Home » Modeling » Epsilon » [EVL] word "model"
[EVL] word "model" [message #513452] Wed, 10 February 2010 04:53 Go to next message
Hello !
I'm using EVL to validate GMF diagrams which their metamodel root's name is "Model".
I have this constraint:
constraint UniqueName {
guard : self.satisfies('validStructuredTypeName')
check : self.model.datatype->select(p|p.isTypeOf(StructuredType))->select(s|s.Name = self.Name)->size() = 1
message : 'UDT Name should be unique'
fix{
title: self.Name + ' -> Choose other Name'
do {
self.Name :=UserInput.prompt('Choose other Name', self.Name);
Eclipse highlights "model" as a reserved word and when I validate a diagram I receive the following error:
bundleresource://781/model/ORDB4ORA.evl has one or more syntax errors :
Line: 70, Column: 22, Reason: mismatched input: '.'
Line 70 is :
Is "model" a reserved word?
In affirmative case: How do I use "model" like not-reserved word?
Álvaro Jiménez Rielo
Kybele Research Group
Rey Juan Carlos University (Madrid)
Re: [EVL] word "model" [message #513456 is a reply to message #513452] Wed, 10 February 2010 00:02 Go to previous messageGo to next message
Hi Alvaro,
Reserved words can be escaped by enclosing them into `` (e.g.
self.`model`.datatype)
Dimitris
ajimenezr wrote:
> Hello !
> is "Model". I have this constraint:
> check :
> fix{
> do {
> self.Name);
> Line 70 is :
> check :
> Is "model" a reserved word? In affirmative case: How do I use "model"
> Kybele Research Group Rey Juan Carlos University (Madrid)
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: [EVL] word "model" [message #513460 is a reply to message #513456] Wed, 10 February 2010 05:19 Go to previous messageGo to next message
Hi Dimitris,
I have tried your solution self.`model`.datatype and it hasn't worked
but I have used "reservedword" (self."model".datatype) and it works!
Thanks (one more time).
Re: [EVL] word "model" [message #513476 is a reply to message #513460] Wed, 10 February 2010 00:52 Go to previous messageGo to next message
Hi Alvaro,
Are you using the latest version of Epsilon (0.8.8)? "" was the escape
sequence until 0.8.7 but we changed this to `` so that we can use "" for
string literals (in addition to ''). You can have a look at
http://www.eclipse.org/gmt/epsilon/doc/articles/eol-syntax-u pdates/ for
more updates in the syntaxes of Epsilon languages.
Dimitris
ajimenezr wrote:
> Hi Dimitris,
Re: [EVL] word "model" [message #586024 is a reply to message #513460] Wed, 10 February 2010 05:34 Go to previous message
Hi Alvaro,
Dimitris
ajimenezr wrote:
> Hi Dimitris,
Previous Topic:[EVL] word "model"
Next Topic:attaching eugenia generated diagram with editor
Current Time: Fri Jul 25 06:17:49 EDT 2025
Powered by FUDForum. Page generated in 0.04953 seconds
