Home » Archived » Riena » How to build Riena from source?
icon5.gif  How to build Riena from source? [message #541400] Sun, 20 June 2010 18:20 Go to next message
Me again,
I wonder what's the best way to build the whole of Riena (target platform components) from source?! I've imported the Team Project Set file bundled with org.eclipse.riena.releng, but still see a lot of errors and unsolved dependencies.
For example, what's the target platform definition I need to use? I suppose the one that comes with org.eclipse.riena.ui.templates should suffice for building the IDE toolset components at least, but since it complains about a number of unresolved installable units when opened I also wonder whether or not its still being actively maintained.
Also, why are there 3 different plug-ins starting in org.eclipse.riena.build*? Which one's currently being used?
Any hints for me where to start looking? Is there perhaps some magic Wiki page on building Riena from source that I managed to miss so far Smile?
Thanks in advance,
Chris
[Updated on: Sun, 20 June 2010 18:20] by Moderator
Re: How to build Riena from source? [message #541746 is a reply to message #541400] Tue, 22 June 2010 08:18 Go to previous messageGo to next message
Am 21.06.10 00:20, schrieb Christian Kesselheim:
> Me again,
> suffice for building the toolset component at least, but since it
> Wiki page on building Riena from source that I managed to miss so far :)?
> Thanks in advance,
> Chris
Hi Chris,
If you like to have Riena in your workspace you need to installed Equinox SDK and RCP SDK into a new target platform and
activate that target platform. You can easily do that using the Helios repo and that should be it.
That is true for the Riena runtime pieces.
You need a second workspace to deal with the Riena toolbox. The target platform there is just the IDE and there is a
seperate releng for the toolbox o.e.r.toolbox.releng.
When you install the Riena Toolbox one of the benefits is that a .target file that is anywhere within the plugins is
offered to become a new target. So say you have that installed as an IDE plugin, you can easily activate the definition
in o.e.r.ui.templates called riena_2.0.0.target which is the target definition for creating Riena-based applications.
Building Riena in a build process is a little tricky and we were fighting with our build since the beginning. Elias now
helped us create a build project org.eclipse.riena.build3 that finally does it all. So build and build2 are just
previous attempts to build Riena.
However the build only runs on windows and need to have a set of files and a certain directory structure that we havnt
come around to describe anywhere. If you like to have your own build running as a headless build, I think a good first
step would be to open a bug and push us to describe that directory structure for you :-)
regards
christian
Re: How to build Riena from source? [message #541757 is a reply to message #541400] Tue, 22 June 2010 08:51 Go to previous messageGo to next message
Thanks a lot, that really helped. Since we're planning on using Riena for our next RCP solution (and I guess there will come the time when we'll want to do our own patches and bug-fixes), I'm currently thinking about setting-up a private nightly build of Riena on our company's own Hudson server. So perhaps I'll have to file that "describe your directory structure" bug request you've mentioned after all Smile.
So far, my main source of confusion stems from the fact that importing the Riena Team Project Set from CVS doesn't seem to produce an error-free workspace configuration, at least not for me.
For example:
1. org.sl4j.* is missing while org.apache.log4j is not. Since org.sl4j.log4j also contains its own version of log4j (and is installed in the Riena target platform by default), the compiler seems so get confused and prefers the (possibly outdated) target platform org.sl4j.log4j over the org.apache.log4j I have locally checked-out. As a result, recent API changes in log4j (e.g. Category.setLevel()) will not be visible and produce a problem marker in org.eclipse.riena.core. Checking out a fresh org.sl4j.* from Orbit CVS makes the problem go away, so I wonder if this should not be included in the team project set by default.
2. Bundles like org.eclipse.riena.exceptionmanager and org.eclipse.riena.workspace have broken imports (e.g. ServiceInjector) or dependencies (e.g. dependency on org.eclipse.riena.ui.core missing), so I wonder if these bundles are still actively maintained/required.
3. Bundles like org.eclipse.riena.ui.tests or org.eclipse.riena.security.services.config don't compile at all for me (source directory/class reference missing).
As soon as I get this working for me (and my Hudson) I will the results as part of some blog, so you can review and laugh at all my ridiculous rookie mistakes Smile.
[Updated on: Tue, 22 June 2010 08:55] by Moderator
Re: How to build Riena from source? [message #541958 is a reply to message #541757] Wed, 23 June 2010 07:25 Go to previous messageGo to next message
Hi Christian,
I am really wondering if you are really getting at the *.psf file.
You should NOT get every project in CVS that has "riena" it its name, but rather only get org.eclipse.riena.releng. And
then use the projectSet-pserver.psf file -> Import Project Set ...
That should really avoid ALL the problems below.
Am 22.06.10 14:51, schrieb Christian Kesselheim:
> directory structure" bug request you've mentioned after all :).
> For example:
> confused and prefers the (outdated) target platform log4j over the one I
> have locally checked-out. As a result, recent changes in log4j (e.g.
> Category.setLevel) will not be visible and produce a problem marker in
We use org.apache.log4j in our workspace. On request we are actually importing the package and dont require the
org.apache.log4j bundle. For that reason p2 "picks" a bundle and it use org.sl4j.* which also contains log4j. I know
Ekke also uses sl4j, but I just have org.apache.log4j v1_2_13 in my workspace and that works.
org.apache.log4j is in our project set.
> so I wonder if these bundles are actively maintained/required at this
> point in time.
These bundles are no longer active and they are, as far as I can tell, not in the *.psf file.
security.services.config is outdated (again not in the psf file). ui..tests. are ...... not in the .psf file
> As soon as I get this working for me (and my Hudson) I might publish the
> results as part of some blog, so you can review and laugh at my rookie
> mistakes :).
cool....please post the blog entry url here once you get around to do that.
christian
p.s. if you have more questions let us know. We actually make a living from supporting people running Riena based
projects. So if you need more help that newsgroup, mailing list or bugzilla can offer, please get directly in touch with
me. But that doesnt mean we dont continue to answer mails here in the newsgroup or in bugzilla. Sometimes starting on
the right foot is the hardest part and we have some experience doing just that.
Re: How to build Riena from source? [message #541967 is a reply to message #541400] Wed, 23 June 2010 08:15 Go to previous messageGo to next message
Argh, my mistake indeed. At some point I decided to create a GIT mirror of the Riena CVS repository and then clone & serve my sandbox from there. I then simply forgot to "filter" projects again (against the project set) when re-importing them into Eclipse.
Building my target platform by hand instead of using a physical target definition file (effectively by-passing the P2 Planner here) also makes the sl4j vs. log4j confusion go away.
I'm always surprised by the somewhat disproportional complexity of Eclipse topics like provisioning (P2) and head-less build (PDE Build, Buckminster, Tycho, etc.) when compared to some of the more runtime-oriented concepts, such as basic RCP UI, branding, help system or even Riena.
Anyway, thanks (again!) for your kind help and suggestions. It's deeply appreciated Smile.
Chris
Re: How to build Riena from source? [message #541986 is a reply to message #541967] Wed, 23 June 2010 08:54 Go to previous messageGo to next message
Am 23.06.10 14:15, schrieb Christian Kesselheim:
> or even Riena.
> appreciated :).
> Cheers,
> Chris
I am sure you did not create your own Git mirror from CVS but knew :-) that the Eclipse foundation is actually already
doing that for all Eclipse projects providing a readonly Git repo as listed here http://dev.eclipse.org/git/index.html
So Riena is in a pretty up-to-date version right here git://dev.eclipse.org/org.eclipse.riena/org.eclipse.riena.gi t
Again that wouldnt help you with sorting out the redundant projects.....maybe now that the release is over, I will take
the time and ask the webmaster to delete those projects.
christian
Re: How to build Riena from source? [message #541990 is a reply to message #541400] Wed, 23 June 2010 09:11 Go to previous messageGo to next message
I am sure you did not create your own Git mirror from CVS but knew Smile that the Eclipse foundation is actually already
Indeed I didn't. Another hour of my lifetime wasted, I guess Smile. Thanks again for the tip.
icon9.gif  Re: How to build Riena from source? [message #544497 is a reply to message #541400] Fri, 02 July 2010 18:17 Go to previous messageGo to next message
After hours of trial and error (my custom build of Riena just wouldn't work properly at run-runtime), I just discovered that the Riena GIT repository is most probably broken and will have to be re-created (I think):
https://bugs.eclipse.org/bugs/show_bug.cgi?id=318766
Of all the possible root causes for my troubles, a broken CVS-GIT synchronization process at Eclipse.org was probably the last thing I'd ever have considered...
Strange world. Confused
Re: How to build Riena from source? [message #544630 is a reply to message #544497] Mon, 05 July 2010 02:30 Go to previous messageGo to next message
Am 03.07.10 00:18, schrieb Christian Kesselheim:
> think):
> Strange world. :?
First of all, you are really a brave guy trying to get the build running without a proper description......
The riena-build3 (and I hope that is what you are using) is build using CVS checkouts. So you dont really need a Git
mirror in order to build. However it uses checkouts using ssh which you cant do, since you are no committer. Still you
could the pserver access. There are sometimes sync issues with the pserver mirror, but they only stay around for a few
hours.
Second I am not really sure I understand WHY you want to run your own build ? Isnt the version in the Helios repo and
the milestones that we provide not good enough for any reason ?
christian
Re: How to build Riena from source? [message #544645 is a reply to message #544630] Mon, 05 July 2010 03:55 Go to previous messageGo to next message
Hi Christian,
I'm aware of the build3 project using CVS checkout. On the other hand, we've recently begun to create patches/extensions to the Riena source base on our own (most of which we'll eventually try to contribute back, of course), so we needed some internal, nightly-build Riena update site that we could use to re-materialize of our target platform on a regular basis.
Also, there are a couple of bugfixes (e.g. compatibility with SpringExtensionFactory at the controller/view-level, see https://bugs.eclipse.org/bugs/show_bug.cgi?id=317540) which we rely on but that - to my knowledge - aren't currently part of any standard Riena download (AFAIK, there is currently no official nightly build of Riena available online, is there?).
In the meantime, we've solved the problem by setting-up our own custom GIT mirror of the Riena CVS repository using GIT 1.7.1 and CVSPS 2.1 (the resulting GIT repository seems to contain all CVS commits that the official Eclipse GIT repository is currently lacking).
Still, I strongly recommend that someone at Eclipse re-creates the Riena GIT repository from CVS using an up-to-date version of GIT and CVSPS. In its currently shape (missing some commits here and there), the mirror will otherwise only serve to confuse people, since no one would honestly suspect a flaw in their version control system to be the root cause behind a given compile or run-time error. I know, because I didn't Very Happy !
Thanks again for this great product and the time you've spent so far in educating Riena rookies like myself Smile.
Regards from Luxembourg,
Chris
Re: How to build Riena from source? [message #544698 is a reply to message #544645] Mon, 05 July 2010 05:26 Go to previous messageGo to next message
Hi Chris,
I'd be really interested to hear what you are doing, what you are missing, what new things you are doing.
Maybe you can give a little back :-) and tell everybody what you are up to........
It would also be nice, if you could write a wiki page at wiki.eclipse.org that describes how to set up your own Riena build.
Yes thats all time consuming, but it would help many others (who are in the same position that you are)....
regards
christian
Am 05.07.10 09:55, schrieb Christian Kesselheim:
> Hi Christian,
> basis.
> behind a given compile or run-time error. I know, because I didn't :d !
> educating Riena rookies like myself :).
> Chris
Re: How to build Riena from source? [message #544714 is a reply to message #544698] Mon, 05 July 2010 06:48 Go to previous messageGo to next message
We'll definitely start to contribute our changes back to Eclipse/Riena at some point in the process, just give us a few more weeks to get our hands dirty and acquire some more knowledge about Riena and how it is best to be used.
So far, our bugfixes/extensions are mainly related to unit testing in the scope of Riena. It appears there are still numerous places in the code base where certain ridgets/features will work fine at run-time but fail with a rather non-descriptive error message when invoked from within a headless unit test. Since we're developing all our code on a purely test-driven basis (while actually learning how to use and thus doing all kinds of crazy things with the Riena API at the same time), it happens that we bump into the occasional NullpointerException etc. now and then. These we then fix on our own branch of Riena, which is why we need to headless build to provide us with an up-to-date P2 update site in the first place.
Re: How to build Riena from source? [message #585959 is a reply to message #541757] Wed, 23 June 2010 07:25 Go to previous messageGo to next message
Hi Christian,
> For example:
> point in time.
> mistakes :).
christian
Re: How to build Riena from source? [message #586227 is a reply to message #544630] Mon, 05 July 2010 03:55 Go to previous messageGo to next message
Hi Christian,
Still, I strongly recommend that someone at Eclipse re-creates the Riena GIT repository from CVS using an up-to-date version of GIT and CVSPS. In its currently shape (missing some commits here and there), the mirror will otherwise only serve to confuse people, since no one would honestly suspect a flaw in their version control system to be the root cause behind a given compile or run-time error. I know, because I didn't :d !
Thanks again for this great product and the time you've spent so far in educating Riena rookies like myself :).
Chris
Re: How to build Riena from source? [message #586235 is a reply to message #586227] Mon, 05 July 2010 05:26 Go to previous messageGo to next message
Hi Chris,
regards
christian
> Hi Christian,
> basis.
> Chris
Re: How to build Riena from source? [message #586245 is a reply to message #544698] Mon, 05 July 2010 06:48 Go to previous message
Previous Topic:How to build Riena from source?
Next Topic:One Framework to bind them All ?!
Current Time: Thu Jul 24 23:23:25 EDT 2025
Powered by FUDForum. Page generated in 1.12204 seconds
