Home » Eclipse Projects » Mylyn » Configuration Caching missing for Bugzilla 2.2.0
Configuration Caching missing for Bugzilla 2.2.0 [message #40174] Mon, 31 December 2007 17:40 Go to next message
I have a quick question, to verify a problem before I file a bug report,
about the Bugzilla Connector.
The New & Noteworthy shows a screen shot of a option labeled "Cached
Configuration" that I cannot seem to find on the version that I
installed today (2.2.0.I20071220-1700). This was an upgrade from 2.1,
and to verify I did a clean install onto a bare platform runtime, and
saw the same missing option. This this indeed missing or am I doing
something wrong?
Thank you for your time.
Sun JDK 1.6.0_03
Windows XP SP2
Eclipse SDK 3.3.1.1
Targeting bugs.eclipse.org/bugs
Re: Configuration Caching missing for Bugzilla 2.2.0 [message #40512 is a reply to message #40174] Wed, 09 January 2008 05:22 Go to previous messageGo to next message
Noticed the same thing today.
It was put in place to resolve a load/performance problem on
bugs.eclipse.org. It works by sending a HEAD request before doing a
config update to check whether there have been mods and works only on
bugs.eclipse.org as it requires mods to bugzilla itself.
It was dropped from the development stream on 5 october 2007 when the
gzip patches were put in. See the source history on
BugzillaRepositorySettingsPage.java#createAdditionalControls
version 1.70
bugs.eclipse.org resolved the issue by generating the config once a day
and propagating that to the download mirrors around the world.
When you request confiig.cgi from bugs.eclipse.org, you actually get a
file from some other server near you.
Vote for bug 205416 when you want gzip encoding on bugs.eclipse.org
If you want to increase performance on another bugzilla, look at:
196056: [performance] reduce frequency of repository configuration download
https://bugs.eclipse.org/bugs/show_bug.cgi?id=196056
205416: In order to reduce traffic, the bugzilla should not only cache
its config but also gzip it
https://bugs.eclipse.org/bugs/show_bug.cgi?id=205416
205708: Make Mylyn accept gzip encoded data on all requests
https://bugs.eclipse.org/bugs/show_bug.cgi?id=205708
These require mods to bugzilla itself as well for the config, but the
rest can be implemented by adding mod_gzip/mod_deflate to Apache
You should file a bug report, as it is an error in the new and noteworthy!
Maarten
> something wrong?
> Sun JDK 1.6.0_03
> Windows XP SP2
> Eclipse SDK 3.3.1.1
Re: Configuration Caching missing for Bugzilla 2.2.0 [message #40573 is a reply to message #40174] Wed, 09 January 2008 07:57 Go to previous messageGo to next message
Created bug 214739: New & Noteworthy for 2.2 mentions cached
configuration, but option is absent from bugzilla connector
https://bugs.eclipse.org/bugs/show_bug.cgi?id=214739
> something wrong?
> Sun JDK 1.6.0_03
> Windows XP SP2
> Eclipse SDK 3.3.1.1
Re: Configuration Caching missing for Bugzilla 2.2.0 [message #40975 is a reply to message #40573] Fri, 11 January 2008 18:36 Go to previous message
Originally posted by: beatmik.acm.org
This is now automatic if caching is available, so the user does not need
to be aware of the setting. Thanks for pointing this out. I have
updated the New & Noteworthy and linked to your instructions for admins,
which I have moved to:
http://wiki.eclipse.org/Mylyn_User_Guide#Tips_for_server_adm inistrators
Mik
>> report, about the Bugzilla Connector.
>> something wrong?
>> Sun JDK 1.6.0_03
>> Windows XP SP2
>> Eclipse SDK 3.3.1.1
Re: Configuration Caching missing for Bugzilla 2.2.0 [message #586708 is a reply to message #40174] Wed, 09 January 2008 05:22 Go to previous message
version 1.70
Maarten
> something wrong?
> Sun JDK 1.6.0_03
> Windows XP SP2
> Eclipse SDK 3.3.1.1
Re: Configuration Caching missing for Bugzilla 2.2.0 [message #586729 is a reply to message #40174] Wed, 09 January 2008 07:57 Go to previous message
> something wrong?
> Sun JDK 1.6.0_03
> Windows XP SP2
> Eclipse SDK 3.3.1.1
Re: Configuration Caching missing for Bugzilla 2.2.0 [message #586926 is a reply to message #40573] Fri, 11 January 2008 18:36 Go to previous message
Mik
>> something wrong?
>> Sun JDK 1.6.0_03
>> Windows XP SP2
>> Eclipse SDK 3.3.1.1
Previous Topic:JIRA improvements
Next Topic:Problems updating from Mylyn 2.1 to 2.2 using Update Manager
Current Time: Sun Jun 29 23:10:54 EDT 2025
Powered by FUDForum. Page generated in 0.07712 seconds
