Required Plugins? [message #469655] |
Tue, 02 October 2007 09:20  |
Documentation for adding help to RCP still refers to requiring tomcat,
lucene, etc. What are the explicit plugins that must be in the target when
exporting an RCP?
Re: Required Plugins? [message #469657 is a reply to message #469656] |
Wed, 03 October 2007 09:26   |
Right. The dependencies are needed in the feature holding the plugin.
These used to include appserver, base, tomcat, some apache code, etc.
On 10/2/07 1:53 PM, in article fdu7jc$a8k$1@build.eclipse.org, "Jacek
Pospychala" <jacek.pospychala@pl.ibm.com> wrote:
> this recent article:
> http://www.eclipse.org/articles/article.php?file=Article-Add ingHelpToRCP/index
> .html
> notes that only required plugins are org.eclipse.help.webapp and
> org.eclipse.help.ui plus their dependencies.
>> exporting an RCP?
Re: Required Plugins? [message #469886 is a reply to message #469660] |
Fri, 12 October 2007 20:27  |
Thanks. In the past, there were eight (I think) specific plugins that were
required for help to work. Now the documentation simply refers to two, but
their dependencies have multiplied like loaves and fishes. The end result
is that it is difficult to set up a separate target platform from the
development platform.
On 10/11/07 7:42 AM, in article m3ve9dydgz.fsf@orees.hpl.hp.com, "Owen Rees"
<owen.rees@hp.com> wrote:
> Jacek Pospychala <jacek.pospychala@pl.ibm.com> writes:
>> Hi,
>> x.html
> If you are starting from the RCP SDK as the target you do not have
> those plugins or their dependencies so you have to copy them to your
> target from the platform SDK. There does not seem to be an easy way to
> find out what dependencies are missing from the target. You can go
> through the plugins one by one looking at their dependencies to see
> which are missing but it is a rather tedious process.
> It is possible to change the target to the platform SDK, do the "Add
> Required Plug-ins", save the product and then change the target back
> again. That leaves your product configuration with the missing plugins
> listed and marked as faulty so you can then copy them in one go. This
> is less tedious but does not seem to me to be an ideal way of
> addressing the issue.
Re: Required Plugins? [message #586182 is a reply to message #469656] |
> .html
>> exporting an RCP?
Re: Required Plugins? [message #586222 is a reply to message #469656] |
Thu, 11 October 2007 09:42  |
> http://www.eclipse.org/articles/article.php?file=Article-Add ingHelpToRCP/index.html
Owen Rees; speaking personally, and not on behalf of HP.
Hewlett-Packard Limited. Registered No: 690597 England
Registered Office: Cain Road, Bracknell, Berks RG12 1HN
Re: Required Plugins? [message #588590 is a reply to message #469660] |
>> Hi,
>> x.html
FUDForum. Page generated in 0.07590 seconds
