Home » Eclipse Projects » GEF » Composite objects and GEF EditPart in one editor page
Composite objects and GEF EditPart in one editor page [message #5766] Thu, 30 May 2002 05:40 Go to next message
Originally posted by: swaminathan_p.persistent.co.in
I have to show two JFace Table Tree Viewers (one on the left
hand side and right hand side) on an editor. In between these
two I need a GEF EditPart view for rendering connection lines
between the Table-tree-items of the two Table-Tree objects.
How do I add a GEF EditPart (or EditorPart) in a composite object (editor) ?
Or do I need to add the two Table Tree Viewers on a GEF EditPart ?
I need to have a GEF EditPart
and draw some Draw2d Figures.
v
| | GEF Edit Part | |
| JFace Table | | JFace Table |
| Tree View | | Tree View |
| Page1 | Page2 | |
MultiPageEditorPart
Thanks in advance,
-Swamy
Re: Composite objects and GEF EditPart in one editor page [message #5875 is a reply to message #5766] Thu, 30 May 2002 15:15 Go to previous messageGo to next message
Originally posted by: none.ibm.com
You should just use an SWT canvas and add a PaintListener. Connections
require Figures at the other end, not TreeTableItems. And I assume the user
will interact with the tableTree, which is not GEF.
"Swaminathan P" <swaminathan_p@persistent.co.in> wrote in message
news:ad4qp8$rkv$1@rogue.oti.com...
> v
> | | GEF Edit Part | |
> | Page1 | Page2 | |
> MultiPageEditorPart
> Thanks in advance,
> -Swamy
Re: Composite objects and GEF EditPart in one editor page [message #5907 is a reply to message #5875] Thu, 30 May 2002 20:29 Go to previous messageGo to next message
Originally posted by: bob.objfac.com
Is there a GEF or draw2d figure that displays a tree?
Bob
"Randy Hudson" <none@ibm.com> wrote in message
news:ad5ss8$g7j$1@rogue.oti.com...
user
> > Hi,
(editor)
> > v
> > | | GEF Edit Part | |
> > | Page1 | Page2 | |
> > MultiPageEditorPart
> > Thanks in advance,
> > -Swamy
Re: Composite objects and GEF EditPart in one editor page [message #5960 is a reply to message #5875] Fri, 31 May 2002 02:06 Go to previous message
Hi Randy,
Thanks for your reply.
If we should use a SWT canvas, then is there any easy way to link the table
tree items and the connections in SWT canvas, because we need to
move/enable/disable the connections, depending upon different events on the
TableTree.
-Swamy
user
> > Hi,
(editor)
> > v
> > | | GEF Edit Part | |
> > | Page1 | Page2 | |
> > MultiPageEditorPart
> > Thanks in advance,
> > -Swamy
Re: Composite objects and GEF EditPart in one editor page [message #6461 is a reply to message #5960] Thu, 30 May 2002 18:46 Go to previous message
news:ad72iu$r9b$1@rogue.oti.com...
> Hi Randy,
table
the
> TableTree.
> -Swamy
Look at TreeEditor. This class manages a CellEditor, which is another SWT
Control that must follow the TreeItem behind it, and disappear when
necessary.
Previous Topic:Property Value Editing Problem
Next Topic:JDT Snippet says: Missing code implementation in the compiler
Current Time: Fri Sep 05 09:24:59 EDT 2025
Powered by FUDForum. Page generated in 0.15562 seconds
