Error while debugging [message #468813] |
Thu, 15 February 2007 20:01  |
public static void main(String[] args) throws
java.io.FileNotFoundException,
java.io.IOException,
java.lang.InterruptedException {
fileName = new String(args[args.length-1]);
// set up the parser and scanner with the appropriate file
// name
FileReader aslFile = new FileReader(fileName);
NolifeScanner scanner = new NolifeScanner(aslFile);
NolifeParser parser = new NolifeParser(scanner);
hi all,
I am debugging a java program in Eclipse 3.2.1 in debug perspective.
When I'm just running the program it's fine. But when I'm launching the
debugger, and trying to step into the NoLifeParser() it stops and shows me
the error message like this:
ClassLoader.class
Source not found
The source attachment does not contain the source for the ClassLoader.class
You can change the source attachment by clicking Change Attached Source
below:
BUTTON
and then the source code for ClassLoader class.
Please help, I'm struggling =(
Thanks in advance,....!!
Re: Error while debugging [message #468820 is a reply to message #468813] |
Wed, 21 February 2007 09:44  |
HI Sandesh,
Better to ask this question on eclipse.platform.
Doug
"Sandesh" <skkumbha@mtu.edu> wrote in message
news:60b1bec2515dc4545347f1de08833164$1@www.eclipse.org:
> // name
> hi all,
> ClassLoader.class
> Source not found
> below:
> BUTTON
Re: Error while debugging [message #587365 is a reply to message #468813] |
HI Sandesh,
Doug
> // name
> hi all,
> ClassLoader.class
> Source not found
> below:
> BUTTON
FUDForum. Page generated in 0.24610 seconds
