Home » Modeling » Epsilon » EVL is not working.
EVL is not working. [message #519153] |
Sun, 07 March 2010 08:16  |
Hello!!
My name is Jose Miguel. I'm trying validate my model whit GMF-based editor using Epsilon Validatiion lenguaje, but, I have some problems.
I'm using Eclipse Modeling. I have all Epsilon plugins and I'm using ubuntu 9.10.
I have created my GMF-editor using Eugenia, and It's working ok, so, Now I'm trying validate it. I followed the tutorial called "Live validation and quick-fixes in GMF-based editors with EVL" ( http://www.eclipse.org/gmt/epsilon/doc/articles/evl-gmf-inte gration/)
First Step: I create the integration plugin. I call it "NATversion1.validation".
Second step: I set the dependencies org.eclipse.ui.ide and org.eclipse.epsilon.evl.emf.validation to the list of dependences.
Third step: I created a evl file under validation/firewalls.evl . I have done this file very easy, It's only for try.
context Zone {
constraint HasName {
check : self.name.isDefined()
message : 'Mistake'
context Host {
constraint test2 {
check : true
message : 'Mistake2'
constraint test3 {
check : false
message : 'Mistake3'
constraint test4 {
check : return true
message : 'Mistake4'
constraint test4 {
check : return false
message : 'Mistake5'
In the class Zone, It have a attr called name.
Fourth step:
In the extensions I added org.eclipse.epsilon.evl.emf.validation. Them I did right-click it and add a new constraintBinding. In the namespaceURI y set to the value firewalls and in the constraints y select the last evl file.
Nex,I added the org.eclipse.ui.ide.markerResolution and created two markerResolutionGenerator.
One:
class : org.eclipse.epsilon.evl.emf.validation.EvlMarkerResolutionGe nerator
markerType : NATversion1.diagram.diagnostic
Other
markerType : org.eclipse.emf.ecore.diagnostic
Fifth step:
I opened a new eclipse instance, created a new firewalls diagram with errors, saved it, clicked "validate" and nothing happened. Nothing "Problems" and view no indication for a constraint violation...
What's wrong???
I've reproduced the filesistem example from filesistem.emf (creating all fom it) and doing all step by step, and I can't do it work.
Thank. Congratulations for this fantastic system.
Thank you very much.
Jose Miguel.
Re: EVL is not working. [message #519179 is a reply to message #519153] |
Sun, 07 March 2010 14:26   |
Hi Jose,
Could you please share your .emf metamodel so that I can have a look?
Dimitris
Jose Miguel wrote:
> Hello!!
> ubuntu 9.10.
> context Zone {
> message : 'Mistake'
> context Host {
> constraint test2 {
> check : true
> constraint test3 {
> check : false
> constraint test4 {
> check : return true
> constraint test4 {
> Fourth step:
> evl file.
> One:
> class :
> Other
> class :
> Fifth step:
> What's wrong???
> Thank. Congratulations for this fantastic system. ;)
> Jose Miguel.
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: EVL is not working. [message #519353 is a reply to message #519286] |
Mon, 08 March 2010 10:02   |
Hi Jose,
I've imported your plugins, used your runtime workspace, opened
default.firewalls_diagram, clicked Edit->Validate and it seems to be
working fine for me (error markers appeared as expected)... Which
version of Eclipse Modeling / Epsilon are you using?
Dimitris
Dimitris Kolovos wrote:
> Hi Jose,
> The metamodel looks fine... Could you please zip your plugin projects
> and send them to me at dskolovos _ gmail _ com so that I can have a look?
> Cheers,
> Dimitris
> Jose Miguel wrote:
>> Hello Dimitrios.
>> Thank you for your help.
>> Here you are the emf metamodel.
>> @namespace(
>> uri="firewalls",
>> prefix="firewalls")
>> package firewalls;
>> @gmf.diagram(foo="bar")
>> class Diagrama{
>> val Zona[*] zonas;
>> val Firewall[*] firewalls;
>> val Estructura[*] estructuras;
>> @gmf.node(label = "nombre_host")
>> class Host{
>> attr String nombre_host;
>> @gmf.node(label = "nombre_server")
>> class Server{
>> attr String nombre_server;
>> @gmf.node(label = "name")
>> class Zona{
>> attr String name;
>> @gmf.compartment(foo="bar")
>> val Host[*] host;
>> val Server[*] servers;
>> class Firewall {
>> attr String name;
>> @gmf.link(source="source", target="target", style="dot", width="2")
>> class Estructura{
>> ref Firewall source;
>> ref Zona target;
>> This is a old version. The current version is so much complicated and
>> is using Nodes with images so, It's more difficult if you try
>> reproduce it. I have tried validate this meta-model, and I neither can
>> do it.
>> I don't know what can be happening.
>> Jose Miguel.
Re: EVL is not working. [message #587114 is a reply to message #519153] |
Hi Jose,
Dimitris
Jose Miguel wrote:
> Hello!!
> ubuntu 9.10.
> context Zone {
> message : 'Mistake'
> context Host {
> constraint test2 {
> check : true
> constraint test3 {
> check : false
> constraint test4 {
> check : return true
> constraint test4 {
> Fourth step:
> evl file.
> One:
> class :
> Other
> class :
> Fifth step:
> What's wrong???
> Jose Miguel.
Re: EVL is not working. [message #587162 is a reply to message #519179] |
Mon, 08 March 2010 06:40  |
Hello Dimitrios.
@namespace(
uri="firewalls",
prefix="firewalls")
package firewalls;
class Diagrama{
val Zona[*] zonas;
class Host{
class Server{
class Zona{
attr String name;
val Host[*] host;
class Firewall {
attr String name;
class Estructura{
ref Zona target;
This is a old version. The current version is so much complicated and is using Nodes with images so, It's more difficult if you try reproduce it. I have tried validate this meta-model, and I neither can do it.
Jose Miguel.
Re: EVL is not working. [message #587171 is a reply to message #587162] |
Mon, 08 March 2010 06:42  |
Hi Jose,
Dimitris
Jose Miguel wrote:
> Hello Dimitrios.
> @namespace(
> uri="firewalls",
> prefix="firewalls")
> package firewalls;
> class Diagrama{
> val Zona[*] zonas;
> class Host{
> class Server{
> class Zona{
> attr String name;
> val Host[*] host;
> class Firewall {
> attr String name;
> class Estructura{
> ref Zona target;
> Jose Miguel.
Re: EVL is not working. [message #587198 is a reply to message #519286] |
Hi Jose,
Dimitris
> Hi Jose,
> Cheers,
> Dimitris
> Jose Miguel wrote:
>> Hello Dimitrios.
>> @namespace(
>> uri="firewalls",
>> prefix="firewalls")
>> package firewalls;
>> class Diagrama{
>> val Zona[*] zonas;
>> class Host{
>> class Server{
>> class Zona{
>> attr String name;
>> val Host[*] host;
>> class Firewall {
>> attr String name;
>> class Estructura{
>> ref Zona target;
>> do it.
>> Jose Miguel.
Re: EVL is not working. [message #587213 is a reply to message #519353] |
Tue, 09 March 2010 05:20  |
Hi Dimitrios:
I'm using this versions:
Eclipse Modeling Tools 1.2.1.20090918-0703 epp.package.modeling
Emfatic (Incubation) 0.3.0.200810132307 org.eclipse.emf.emfatic_feature.feature.group
Epsilon Core (Incubation) 0.8.8.200910281243 org.eclipse.epsilon.feature.feature.group
Epsilon EMF/GMF Live Validation (Incubation) 0.8.8.200910281243 org.eclipse.epsilon.evl.emf.validation.feature.feature.group
Epsilon EMF/GMF Scripting (Incubation) 0.8.8.200910281243 org.eclipse.epsilon.gmf.feature.feature.group
Epsilon Eugenia (Incubation) 0.8.8.200910281243 org.eclipse.epsilon.eugenia.feature.feature.group
This is very rare... :(
Thank you very very much.
Re: EVL is not working. [message #587223 is a reply to message #587213] |
Tue, 09 March 2010 05:33  |
Hi Jose,
Could you please download one of the distributions available in
http://eclipse.org/gmt/epsilon/download/ and install Epsilon and Emfatic
on top of it? Apologies for the inconvenience; I don't have a
readily-available Linux environment to test (but can get one if
necessary) so before I do so, we need to be sure that we're using
exactly the same versions.
Dimitris
Jose Miguel wrote:
> Hi Dimitrios:
Re: EVL is not working. [message #587234 is a reply to message #587213] |
Tue, 09 March 2010 06:15  |
Hi Again Dimitrios:
It's working!!! I don't know what was happening, but I have removed Eclipse and I have installed all again, and now, it's working!!!
Thank you very much for your help, You are the best ;)
Current Time: Tue Jul 22 20:35:54 EDT 2025
Powered by FUDForum. Page generated in 0.04259 seconds
