Home » Eclipse Projects » Nebula » fix for cosmetic painting problem in PGroup
| fix for cosmetic painting problem in PGroup [message #33926] |
Thu, 03 May 2007 09:46  |
Originally posted by: slorenc.infogix.com
I ran into a painting problem with PGroup which has rounded corners. When
you set PGroups background to something other than the parent control's
background Pgroup's background bleeds outside the 4 rounded corners.
I fixed this problem by adding 2 lines of code in RectangleGroupStrategy's
paint method and would like to offer this fix to be incorporated into the
code.
First I set the background color to parent's color around line 136. See
| Re: fix for cosmetic painting problem in PGroup [message #34001 is a reply to message #33926] |
Thu, 03 May 2007 12:18   |
Hi Swavek,
PGroup is designed to correctly show the parent's background if you use
the SWT background mode features. If you call
setBackgroundMode(SWT.INHERIT_DEFAULT) then you should see the
background color of the parent bleed through correctly.
-Chris
> code.
> First I set the background color to parent's color around line 136. See à
> Color back = getGroup().internalGetBackground();
> if (back != null)
> // fill background with parent color so the areas outside the
> rounded edges have the same color as parent
> à gc.setBackground(getGroup().getParent().getBackground()); //
> added line
> gc.fillRectangle(0,0,getGroup().getSize().x,getGroup().getSi ze().y);
> The second place where this fix is made is in the code which paints the
> bottom rounded rectangle around line 404.
> gc.setClipping(reg);
> // fill the background constrained by the clipping region
> à gc.fillRectangle(0, titleHeight, getGroup().getSize().x - 1,
> getGroup().getSize().y - titleHeight); // added line
> // draw rounded bottom border
> GraphicUtils.drawRoundRectangle(gc, 0, titleHeight,
> titleHeight, null, false,
> true);
> reg.dispose();
> Swavek Lorenc
> slorenc@infogix.com
| Re: fix for cosmetic painting problem in PGroup [message #44943 is a reply to message #34001] |
Tue, 18 December 2007 04:40   |
Hi Chris,
I don't know maybe I'm doing something wrong but code like this:
PGroup group_other = new PGroup(form, SWT.SMOOTH);
group_other.addControlListener(new Relayout());
group_other.setExpanded(false);
group_other.setBackgroundMode(SWT.INHERIT_DEFAULT);
group_other.setBackground(group_other.getDisplay().getSystem Color(SWT.COLOR_WHITE));
Leaves white edges at the bottom and top! Is there something I'm doing
wrong? Adding the 2 lines from this post fixes the problem reveals
another one because when putting Group-Widgets inside the PGroup their
border is not rendered any more.
I've tested with WinXP and Eclipse-3.3.
Tom
Chris Gross schrieb:
> Hi Swavek,
> Regards,
> -Chris
>> When you set PGroups background to something other than the parent
>> control's background Pgroup's background bleeds outside the 4 rounded
>> corners.
>> RectangleGroupStrategy's paint method and would like to offer this fix
>> to be incorporated into the code.
>> See à
>> if (back != null)
>> the rounded edges have the same color as parent
>> // added line
>> the bottom rounded rectangle around line 404.
>> - 1, getGroup().getSize().y - titleHeight); // added line
>> - titleHeight, null, false,
>> true);
>> reg.dispose();
>> Swavek Lorenc
>> slorenc@infogix.com
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
| Re: fix for cosmetic painting problem in PGroup [message #45335 is a reply to message #44943] |
Fri, 04 January 2008 16:21  |
You have to call setBackgroundMode on the parent of the PGroup. The
background mode API is (IMO) really confusing. I've added a new snippet
to show how to do correctly. Let me know if this helps:
http://dev.eclipse.org/viewcvs/index.cgi/~checkout~/org.ecli pse.swt.nebula/org.eclipse.swt.nebula.snippets/src/org/eclip se/swt/nebula/snippets/pgroup/PGroupSnippet2.java?cvsroot=Te chnology_Project
-Chris
Tom Schindl wrote:
> Hi Chris,
> Tom
>> Hi Swavek,
>> use the SWT background mode features. If you call
>> Regards,
>> -Chris
>>> corners.
>>> fix to be incorporated into the code.
>>> See à
>>> if (back != null)
>>> // added line
>>> region
>>> getGroup().getSize().x - 1, getGroup().getSize().y - titleHeight);
>>> // added line
>>> getGroup().getSize().y - titleHeight, null, false,
>>> true);
>>> reg.dispose();
>>> Swavek Lorenc
>>> slorenc@infogix.com
| Re: fix for cosmetic painting problem in PGroup [message #581717 is a reply to message #33926] |
Hi Swavek,
-Chris
> code.
> if (back != null)
> added line
> true);
> reg.dispose();
> Swavek Lorenc
> slorenc@infogix.com
| Re: fix for cosmetic painting problem in PGroup [message #587036 is a reply to message #34001] |
Hi Chris,
Tom
> Hi Swavek,
> Regards,
> -Chris
>> corners.
>> See à
>> if (back != null)
>> // added line
>> true);
>> reg.dispose();
>> Swavek Lorenc
>> slorenc@infogix.com
| Re: fix for cosmetic painting problem in PGroup [message #587152 is a reply to message #44943] |
-Chris
Tom Schindl wrote:
> Hi Chris,
> Tom
>> Hi Swavek,
>> Regards,
>> -Chris
>>> corners.
>>> See à
>>> if (back != null)
>>> // added line
>>> region
>>> // added line
>>> true);
>>> reg.dispose();
>>> Swavek Lorenc
>>> slorenc@infogix.com
Current Time: Sun Nov 02 07:07:44 EST 2025
Powered by FUDForum. Page generated in 0.34694 seconds
