Home » Eclipse Projects » DTP » ODA driver for EJB access
ODA driver for EJB access [message #29047] Sun, 08 April 2007 05:54 Go to next message
Originally posted by: ruby.boyarski.verix.com
hi,
I would like to develop an ODA driver to access EJBs.
Are there any pointers how to approach this?
Maybe someone has already developed something like that for public use?
thanks,
Ruby
Re: ODA driver for EJB access [message #29094 is a reply to message #29047] Mon, 09 April 2007 20:12 Go to previous messageGo to next message
The approach may vary depending on whether you are developing an ODA driver
from scratch, versus extending the behavior of an existing ODA driver.
If you are starting a new one, try start with the New Plug-in Project
Template Wizard provided by the ODA framework, which generates new ODA
plugin projects with stubbed source code.
The ODA Tutorial presentation material from EclipseCon2007 provides an
overall description. See link
http://eclipsezilla.eclipsecon.org/php/attachment.php?bugid= 3616
Linda
Re: ODA driver for EJB access [message #29125 is a reply to message #29094] Tue, 10 April 2007 08:50 Go to previous messageGo to next message
Thanks a lot for your answer.
I have managed to write an ODA plugin using the wizard and conenct to the
EJB.
I have two problems/additional questions you may be kind enough to answer:
1. When defining a data set on my new ODA data source I am able to preview
data (in the BIRT data set properties box (if double clicking the data set))
but when trying to preview the report with a table populated with this data
set the preview page shows as blank. As if it's stuck...
2. To override problem #1 I thought I would try previewing it in my iServer
with the iPortal. I published the report but I get the following exception
when trying to access it from the iPortal: "report generation failed. Cause:
Cannot process the verix_oda_runtime driver's configuration.
verix_oda_runtime". I guess it has got to do with the fact that I didn't
deploy the new ODA data source. How should I do that?
Ruby
"Linda Chan" <lchan@actuate.com> wrote in message
news:461AD676.30E78DE2@actuate.com...
> driver
> Linda
Re: ODA driver for EJB access [message #29239 is a reply to message #29125] Wed, 11 April 2007 00:14 Go to previous messageGo to next message
Ruby,
Was there any error in the BIRT Viewer log?
Questions on the Viewer are actually specific to BIRT, and are best posted in
the BIRT newsgroup.
Linda
> EJB.
> Cheers,
> Ruby
> > driver
> > Linda
Re: ODA driver for EJB access [message #29277 is a reply to message #29239] Wed, 11 April 2007 11:20 Go to previous messageGo to next message
Yes - See attached log.
The exception is in my code during context lookup. When running the same
code from a Main it works (with same lookup parameters).
For some reason it "thinks" that the lookup URL is
" Files/Actuate9/BRDPro/eclipse/plugins/org.eclipse.birt.repor t.viewer_2.1.2.v20061218-0710/birt/WEB-INF/classes/] "
although I haven't specified it anywhere...
Ruby
news:461C60BA.C370E227@actuate.com...
> Ruby,
> in
> the BIRT newsgroup.
> Linda
>> EJB.
>> answer:
>> preview
>> set))
>> data
>> iServer
>> exception
>> Cause:
>> Cheers,
>> Ruby
>> > driver
>> > Linda
Re: ODA driver for EJB access [message #29315 is a reply to message #29277] Wed, 11 April 2007 22:54 Go to previous messageGo to next message
This seems to be a BIRT Viewer configuration issue. It is probably similar to the problem you'd encountered when
using a scripted data source, as described in your separate thread in BIRT newsgroup.
Please post your error log there; folks there with more expertise in BIRT Viewer can provide you a better idea.
Linda
> Cheers,
> Ruby
> > Ruby,
> > in
> > the BIRT newsgroup.
> > Linda
Re: ODA driver for EJB access [message #29353 is a reply to message #29315] Thu, 12 April 2007 07:05 Go to previous message
OK. Did that.
Thanks.
news:461D9F56.E60EAE53@actuate.com...
> newsgroup.
> Linda
>> Cheers,
>> Ruby
>> > Ruby,
>> > posted
>> > in
>> > the BIRT newsgroup.
>> > Linda
Re: ODA driver for EJB access [message #585128 is a reply to message #29047] Mon, 09 April 2007 20:12 Go to previous message
Linda
Re: ODA driver for EJB access [message #585143 is a reply to message #29094] Tue, 10 April 2007 08:50 Go to previous message
EJB.
Ruby
> driver
> Linda
Re: ODA driver for EJB access [message #585174 is a reply to message #29125] Wed, 11 April 2007 00:14 Go to previous message
Ruby,
the BIRT newsgroup.
Linda
> EJB.
> Cheers,
> Ruby
> > driver
> > Linda
Re: ODA driver for EJB access [message #585189 is a reply to message #29239] Wed, 11 April 2007 11:20 Go to previous message
Ruby
> Ruby,
> in
> the BIRT newsgroup.
> Linda
>> EJB.
>> answer:
>> preview
>> set))
>> data
>> iServer
>> exception
>> Cause:
>> Cheers,
>> Ruby
>> > driver
>> > Linda
Re: ODA driver for EJB access [message #585204 is a reply to message #29277] Wed, 11 April 2007 22:54 Go to previous message
Linda
> Cheers,
> Ruby
> > Ruby,
> > in
> > the BIRT newsgroup.
> > Linda
Re: ODA driver for EJB access [message #585225 is a reply to message #29315] Thu, 12 April 2007 07:05 Go to previous message
OK. Did that.
Thanks.
> newsgroup.
> Linda
>> Cheers,
>> Ruby
>> > Ruby,
>> > posted
>> > in
>> > the BIRT newsgroup.
>> > Linda
Previous Topic:MSSQL Connectivity
Next Topic:relative location of driver JAR file
Current Time: Sat Jul 19 02:52:16 EDT 2025
Powered by FUDForum. Page generated in 0.04300 seconds
