Problem reproducing EOL Tool Simmetrics Example [message #587076] |
Sun, 07 March 2010 06:36  |
I'm stuck trying to reproduce the Simmetrics Tool example. I'm exporting the tool as a plugin, place in the dropins folder and can see it in the Epsilon perspective in the tools tab. No problem there. However, when trying to use the similarity function, I keep getting a class not found exception: java.lang.ClassNotFoundException: uk.ac.shef.wit.simmetrics.similaritymetrics.JaroWinkler
I'm really no expert creating Eclipse plugins. So I have been putting the library in the plugin's build path and added it to the bundle-class path ... with little success.
What am I overlooking? How should the Manifest for the example look like?
Thanks a lot for your help!
Anne
Re: Problem reproducing EOL Tool Simmetrics Example [message #587126 is a reply to message #587119] |
Sun, 07 March 2010 16:31  |
Hi Anne,
To make simmetrics.jar visible to your tool, you need to create a plugin
from it using the New->Plug-in from Existing JAR Archives wizard and
then add the created simmetrics plugin to the dependencies of the plugin
where you define the tool.
Dimitris
Anne wrote:
> Hi Dimitris,
> thank you for the quick reply and the article. I had checked the article
> before and don't think that this is where the problem lies. The tool
> works fine for functions not accessing the simmetrics library. So I
> guess my problem is somehow with exporting the simmetrics jar...
> Thanks again,
> Anne
FUDForum. Page generated in 0.04206 seconds
