Horisontal scrolling during column draging [message #586989] |
Fri, 14 December 2007 05:04 |
--------------050403080303090909090309
Hi!
I've met some unexpected issue with column dragging. If a column is
dragged on right (or left) invisible area, a grid will not be scrolled
to reach invisible columns. Nevertheless, grid is scrolled during multi
selection dragging. Please use an attached snippet and try to select
invisible cells, than drag column into invisible target column.
Could you advice some solution for scrolling grid during column
dragging? Thank you in advance.
Andrey
name="MxSnippet026TreeViewerTabEditingForGrid.java"
Content-Disposition: inline;
filename="MxSnippet026TreeViewerTabEditingForGrid.java"
package com.maconomy.widgets.snippets;
import java.util.ArrayList;
import org.eclipse.jface.viewers.CellEditor;
import org.eclipse.jface.viewers.ColumnLabelProvider;
import org.eclipse.jface.viewers.ColumnViewerEditor;
import org.eclipse.jface.viewers.ColumnViewerEditorActivationEvent;
import org.eclipse.jface.viewers.ColumnViewerEditorActivationStrate gy;
import org.eclipse.jface.viewers.EditingSupport;
import org.eclipse.jface.viewers.ITreeContentProvider;
import org.eclipse.jface.viewers.TextCellEditor;
import org.eclipse.jface.viewers.Viewer;
import org.eclipse.nebula.jface.gridviewer.GridTableViewer;
import org.eclipse.nebula.jface.gridviewer.GridViewerColumn;
import org.eclipse.nebula.jface.gridviewer.GridViewerEditor;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.events.SelectionListener;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Shell;
* A simple TreeViewer to demonstrate usage. Anyone could extend the snippet for test purposer or bug reporting.
* @author Tom Schindl <tom.schindl@bestsolution.at>
public class MxSnippet026TreeViewerTabEditingForGrid {
* @param shell
public MxSnippet026TreeViewerTabEditingForGrid(final Shell shell) {
final Button b = new Button(shell,SWT.PUSH);
b.setText("Remove column");
// Grid used instead jFace viewer
final GridTableViewer v = new GridTableViewer(shell, SWT.FULL_SELECTION | SWT.BORDER | SWT.V_SCROLL | SWT.H_SCROLL);
v.getGrid().setLinesVisible(true);
v.getGrid().setHeaderVisible(true);
b.addSelectionListener(new SelectionListener() {
public void widgetDefaultSelected(SelectionEvent e) {
public void widgetSelected(SelectionEvent e) {
v.getGrid().getColumn(1).dispose();
// does not available for Grid
//TableViewerFocusCellManager focusCellManager = new TableViewerFocusCellManager(v,new FocusCellOwnerDrawHighlighter(v));
final ColumnViewerEditorActivationStrategy actSupport = new ColumnViewerEditorActivationStrategy(v) {
protected boolean isEditorActivationEvent(
ColumnViewerEditorActivationEvent event) {
System.out.println("event "+event.eventType);
return event.eventType == ColumnViewerEditorActivationEvent.TRAVERSAL
//mouse click activation!!!
|| event.eventType == ColumnViewerEditorActivationEvent.MOUSE_CLICK_SELECTION
|| (event.eventType == ColumnViewerEditorActivationEvent.KEY_PRESSED && event.keyCode == SWT.CR)
|| event.eventType == ColumnViewerEditorActivationEvent.PROGRAMMATIC;
GridViewerEditor.create(v, actSupport, ColumnViewerEditor.TABBING_HORIZONTAL | ColumnViewerEditor.TABBING_MOVE_TO_ROW_NEIGHBOR
| ColumnViewerEditor.TABBING_VERTICAL | ColumnViewerEditor.KEYBOARD_ACTIVATION);
v.getGrid().setCellSelectionEnabled(true);
final TextCellEditor textCellEditor = new TextCellEditor(v.getGrid());
GridViewerColumn column = new GridViewerColumn(v, SWT.NONE);
column.getColumn().setWidth(270);
column.getColumn().setMoveable(true);
column.getColumn().setText("Column 1");
column.setLabelProvider(new ColumnLabelProvider() {
public String getText(Object element) {
return "Column 1 => " + element.toString();
column.setEditingSupport(new EditingSupport(v) {
protected boolean canEdit(Object element) {
return false;
protected CellEditor getCellEditor(Object element) {
return textCellEditor;
protected Object getValue(Object element) {
return ((MyModel) element).counter + "";
protected void setValue(Object element, Object value) {
((MyModel) element).counter = Integer
.parseInt(value.toString());
v.update(element, null);
column.getColumn().setText("Column 2");
return "Column 2 => " + element.toString();
return true;
column.getColumn().setWidth(200);
column.getColumn().setText("Column 3");
return "Column 3 => " + element.toString();
return true;
column = new GridViewerColumn(v, SWT.CHECK | SWT.CENTER);
column.getColumn().setText("Column 4");
return null;
v.setContentProvider(new MyContentProvider());
v.setInput(createModel());
private MyModel createModel() {
final MyModel root = new MyModel(0, null);
root.counter = 0;
MyModel tmp;
MyModel subItem;
for (int i = 1; i < 10; i++) {
tmp = new MyModel(i, root);
root.child.add(tmp);
for (int j = 1; j < i; j++) {
subItem = new MyModel(j, tmp);
subItem.child.add(new MyModel(j * 100, subItem));
tmp.child.add(subItem);
return root;
final Display display = new Display();
final Shell shell = new Shell(display);
shell.setLayout(new FillLayout());
new MxSnippet026TreeViewerTabEditingForGrid(shell);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch())
display.sleep();
display.dispose();
private class MyContentProvider implements ITreeContentProvider {
public Object[] getElements(Object inputElement) {
return ((MyModel) inputElement).child.toArray();
public void dispose() {
public void inputChanged(Viewer viewer, Object oldInput, Object newInput) {
public Object[] getChildren(Object parentElement) {
return getElements(parentElement);
public Object getParent(Object element) {
if (element == null) {
return null;
return ((MyModel) element).parent;
public boolean hasChildren(Object element) {
return ((MyModel) element).child.size() > 0;
public class MyModel {
public MyModel parent;
public ArrayList child = new ArrayList();
public int counter;
public MyModel(int counter, MyModel parent) {
this.parent = parent;
this.counter = counter;
public String toString() {
String rv = "Item ";
if (parent != null) {
rv = parent.toString() + ".";
rv += counter;
return rv;
--------------050403080303090909090309--
FUDForum. Page generated in 0.03628 seconds
