrote:
> Hi Chris,
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi,
>> objects of type OrderedSet, however I'm having difficulty
>> understanding the syntax of the operation.
>> e.g.
>> to the format identified in the Epsilon book. This form also fails to
>> parse:
>> Regards
>> Chris
Re: Syntax of iterate operation [message #587870 is a reply to message #523789] Mon, 29 March 2010 07:11 Go to previous message
Hi Chris,
Dimitris
Chris Holmes wrote:
> e.g.
> Regards
> Chris
Re: Syntax of iterate operation [message #587883 is a reply to message #587870] Mon, 29 March 2010 07:35 Go to previous message
Hi Dimitris,
OK, will do.
Best Wishes
Chris
> Hi Chris,
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi,
>> e.g.
>> parse:
>> Regards
>> Chris
Previous Topic:Syntax of iterate operation
Next Topic:Debugging ETL
Current Time: Wed Jul 23 04:07:31 EDT 2025
Powered by FUDForum. Page generated in 0.62604 seconds
