JavaEditorPreferencePage [message #37941] |
Thu, 12 December 2002 11:25  |
Originally posted by: tim.duckdogmedia.com
Does anyone know if it's possible to add a checkbox to the existing
JavaEditorPreferencePage without hacking the JDT code? I've been trying to
get access to the control by creating a subclass of
JavaEditorPreferencePage but I just can't get it to work. The only thing
that does work for me is hacking the JDT code but I'd prefer to write a
plug-in that adds the checkbox. I could write a new preference page but
the option belongs with the JavaEditorPreferencePage. HELP!!!
Tim
Re: JavaEditorPreferencePage [message #38095 is a reply to message #38001] |
Fri, 13 December 2002 11:41  |
Originally posted by: jared-eclipse.mn.rr.com
The person who told you that it's not possible is a member of the JDT
development team. Maybe I'm being naive, but I trust that he knows what
he's talking about. :-)
- Jared
Tim Malin wrote:
> I wasn't sure if the answer was "truly" NO because the person stated that
> as far as they knew "there's no way". Are you saying that the answer is
> "no" because you know this to be true?
> Tim
> Jared Burns wrote:
>> When you asked this question on the eclipse.tools newsgroup, you were
>> told that the answer is no.
>> - Jared
>> > to get access to the control by creating a subclass of
>> > thing that does work for me is hacking the JDT code but I'd prefer to
>> > write a plug-in that adds the checkbox. I could write a new preference
>> > page but the option belongs with the JavaEditorPreferencePage. HELP!!!
>> > Thanks,
>> > Tim
Re: JavaEditorPreferencePage [message #587477 is a reply to message #37941] |
Thu, 12 December 2002 11:41  |
When you asked this question on the eclipse.tools newsgroup, you were told
- Jared
> Tim
Re: JavaEditorPreferencePage [message #587491 is a reply to message #37974] |
Fri, 13 December 2002 07:35  |
Tim
> - Jared
> > Thanks,
> > Tim
Re: JavaEditorPreferencePage [message #587505 is a reply to message #37941] |
Fri, 13 December 2002 08:22  |
Originally posted by: hcs33.egon.gyaloglo.hu
When you creating the subclass of JavaEditorPreferencePage did you change
the class name to your own class in the plugin.xml of the jdt.ui plugin? If
you change it to contain the name of your new class it maybe works (of
course, you cannot do it in another plugin entirely because of the
modification of plugin.xml :-()
Csaba
"Tim Malin" <tim@duckdogmedia.com> wrote in message
news:atadak$iv5$1@rogue.oti.com...
> Tim
Re: JavaEditorPreferencePage [message #587515 is a reply to message #38031] |
Fri, 13 December 2002 09:54  |
That's exactly one of the things that I'm trying to avoid, modifying
anything that has to do the eclipse base code (or other plugins). I want
to be able to create my own plug-in that has it's own plugin.xml all the
while extending the JavaEditorPreferencePage to add a checkbox.
-Tim
Horváth Csaba wrote:
> Regards,
> Csaba
> > Thanks,
> > Tim
Re: JavaEditorPreferencePage [message #587533 is a reply to message #38001] |
- Jared
> Tim
>> - Jared
>> > Thanks,
>> > Tim
FUDForum. Page generated in 0.05062 seconds
