Home » Eclipse Projects » DTP » No schemas displayed when connecting to DB2 Express-C V9.1
No schemas displayed when connecting to DB2 Express-C V9.1 [message #31524] Mon, 18 June 2007 08:32 Go to next message
I am just trying the DTP, for the moment only as an alternative to the
cumbersome DB2 CC. I created a driver template using the JCC driver,
created a new "SQL Model JDBC COnnection", Ping works okay. I connect to
the DB (name of DB is "GTS") and try to browse it. However, the "tree"
ends at the "Schemas" node under the "GTS" node representing my
database. No schemas or anything else is shown (there are several
schemas in the DBMS instance, including one named GTS). "Refresh" didn't
work. I also tried different versions (including 1.0 and the latest 1.5
nightly), currently I am using
Eclipse SDK 3.3RC4
EMF/SDO/XSD 2.3.0RC3
GEF 3.3RC3
mdt-uml2 SDK 2.1RC3
Subclipse 1.2
and
DTP SDK 1.5_RC3
Any help appreciated.
JG
BTW: Postgres works (Re: No schemas displayed when connecting to DB2 Express-C V9.1) [message #31562 is a reply to message #31524] Mon, 18 June 2007 08:40 Go to previous messageGo to next message
I just tried connecting to a Postgres server, seems to work fine, so I
guess the problem is no with my DTP installation per se, or is it?
Re: No schemas displayed when connecting to DB2 Express-C V9.1 [message #31704 is a reply to message #31524] Thu, 28 June 2007 14:30 Go to previous messageGo to next message
Originally posted by: brianf.sybase.com
Hi JG...
Which driver are you using? There are multiple "enablement" plug-ins
available for DB2 variations that might help you out... They're available in
the DTP CVS repository
HEAD
org.eclipse.datatools.enablement
plugins
org.eclipse.datatools.enablement.ibm.db2.*
It appears we currently have DB2 enablement plug-ins for iseries, luw, and
zseries.
Did you try those or try to roll your own driver definition using the
Generic JDBC driver?
--Brian Fitzpatrick
"JG" <jguni@gmx.de> wrote in message news:f55u13$bl6$1@build.eclipse.org...
> Eclipse SDK 3.3RC4
> GEF 3.3RC3
> mdt-uml2 SDK 2.1RC3
> Subclipse 1.2
> and
> DTP SDK 1.5_RC3
> Regards
> JG
Re: No schemas displayed when connecting to DB2 Express-C V9.1 [message #33960 is a reply to message #31524] Fri, 03 August 2007 11:15 Go to previous message
I'm experiencing the same problem. I can connect and retrieve data but the
schema trees are blank. I don't believe it's our db because I can connect,
retrieve data, and see the schema using the same driver in Callisto, JDK
1.4, and Database Explorer. The developer next to me can connect, retrieve
data, and see the schema using the same driver in Europa with Quantum DB.
My environment:
DB2 v7 z/OS
Eclipse Europa
JDK 6
DTP 1.5
These are my 'enablement' plugins for db2
org.eclipse.datatools.enablement.ibm.db2.iseries.dbdefinitio n_1.0.0.200706071.jar
org.eclipse.datatools.enablement.ibm.db2.iseries.profile_1.0 .0.200706071.jar
org.eclipse.datatools.enablement.ibm.db2.luw.dbdefinition_1. 0.0.200706071.jar
org.eclipse.datatools.enablement.ibm.db2.luw.profile_1.0.0.2 00706071.jar
org.eclipse.datatools.enablement.ibm.db2.zseries.dbdefinitio n_1.0.0.200706071.jar
org.eclipse.datatools.enablement.ibm.db2.zseries.profile_1.0 .0.200706071.jar
Any help would be appreciated as I would rather not install Quantum DB and
it's a pain to have Callisto open to navigate the schema and then switch
back to Europa to do my development.
> Eclipse SDK 3.3RC4
> GEF 3.3RC3
> mdt-uml2 SDK 2.1RC3
> Subclipse 1.2
> and
> DTP SDK 1.5_RC3
> Regards
> JG
BTW: Postgres works (Re: No schemas displayed when connecting to DB2 Express-C V9.1) [message #585952 is a reply to message #31524] Mon, 18 June 2007 08:40 Go to previous message
Re: No schemas displayed when connecting to DB2 Express-C V9.1 [message #586017 is a reply to message #31524] Thu, 28 June 2007 14:30 Go to previous message
Hi JG...
HEAD
plugins
zseries.
--Brian Fitzpatrick
> Eclipse SDK 3.3RC4
> GEF 3.3RC3
> mdt-uml2 SDK 2.1RC3
> Subclipse 1.2
> and
> DTP SDK 1.5_RC3
> Regards
> JG
Re: No schemas displayed when connecting to DB2 Express-C V9.1 [message #587014 is a reply to message #31524] Fri, 03 August 2007 11:15 Go to previous message
My environment:
DB2 v7 z/OS
Eclipse Europa
JDK 6
DTP 1.5
> Eclipse SDK 3.3RC4
> GEF 3.3RC3
> mdt-uml2 SDK 2.1RC3
> Subclipse 1.2
> and
> DTP SDK 1.5_RC3
> Regards
> JG
Previous Topic:50 records returned
Next Topic:RoutineEditor to open different SQL Objects with same name
Current Time: Wed Jul 23 15:32:54 EDT 2025
Powered by FUDForum. Page generated in 0.10201 seconds
