Where can I find tomcat deployment errors? [message #586054] |
Wed, 07 July 2010 11:03  |
I'm trying to deploy an application, but for some reason I'm getting this error:
> [2010-07-07 11:54:21.572] start-signalling-1 <DE0006E> Start failed for bundle 'HelloWorldJSF' version '0.0.0'. org.eclipse.virgo.kernel.deployer.core.DeploymentException: Web application failed to start
> at org.eclipse.virgo.web.core.internal.WebBundleLifecycleListen er.onStarted(WebBundleLifecycleListener.java:129)
> at org.eclipse.virgo.kernel.install.artifact.internal.ArtifactS tateMonitor.onStarted(ArtifactStateMonitor.java:205)
> at org.eclipse.virgo.kernel.install.artifact.internal.AbstractI nstallArtifact.asyncStartSucceeded(AbstractInstallArtifact.j ava:272)
> at org.eclipse.virgo.kernel.install.artifact.internal.AbstractI nstallArtifact.access$0(AbstractInstallArtifact.java:269)
> at org.eclipse.virgo.kernel.install.artifact.internal.AbstractI nstallArtifact$StateMonitorSignal.signalSuccessfulCompletion (AbstractInstallArtifact.java:222)
> at org.eclipse.virgo.kernel.core.internal.BundleStartTracker$1. run(BundleStartTracker.java:140)
> at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Threa dPoolExecutor.java:886)
> at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:908)
> at java.lang.Thread.run(Thread.java:619)
> Caused by: org.eclipse.gemini.web.core.WebApplicationStartFailedExcepti on: org.eclipse.gemini.web.core.spi.ServletContainerException: Web application at '/HelloWorldJSF' failed to start. Check the logs for more details.
> at org.eclipse.gemini.web.internal.StandardWebApplication.start (StandardWebApplication.java:107)
> at org.eclipse.virgo.web.core.internal.WebBundleLifecycleListen er.onStarted(WebBundleLifecycleListener.java:120)
> ... 8 common frames omitted
> Caused by: org.eclipse.gemini.web.core.spi.ServletContainerException: Web application at '/HelloWorldJSF' failed to start. Check the logs for more details.
> at org.eclipse.gemini.web.tomcat.internal.TomcatServletContaine r.startWebApplication(TomcatServletContainer.java:123)
> at org.eclipse.gemini.web.internal.StandardWebApplication.start (StandardWebApplication.java:90)
> ... 9 common frames omitted
Can anyone tell me where can i see these "log for more details"???
FUDForum. Page generated in 0.06137 seconds
