Home » Archived » XML Schema Definition (XSD) » loading embedded schemas from wsdl
| loading embedded schemas from wsdl [message #39626] |
Wed, 24 March 2004 14:41  |
Originally posted by: cipher8000.yahoo.com
Hi Ed,
Is there any sample/test code to look at on how to load the embedded schemas
from a wsdl file.
i have a wsdl, looks like below:
<definition>
<types>
<schema targetNamespace="boo">
<complexType name="booType/>
</schema>
<schema targetNamespace="foo" xmlns:b="boo"/>
<import namespace="boo"/>
<element name="e1" type="b:booType"/>
</schema>
</types>
</definition>
"foo" schema depends on the "boo" schema.
thanks
-muruga
| Re: loading embedded schemas from wsdl [message #39685 is a reply to message #39655] |
Wed, 24 March 2004 18:02   |
Hi Ed,
Sorry. i didnt notice..i thought i sent to the news group. Here is the
problem.
here i am attaching the wsdl, i am sure i don't have any imports which
points to
invalid schema location. But i have an import without schemaLocation.
I attached the wsdl along with this email. For some reason when i tried to
load:
<schema attributeFormDefault="qualified" elementFormDefault="qualified"
targetNamespace="http://samples.cxdn.com"
xmlns="http://www.w3.org/2001/XMLSchema"
xmlns:payment="http://payment.org">
<import namespace="http://payment.org"/>
<element name="paymentRequest" type="payment:PaymentRequestType"/>
<element name="digitalReceipt" type="payment:DigitalReceiptType"/>
</schema>
i get this extra <html> resource. Do you think it is because the import
doesn't have a "schemaLocation" attribute.
thanks,
-muruga
Muruga,
It's best to ask question on the forum so that more people will benefit
from the answers.
Probably there is an import or include in one of your schemas who's that
resolves to an http address that yields the HTML you show below. You
should figure out the URI of the resource with the content you show below
and then look for an import or include with that schema location or
namespace.
Hi Ed,
Thanks for the tip.
Rightnow I am manually parsing <schema> elements and creating
XSDSchema using XSDFactory and associate that element with XSDSchema.
But after i parsed all the embedded schemas, i tried printing each one
from ResourceSet.
I get this <html> doc as extra resource into ResourceSet.
<html>
<head>
<title>Under Construction</title>
</head>
<body bgcolor="#ffffff">
<center>
<img height="35"
src="http://banners.directnic.com/construction/const_title.gif"
width="760">
<br>
<table border="0" cellpadding="0" cellspacing="0" width="436">
<tr>
<td>
<img border="0" height="1"
src="http://banners.directnic.com/construction/spacer.gif" width="171"/>
</td>
</tr>
</table>
</br>
</img>
</center>
</body>
</html>
thanks
-muruga
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:4061F8BC.E20D3E01@ca.ibm.com...
Muruga,
All you need to do is register the XSDResourceFactoryImpl to handle "wsdl"
extensions just as you do for "xsd". For the resulting "wsdl" resource,
the
getContents() will contain all the embedded <schema>s, just as the "xsd"
resource's getContents() contains a single schema for the one <schema> in
the
..xsd file.
Muruga Chinnananchi wrote:
> Hi Ed,
schemas
> from a wsdl file.
> <definition>
> <types>
> </schema>
> </schema>
> </types>
> </definition>
> thanks
> -muruga
Attachment: PayFlow.wsdl
(Size: 2.44KB, Downloaded 304 times)
| Re: loading embedded schemas from wsdl [message #39719 is a reply to message #39685] |
Wed, 24 March 2004 18:21   |
--------------05F3F97A67BA9FC3D43AED37
Content-Type: text/plain; charset=us-ascii
Muruaga,
An <import> without a schemaLocation will use the namespace as the location.
At the risk of free advertisement for http://payment.org, if you type that
into you browser, you'll see a page that not surprisingly is under
construction. ;-)
> Hi Ed,
> problem.
> points to
> load:
> </schema>
> thanks,
> -muruga
> Muruga,
> from the answers.
> namespace.
> Hi Ed,
> Thanks for the tip.
> from ResourceSet.
> <html>
> <head>
> </head>
> <center>
> <img height="35"
> width="760">
> <br>
> <tr>
> <td>
> </td>
> </tr>
> </table>
> </br>
> </img>
> </center>
> </body>
> </html>
> thanks
> -muruga
> Muruga,
> the
> the
> .xsd file.
> > Hi Ed,
> schemas
> > from a wsdl file.
> > <definition>
> > <types>
> > </schema>
> > </schema>
> > </types>
> > </definition>
> > thanks
> > -muruga
> PayFlow.wsdl Type: unspecified type (application/octet-stream)
> Encoding: x-uuencode
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Muruaga,
<p>An <import> without a schemaLocation will use the namespace as the
location.
<p>At the risk of free advertisement for <A HREF="http://payment.org">http://payment.org</A>, if you type
that into you browser, you'll see a page that not surprisingly is under
construction. ;-)
<br>
<p>Muruga Chinnananchi wrote:
<blockquote TYPE=CITE>Hi Ed,
<p>Sorry. i didnt notice..i thought i sent to the news group. Here is the
<br>problem.
<br>here i am attaching the wsdl, i am sure i don't have any imports which
<br>points to
<br>invalid schema location. But i have an import without schemaLocation.
<p>I attached the wsdl along with this email. For some reason when i tried
to
<br>load:
<p> <schema attributeFormDefault="qualified" elementFormDefault="qualified"
<br> targetNamespace="<a href="http://samples.cxdn.com">http://samples.cxdn.com</a>"
<br> xmlns="<a href="http://www.w3.org/2001/XMLSchema">http://www.w3.org/2001/XMLSchema</a>"
<br> xmlns:payment="<a href="http://payment.org">http://payment.org</a>">
<br> <import namespace="<a href="http://payment.org" /">http://payment.org"/</a>>
<br> <element name="paymentRequest"
<br> <element name="digitalReceipt"
<br> </schema>
<p>i get this extra <html> resource. Do you think it is because the
import
<br>doesn't have a "schemaLocation" attribute.
<p>thanks,
<br>-muruga
<br> ------------------------------------------------------------ -----------
<br>Muruga,
<p>It's best to ask question on the forum so that more people will benefit
<br>from the answers.
<p>Probably there is an import or include in one of your schemas who's
that
<br>resolves to an http address that yields the HTML you show below.
You
<br>should figure out the URI of the resource with the content you show
below
<br>and then look for an import or include with that schema location or
<br>namespace.
<p> ------------------------------------------------------------ -------------
<br>Hi Ed,
<p>Thanks for the tip.
<p>Rightnow I am manually parsing <schema> elements and creating
<br>XSDSchema using XSDFactory and associate that element with XSDSchema.
<p>But after i parsed all the embedded schemas, i tried printing each one
<br>from ResourceSet.
<br>I get this <html> doc as extra resource into ResourceSet.
<p><?xml version="1.0" encoding="UTF-8"?>
<br><html>
<br><head>
<br><title>Under Construction</title>
<br></head>
<br><body bgcolor="#ffffff">
<br><center>
<br> <img height="35"
<br>src="<a href="http://banners.directnic.com/construction/const_title.gif">http://banners.directnic.com/construction/const_title.gif</a>"
<br>width="760">
<br><br>
<p> <table border="0" cellpadding="0" cellspacing="0" width="436">
<br> <tr>
<br> <td>
<br><img border="0" height="1"
<br>src="<a href="http://banners.directnic.com/construction/spacer.gif">http://banners.directnic.com/construction/spacer.gif</a>"
width="171"/>
<br></td>
<br></tr>
<br></table>
<br></br>
<br></img>
<br></center>
<br></body>
<br></html>
<p>thanks
<br>-muruga
<p>"Ed Merks" <merks@ca.ibm.com> wrote in message
<br><a href="news:4061F8BC.E20D3E01@ca.ibm.com">news:4061F8BC.E20D3E01@ca.ibm.com</a>...
<br>Muruga,
<p>All you need to do is register the XSDResourceFactoryImpl to handle
"wsdl"
<br>extensions just as you do for "xsd". For the resulting
"wsdl" resource,
<br>the
<br>getContents() will contain all the embedded <schema>s, just as the
"xsd"
<br>resource's getContents() contains a single schema for the one <schema>
in
<br>the
<br>.xsd file.
<p>> Hi Ed,
<br>>
<br>> Is there any sample/test code to look at on how to load the embedded
<br>schemas
<br>> from a wsdl file.
<br>>
<br>> i have a wsdl, looks like below:
<br>>
<br>> <definition>
<br>> <types>
<br>> <schema targetNamespace="boo">
<br>>
<br>> </schema>
<br>> <schema targetNamespace="foo"
xmlns:b="boo"/>
<br>>
<br>>
<br>> </schema>
<br>> </types>
<br>> </definition>
<br>>
<br>> "foo" schema depends on the "boo" schema.
<br>>
<br>> thanks
<br>> -muruga
<p>
<br> PayFlow.wsdl Type: unspecified type
<br>
Encoding: x-uuencode</blockquote>
</html>
--------------05F3F97A67BA9FC3D43AED37--
| Re: loading embedded schemas from wsdl [message #39749 is a reply to message #39719] |
Wed, 24 March 2004 18:42   |
------=_NextPart_000_000E_01C411B6.93FFEE40
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Thanks very much Ed. Oh. Thats why i see that html page. Is there any =
workaround to solve these kind of import?
thanks,
-muruga
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:406217ED.7D8FA9EE@ca.ibm.com...
Muruaga,=20
An <import> without a schemaLocation will use the namespace as the =
location.=20
At the risk of free advertisement for http://payment.org, if you type =
that into you browser, you'll see a page that not surprisingly is under =
construction. ;-)=20
=20
Muruga Chinnananchi wrote:=20
Hi Ed,=20
Sorry. i didnt notice..i thought i sent to the news group. Here is =
the=20
problem.=20
here i am attaching the wsdl, i am sure i don't have any imports =
which=20
points to=20
invalid schema location. But i have an import without =
schemaLocation.=20
I attached the wsdl along with this email. For some reason when i =
tried to=20
load:=20
<schema attributeFormDefault=3D"qualified" =
elementFormDefault=3D"qualified"=20
targetNamespace=3D"http://samples.cxdn.com"=20
xmlns=3D"http://www.w3.org/2001/XMLSchema"=20
xmlns:payment=3D"http://payment.org">=20
<import namespace=3D"http://payment.org"/>=20
<element name=3D"paymentRequest" =
type=3D"payment:PaymentRequestType"/>=20
<element name=3D"digitalReceipt" =
type=3D"payment:DigitalReceiptType"/>=20
</schema>=20
i get this extra <html> resource. Do you think it is because the =
import=20
doesn't have a "schemaLocation" attribute.=20
thanks,=20
-muruga=20
------------------------------------------------------------ -----------=20
Muruga,=20
It's best to ask question on the forum so that more people will =
benefit=20
from the answers.=20
Probably there is an import or include in one of your schemas who's =
that=20
resolves to an http address that yields the HTML you show below. =
You=20
should figure out the URI of the resource with the content you show =
below=20
and then look for an import or include with that schema location or=20
namespace.=20
=20
Hi Ed,=20
Thanks for the tip.=20
Rightnow I am manually parsing <schema> elements and creating=20
XSDSchema using XSDFactory and associate that element with =
XSDSchema.=20
But after i parsed all the embedded schemas, i tried printing each =
one=20
from ResourceSet.=20
I get this <html> doc as extra resource into ResourceSet.=20
<?xml version=3D"1.0" encoding=3D"UTF-8"?>=20
<html>=20
<head>=20
<title>Under Construction</title>=20
</head>=20
<body bgcolor=3D"#ffffff">=20
<center>=20
<img height=3D"35"=20
src=3D"http://banners.directnic.com/construction/const_title.gif"=20
width=3D"760">=20
<br>=20
<table border=3D"0" cellpadding=3D"0" cellspacing=3D"0" =
width=3D"436">=20
<tr>=20
<td>=20
<img border=3D"0" height=3D"1"=20
src=3D"http://banners.directnic.com/construction/spacer.gif" =
width=3D"171"/>=20
</td>=20
</tr>=20
</table>=20
</br>=20
</img>=20
</center>=20
</body>=20
</html>=20
thanks=20
-muruga=20
"Ed Merks" <merks@ca.ibm.com> wrote in message=20
news:4061F8BC.E20D3E01@ca.ibm.com...=20
Muruga,=20
All you need to do is register the XSDResourceFactoryImpl to handle =
"wsdl"=20
extensions just as you do for "xsd". For the resulting "wsdl" =
resource,=20
the=20
getContents() will contain all the embedded <schema>s, just as the =
"xsd"=20
resource's getContents() contains a single schema for the one =
<schema> in=20
the=20
.xsd file.=20
> Hi Ed,=20
>=20
> Is there any sample/test code to look at on how to load the =
embedded=20
schemas=20
> from a wsdl file.=20
>=20
> i have a wsdl, looks like below:=20
>=20
> <definition>=20
> <types>=20
> <schema targetNamespace=3D"boo">=20
> <complexType name=3D"booType/>=20
> </schema>=20
> <schema targetNamespace=3D"foo" xmlns:b=3D"boo"/>=20
> <import namespace=3D"boo"/>=20
> <element name=3D"e1" type=3D"b:booType"/>=20
> </schema>=20
> </types>=20
> </definition>=20
>=20
> "foo" schema depends on the "boo" schema.=20
>=20
> thanks=20
> -muruga=20
PayFlow.wsdl Type: unspecified type (application/octet-stream) =
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1400" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Thanks very much Ed. Oh. Thats =
why i see that=20
html page. Is there any workaround to solve these kind of =
import?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>thanks,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>-muruga</FONT></DIV>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
wrote in message <A=20
href=3D"news:406217ED.7D8FA9EE@ca.ibm.com">news:406217ED.7D8FA9EE@ca.ibm.=
com</A>...</DIV>Muruaga,=20
<P>An <import> without a schemaLocation will use the namespace =
as the=20
location.=20
<P>At the risk of free advertisement for <A=20
href=3D"http://payment.org">http://payment.org</A>, if you type that =
into you=20
<BR> =20
<P>Muruga Chinnananchi wrote:=20
<BLOCKQUOTE TYPE=3D"CITE">Hi Ed,=20
<P>Sorry. i didnt notice..i thought i sent to the news group. Here =
is the=20
<BR>problem. <BR>here i am attaching the wsdl, i am sure i don't =
have any=20
imports which <BR>points to <BR>invalid schema location. But i have =
an=20
import without schemaLocation.=20
<P>I attached the wsdl along with this email. For some reason when i =
tried=20
to <BR>load:=20
<P> <schema attributeFormDefault=3D"qualified"=20
elementFormDefault=3D"qualified" <BR> =20
targetNamespace=3D"<A=20
href=3D"http://samples.cxdn.com">http://samples.cxdn.com</A>"=20
<BR> xmlns=3D"<A=20
href=3D"http://www.w3.org/2001/XMLSchema">http://www.w3.org/2001/XMLSchem=
a</A>"=20
<BR> xmlns:payment=3D"<A=20
href=3D"http://payment.org">http://payment.org</A>">=20
<BR> <import =
namespace=3D"<A=20
href=3D"http://payment.org" ?>http://payment.org"/</A>>=20
<BR> <element=20
name=3D"paymentRequest" type=3D"payment:PaymentRequestType"/>=20
<BR> <element=20
name=3D"digitalReceipt" type=3D"payment:DigitalReceiptType"/>=20
<BR> </schema>=20
<P>i get this extra <html> resource. Do you think it is =
because the=20
import <BR>doesn't have a "schemaLocation" attribute.=20
<P>thanks, <BR>-muruga=20
<BR> ------------------------------------------------------------ ---------=
--=20
<BR>Muruga,=20
<P>It's best to ask question on the forum so that more people will =
benefit=20
<BR>from the answers.=20
<P>Probably there is an import or include in one of your schemas =
who's that=20
<BR>resolves to an http address that yields the HTML you show =
below. =20
You <BR>should figure out the URI of the resource with the content =
you show=20
below <BR>and then look for an import or include with that schema =
location=20
or <BR>namespace.=20
<P> ------------------------------------------------------------ ----------=
---=20
<BR>Hi Ed,=20
<P>Thanks for the tip.=20
<P>Rightnow I am manually parsing <schema> elements and =
creating=20
<BR>XSDSchema using XSDFactory and associate that element with =
XSDSchema.=20
<P>But after i parsed all the embedded schemas, i tried printing =
each one=20
<BR>from ResourceSet. <BR>I get this <html> doc as extra =
resource into=20
ResourceSet.=20
<P><?xml version=3D"1.0" encoding=3D"UTF-8"?> <BR><html> =
<BR><head> <BR><title>Under Construction</title>=20
<BR></head> <BR><body bgcolor=3D"#ffffff"> =
<BR><center>=20
<BR> <img height=3D"35" <BR>src=3D"<A=20
href=3D"http://banners.directnic.com/construction/const_title.gif">http:/=
/banners.directnic.com/construction/const_title.gif</A>"=20
<BR>width=3D"760"> <BR><br>=20
<P> <table border=3D"0" cellpadding=3D"0" cellspacing=3D"0" =
width=3D"436"> <BR> <tr>=20
<BR> <td> <BR><img =
border=3D"0"=20
height=3D"1" <BR>src=3D"<A=20
href=3D"http://banners.directnic.com/construction/spacer.gif">http://bann=
ers.directnic.com/construction/spacer.gif</A>"=20
width=3D"171"/> <BR></td> <BR></tr> =
<BR></table>=20
<BR></br> <BR></img> <BR></center> =
<BR></body>=20
<BR></html>=20
<P>thanks <BR>-muruga=20
<P>"Ed Merks" <merks@ca.ibm.com> wrote in message <BR><A=20
href=3D"news:4061F8BC.E20D3E01@ca.ibm.com">news:4061F8BC.E20D3E01@ca.ibm.=
com</A>...=20
<BR>Muruga,=20
<P>All you need to do is register the XSDResourceFactoryImpl to =
handle=20
"wsdl" <BR>extensions just as you do for "xsd". For the=20
resulting "wsdl" resource, <BR>the <BR>getContents() will contain =
all the=20
embedded <schema>s, just as the "xsd" <BR>resource's =
getContents()=20
contains a single schema for the one <schema> in <BR>the =
<BR>.xsd=20
file.=20
<P>> Hi Ed, <BR>> <BR>> Is there any sample/test code to =
look at on=20
how to load the embedded <BR>schemas <BR>> from a wsdl file. =
<BR>>=20
<BR>> i have a wsdl, looks like below: <BR>> <BR>>=20
<definition> <BR>> <types>=20
<BR> > &a mp;nbsp; <schema=20
<BR> > &a mp;nbsp;  =
; =20
<BR> > &a mp;nbsp; =20
</schema> =
; =20
;=20
</schema>=20
<BR>> </types> <BR>> =
</definition>=20
<BR>> <BR>> "foo" schema depends on the "boo" schema. <BR>> =
<BR>> thanks <BR>> -muruga=20
<P> &nbs=
p; &nbs p;=20
Name: PayFlow.wsdl <BR> PayFlow.wsdl =
Type:=20
unspecified type (application/octet-stream)=20
<BR> &nb=
sp; =20
Encoding: x-uuencode</P></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_000E_01C411B6.93FFEE40--
| Re: loading embedded schemas from wsdl [message #39842 is a reply to message #39749] |
Thu, 25 March 2004 06:40   |
--------------98B2494BC23E9CCC0C82ABE7
Muruga,
You could specify a schemaLocation in the <import> or you could use the
ResourceSet's URIConverter's URIMap to map the namespace to the physical
location of the schema.
> workaround to solve these kind of import? thanks,-muruga
> news:406217ED.7D8FA9EE@ca.ibm.com...Muruaga,
> as the location.
> you type that into you browser, you'll see a page that not
> surprisingly is under construction. ;-)
> > Hi Ed,
> > Here is the
> > problem.
> > imports which
> > points to
> > schemaLocation.
> > when i tried to
> > load:
> > </schema>
> > because the import
> > thanks,
> > -muruga
> > Muruga,
> > will benefit
> > from the answers.
> > schemas who's that
> > below. You
> > you show below
> > location or
> > namespace.
> > Hi Ed,
> > Thanks for the tip.
> > creating
> > XSDSchema.
> > printing each one
> > from ResourceSet.
> > <html>
> > <head>
> > </head>
> > <center>
> > <img height="35"
> > width="760">
> > <br>
> > width="436">
> > <tr>
> > <td>
> > width="171"/>
> > </td>
> > </tr>
> > </table>
> > </br>
> > </img>
> > </center>
> > </body>
> > </html>
> > thanks
> > -muruga
> > Muruga,
> > to handle "wsdl"
> > "wsdl" resource,
> > the
> > just as the "xsd"
> > one <schema> in
> > the
> > .xsd file.
> > > Hi Ed,
> > the embedded
> > schemas
> > > from a wsdl file.
> > > <definition>
> > > <types>
> > > </schema>
> > > </schema>
> > > </types>
> > > </definition>
> > > thanks
> > > -muruga
<html>
<body bgcolor="#FFFFFF">
Muruga,
<p>You could specify a schemaLocation in the <import> or you could use
the ResourceSet's URIConverter's URIMap to map the namespace to the physical
<br>
<blockquote TYPE=CITE><style></style>
<font face="Arial"><font size=-1>Thanks
very much Ed. Oh. Thats why i see that html page. Is there any workaround
to solve these kind of import?</font></font> <font face="Arial"><font size=-1>thanks,</font></font><font face="Arial"><font size=-1>-muruga</font></font>
<blockquote dir=ltr
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">"Ed
Merks" <<a href="mailto:merks@ca.ibm.com">merks@ca.ibm.com</a>> wrote
in message <a href="news:406217ED.7D8FA9EE@ca.ibm.com">news:406217ED.7D8FA9EE@ca.ibm.com</a>...Muruaga,
location.
<p>At the risk of free advertisement for <a href="http://payment.org">http://payment.org</a>,
if you type that into you browser, you'll see a page that not surprisingly
<br>
<blockquote TYPE="CITE">Hi Ed,
<br>problem.
<br>points to
to
<br>load:
<br> <import namespace="<a href="http://payment.org" ?>http://payment.org"/</a>>
<br> </schema>
import
<p>thanks,
<br>-muruga
<br>Muruga,
that
You
below
<br>namespace.
<br>Hi Ed,
<br><html>
<br><head>
<br></head>
<br><center>
<br>width="760">
<br><br>
<br> <tr>
<br> <td>
width="171"/>
<br></td>
<br></tr>
<br></table>
<br></br>
<br></img>
<br></center>
<br></body>
<br></html>
<p>thanks
<br>-muruga
<br>Muruga,
"wsdl"
"wsdl" resource,
<br>the
"xsd"
in
<br>the
<br>.xsd file.
<p>> Hi Ed,
<br>>
<br>schemas
<br>>
<br>>
<br>> <definition>
<br>> <types>
<br>>
<br>> </schema>
xmlns:b="boo"/>
<br>>
<br>>
<br>> </schema>
<br>> </types>
<br>> </definition>
<br>>
<br>>
<br>> thanks
<br>> -muruga
<p>
<br>
</blockquote>
</blockquote>
</body>
</html>
--------------98B2494BC23E9CCC0C82ABE7--
| Re: loading embedded schemas from wsdl [message #39873 is a reply to message #39842] |
Thu, 25 March 2004 17:40   |
------=_NextPart_000_0009_01C41277.1BECABC0
Ed,
Thanks for the hint. Can i associate the same schemaLocation (the wsdl =
location) for the two embedded schemas defined in one wsdl.
thanks
-muruga
news:4062C53B.E3744A6D@ca.ibm.com...
Muruga,=20
You could specify a schemaLocation in the <import> or you could use =
the ResourceSet's URIConverter's URIMap to map the namespace to the =
physical location of the schema.=20
=20
Thanks very much Ed. Oh. Thats why i see that html page. Is there =
any workaround to solve these kind of import? thanks,-muruga=20
news:406217ED.7D8FA9EE@ca.ibm.com...Muruaga,=20
location.=20
At the risk of free advertisement for http://payment.org, if you =
type that into you browser, you'll see a page that not surprisingly is =
under construction. ;-)=20
=20
Hi Ed,=20
is the=20
problem.=20
which=20
points to=20
schemaLocation.=20
I attached the wsdl along with this email. For some reason when =
i tried to=20
load:=20
</schema>=20
import=20
thanks,=20
-muruga=20
Muruga,=20
benefit=20
who's that=20
You=20
should figure out the URI of the resource with the content you =
show below=20
and then look for an import or include with that schema location =
or=20
namespace.=20
=20
Hi Ed,=20
XSDSchema.=20
each one=20
<html>=20
<head>=20
</head>=20
<center>=20
width=3D"760">=20
<br>=20
width=3D"436">=20
<tr>=20
<td>=20
width=3D"171"/>=20
</td>=20
</tr>=20
</table>=20
</br>=20
</img>=20
</center>=20
</body>=20
</html>=20
thanks=20
-muruga=20
Muruga,=20
handle "wsdl"=20
resource,=20
the=20
getContents() will contain all the embedded <schema>s, just as =
the "xsd"=20
<schema> in=20
the=20
.xsd file.=20
> Hi Ed,=20
>=20
embedded=20
schemas=20
>=20
>=20
> <definition>=20
> <types>=20
> </schema>=20
> </schema>=20
> </types>=20
> </definition>=20
>=20
>=20
> thanks=20
> -muruga=20
PayFlow.wsdl Type: unspecified type =
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2800.1400" name=3DGENERATOR></HEAD>
<DIV><FONT face=3DArial size=3D2>Ed,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks for the hint. Can i =
associate the same=20
schemaLocation (the wsdl location) for the two embedded schemas defined =
in one=20
wsdl.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>thanks</FONT></DIV>
href=3D"news:4062C53B.E3744A6D@ca.ibm.com">news:4062C53B.E3744A6D@ca.ibm.=
com</A>...</DIV>Muruga,=20
<P>You could specify a schemaLocation in the <import> or you =
could use=20
physical=20
location of the schema. <BR> =20
<STYLE></STYLE>
<FONT face=3DArial><FONT size=3D-1>Thanks very much Ed. Oh. =
Thats why i=20
see that html page. Is there any workaround to solve these kind of=20
import?</FONT></FONT> <FONT face=3DArial><FONT=20
size=3D-1>thanks,</FONT></FONT><FONT face=3DArial><FONT=20
size=3D-1>-muruga</FONT></FONT>=20
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">"Ed=20
Merks" <<A =
com</A>...Muruaga,=20
<P>An <import> without a schemaLocation will use the =
namespace as=20
the location.=20
href=3D"http://payment.org">http://payment.org</A>, if you type =
that into=20
you browser, you'll see a page that not surprisingly is under=20
construction. ;-) <BR> =20
<P>Sorry. i didnt notice..i thought i sent to the news group. =
Here is=20
the <BR>problem. <BR>here i am attaching the wsdl, i am sure i =
don't=20
have any imports which <BR>points to <BR>invalid schema =
location. But i=20
have an import without schemaLocation.=20
<P>I attached the wsdl along with this email. For some reason =
when i=20
tried to <BR>load:=20
elementFormDefault=3D"qualified" =
<BR> =20
<BR> xmlns=3D"<A=20
a</A>"=20
<BR> <import =
namespace=3D"<A=20
<BR> <element=20
name=3D"paymentRequest" type=3D"payment:PaymentRequestType"/> =
<BR> <element=20
name=3D"digitalReceipt" type=3D"payment:DigitalReceiptType"/> =
<BR> </schema>=20
because=20
the import <BR>doesn't have a "schemaLocation" attribute.=20
--=20
<BR>Muruga,=20
<P>It's best to ask question on the forum so that more people =
will=20
benefit <BR>from the answers.=20
who's=20
that <BR>resolves to an http address that yields the HTML you =
show=20
below. You <BR>should figure out the URI of the resource =
with the=20
content you show below <BR>and then look for an import or =
include with=20
that schema location or <BR>namespace.=20
---=20
<BR>Hi Ed,=20
creating=20
<BR>XSDSchema using XSDFactory and associate that element with=20
XSDSchema.=20
each=20
one <BR>from ResourceSet. <BR>I get this <html> doc as =
extra=20
<P><?xml version=3D"1.0" encoding=3D"UTF-8"?> =
<BR><html>=20
<BR><head> <BR><title>Under =
<BR><center>=20
<P> <table border=3D"0" cellpadding=3D"0" =
cellspacing=3D"0"=20
border=3D"0"=20
<BR></table>=20
<BR></body>=20
<BR></html>=20
com</A>...=20
<BR>Muruga,=20
handle=20
"wsdl" <BR>extensions just as you do for "xsd". For =
the=20
resulting "wsdl" resource, <BR>the <BR>getContents() will =
contain all=20
the embedded <schema>s, just as the "xsd" <BR>resource's=20
<schema> in=20
<BR>the <BR>.xsd file.=20
<P>> Hi Ed, <BR>> <BR>> Is there any sample/test code =
to look=20
at on how to load the embedded <BR>schemas <BR>> from a wsdl =
file.=20
<BR>> <BR>> i have a wsdl, looks like below: <BR>> =
<BR>>=20
<schema=20
; =20
</schema> =
; =20
;=20
</schema>=20
</definition>=20
<BR>> <BR>> "foo" schema depends on the "boo" schema. =
<BR>>=20
<P> &nbs=
p; &nbs p;=20
Name: PayFlow.wsdl <BR> =
PayFlow.wsdl Type:=20
<BR> &nb=
sp; =20
Encoding:=20
x-uuencode</P></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE ></BODY>=
</HTML>
------=_NextPart_000_0009_01C41277.1BECABC0--
| Re: loading embedded schemas from wsdl [message #39937 is a reply to message #39873] |
Fri, 26 March 2004 06:09   |
--------------3753996ABFECBD8257B041E7
Muruga,
If you are asking whether XSDSchema.getSchemaLocation() can be set to
the same location of the .wsdl for all the schemas in one .wsdl, the
answer is yes.
> Ed, Thanks for the hint. Can i associate the same schemaLocation (the
> wsdl location) for the two embedded schemas defined in one
> wsdl. thanks-muruga
> news:4062C53B.E3744A6D@ca.ibm.com...Muruga,
> could use the ResourceSet's URIConverter's URIMap to map the
> namespace to the physical location of the schema.
> > Is there any workaround to solve these kind of import?
> > thanks,-muruga
> > http://payment.org, if you type that into you
> > > Hi Ed,
> > > problem.
> > > points to
> > > load:
> > > <import
> > > </schema>
> > > thanks,
> > > -muruga
> > > Muruga,
> > > from the answers.
> > > namespace.
> > > Hi Ed,
> > > Thanks for the tip.
> > > from ResourceSet.
> > > ResourceSet.
> > > <html>
> > > <head>
> > > </head>
> > > <center>
> > > <img height="35"
> > > width="760">
> > > <br>
> > > <tr>
> > > <td>
> > > width="171"/>
> > > </td>
> > > </tr>
> > > </table>
> > > </br>
> > > </img>
> > > </center>
> > > </body>
> > > </html>
> > > thanks
> > > -muruga
> > > Muruga,
> > > the
> > > the
> > > .xsd file.
> > > > Hi Ed,
> > > schemas
> > > > from a wsdl file.
> > > > <definition>
> > > > <types>
> > > > </schema>
> > > xmlns:b="boo"/>
> > > > <element name="e1"
> > > type="b:booType"/>
> > > > </schema>
> > > > </types>
> > > > </definition>
> > > > thanks
> > > > -muruga
<html>
Muruga,
<p>If you are asking whether XSDSchema.getSchemaLocation() can be set to
the same location of the .wsdl for all the schemas in one .wsdl, the answer
is yes.
<br>
<blockquote TYPE=CITE> <font face="Arial"><font size=-1>Ed,</font></font> <font face="Arial"><font size=-1>Thanks
for the hint. Can i associate the same schemaLocation (the wsdl location)
for the two embedded schemas defined in one wsdl.</font></font> <font face="Arial"><font size=-1>thanks</font></font><font face="Arial"><font size=-1>-muruga</font></font>
<blockquote dir=ltr
in message <a href="news:4062C53B.E3744A6D@ca.ibm.com">news:4062C53B.E3744A6D@ca.ibm.com</a>...Muruga,
<br>
<blockquote TYPE="CITE"><style></style>
to solve these kind of import?</font></font> <font face="Arial"><font size=-1>thanks,-muruga</font></font>
<blockquote dir=ltr
location.
<br>
<br>problem.
<br>points to
to
<br>load:
<br> </schema>
import
<p>thanks,
<br>-muruga
<br>Muruga,
that
You
below
<br>namespace.
<br>Hi Ed,
<br><html>
<br><head>
<br></head>
<br><center>
<br>width="760">
<br><br>
<br> <tr>
<br> <td>
width="171"/>
<br></td>
<br></tr>
<br></table>
<br></br>
<br></img>
<br></center>
<br></body>
<br></html>
<p>thanks
<br>-muruga
<br>Muruga,
"wsdl"
"wsdl" resource,
<br>the
"xsd"
in
<br>the
<br>.xsd file.
<p>> Hi Ed,
<br>>
<br>schemas
<br>>
<br>>
<br>> <definition>
<br>> <types>
<br>>
<br>> </schema>
xmlns:b="boo"/>
<br>>
<br>>
<br>> </schema>
<br>> </types>
<br>> </definition>
<br>>
<br>>
<br>> thanks
<br>> -muruga
<p>
<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</body>
</html>
--------------3753996ABFECBD8257B041E7--
| Re: loading embedded schemas from wsdl [message #40006 is a reply to message #39937] |
Fri, 26 March 2004 16:58  |
------=_NextPart_000_000F_01C4133A.6821E820
Hi Ed,
Thanks very much. It works now. I don't see any html xsd resources in =
the ResourceSet.=20
-Muruga
news:40640F55.6EDF90CC@ca.ibm.com...
Muruga,=20
If you are asking whether XSDSchema.getSchemaLocation() can be set to =
the same location of the .wsdl for all the schemas in one .wsdl, the =
answer is yes.=20
=20
Ed, Thanks for the hint. Can i associate the same schemaLocation =
(the wsdl location) for the two embedded schemas defined in one wsdl. =
thanks-muruga=20
news:4062C53B.E3744A6D@ca.ibm.com...Muruga,=20
You could specify a schemaLocation in the <import> or you could =
use the ResourceSet's URIConverter's URIMap to map the namespace to the =
=20
Thanks very much Ed. Oh. Thats why i see that html page. Is =
there any workaround to solve these kind of import? thanks,-muruga=20
An <import> without a schemaLocation will use the namespace as =
the location.=20
At the risk of free advertisement for http://payment.org, if =
you type that into you browser, you'll see a page that not surprisingly =
is under construction. ;-)=20
=20
Hi Ed,=20
Here is the=20
problem.=20
here i am attaching the wsdl, i am sure i don't have any =
imports which=20
points to=20
schemaLocation.=20
when i tried to=20
load:=20
</schema>=20
i get this extra <html> resource. Do you think it is because =
the import=20
thanks,=20
-muruga=20
Muruga,=20
will benefit=20
Probably there is an import or include in one of your =
schemas who's that=20
below. You=20
you show below=20
location or=20
namespace.=20
=20
Hi Ed,=20
creating=20
XSDSchema.=20
But after i parsed all the embedded schemas, i tried =
printing each one=20
<html>=20
<head>=20
</head>=20
<center>=20
width=3D"760">=20
<br>=20
width=3D"436">=20
<tr>=20
<td>=20
width=3D"171"/>=20
</td>=20
</tr>=20
</table>=20
</br>=20
</img>=20
</center>=20
</body>=20
</html>=20
thanks=20
-muruga=20
Muruga,=20
handle "wsdl"=20
extensions just as you do for "xsd". For the resulting =
"wsdl" resource,=20
the=20
getContents() will contain all the embedded <schema>s, just =
as the "xsd"=20
resource's getContents() contains a single schema for the =
one <schema> in=20
the=20
.xsd file.=20
> Hi Ed,=20
>=20
> Is there any sample/test code to look at on how to load =
the embedded=20
schemas=20
>=20
>=20
> <definition>=20
> <types>=20
> </schema>=20
> </schema>=20
> </types>=20
> </definition>=20
>=20
>=20
> thanks=20
> -muruga=20
<HTML><HEAD>
<DIV><FONT face=3DArial size=3D2>Hi Ed,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks very much. It works now. I don't =
see any=20
html xsd resources in the ResourceSet. </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>-Muruga</FONT></DIV>
href=3D"news:40640F55.6EDF90CC@ca.ibm.com">news:40640F55.6EDF90CC@ca.ibm.=
<P>If you are asking whether XSDSchema.getSchemaLocation() can be set =
to the=20
answer is=20
yes. <BR> =20
<BLOCKQUOTE TYPE=3D"CITE"> <FONT face=3DArial><FONT=20
size=3D-1>Ed,</FONT></FONT> <FONT face=3DArial><FONT =
size=3D-1>Thanks for the=20
hint. Can i associate the same schemaLocation (the wsdl location) =
for the=20
two embedded schemas defined in one wsdl.</FONT></FONT> <FONT=20
face=3DArial><FONT size=3D-1>thanks</FONT></FONT><FONT =
Merks" <<A =
com</A>...Muruga,=20
could=20
use the ResourceSet's URIConverter's URIMap to map the namespace =
to the=20
physical location of the schema. <BR> =20
<STYLE></STYLE>
<FONT face=3DArial><FONT size=3D-1>Thanks very much Ed. =
Oh. Thats why=20
i see that html page. Is there any workaround to solve these =
kind of=20
size=3D-1>thanks,-muruga</FONT></FONT>=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: =
5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">"Ed=20
Merks" <<A =
namespace=20
as the location.=20
href=3D"http://payment.org">http://payment.org</A>, if you =
type that=20
under=20
<P>Sorry. i didnt notice..i thought i sent to the news =
group. Here=20
is the <BR>problem. <BR>here i am attaching the wsdl, i am =
sure i=20
don't have any imports which <BR>points to <BR>invalid =
schema=20
location. But i have an import without schemaLocation.=20
<P>I attached the wsdl along with this email. For some =
reason when i=20
<BR> =20
<BR> xmlns=3D"<A=20
a</A>"=20
<BR> <import=20
namespace=3D"<A href=3D"http://payment.org"=20
<BR> <element=20
<BR> <element=20
<BR> </schema>=20
<P>i get this extra <html> resource. Do you think it =
is=20
because the import <BR>doesn't have a "schemaLocation" =
attribute.=20
--=20
<BR>Muruga,=20
<P>It's best to ask question on the forum so that more =
people will=20
<P>Probably there is an import or include in one of your =
schemas=20
who's that <BR>resolves to an http address that yields the =
HTML you=20
show below. You <BR>should figure out the URI of the =
resource=20
with the content you show below <BR>and then look for an =
import or=20
include with that schema location or <BR>namespace.=20
---=20
<BR>Hi Ed,=20
<P>Rightnow I am manually parsing <schema> elements =
and=20
creating <BR>XSDSchema using XSDFactory and associate that =
element=20
with XSDSchema.=20
<P>But after i parsed all the embedded schemas, i tried =
printing=20
each one <BR>from ResourceSet. <BR>I get this <html> =
doc as=20
<BR><html>=20
<BR></head> <BR><body bgcolor=3D"#ffffff">=20
<BR><center> <BR> <img height=3D"35" =
<BR>src=3D"<A=20
border=3D"0"=20
<BR></table>=20
<BR></br> <BR></img> <BR></center>=20
<BR></body> <BR></html>=20
<P>"Ed Merks" <merks@ca.ibm.com> wrote in message =
<BR><A=20
com</A>...=20
<BR>Muruga,=20
<P>All you need to do is register the XSDResourceFactoryImpl =
to=20
handle "wsdl" <BR>extensions just as you do for =
"xsd". =20
For the resulting "wsdl" resource, <BR>the <BR>getContents() =
will=20
contain all the embedded <schema>s, just as the "xsd"=20
<BR>resource's getContents() contains a single schema for =
the one=20
<schema> in <BR>the <BR>.xsd file.=20
<P>> Hi Ed, <BR>> <BR>> Is there any sample/test =
code to=20
look at on how to load the embedded <BR>schemas <BR>> =
from a wsdl=20
file. <BR>> <BR>> i have a wsdl, looks like below: =
<BR>>=20
<BR>> <definition> <BR>> =
<types>=20
<schema=20
; =20
</schema>=20
<schema=20
; =20
;=20
</schema> <BR>> </types> =
<BR>>=20
</definition> <BR>> <BR>> "foo" schema depends =
on the=20
"boo" schema. <BR>> <BR>> thanks <BR>> -muruga=20
<P> &nbs=
p; &nbs p;=20
PayFlow.wsdl =20
Type: unspecified type (application/octet-stream)=20
<BR> &nb=
sp; =20
Encoding:=20
x-uuencode</P></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE ></BLOCK=
------=_NextPart_000_000F_01C4133A.6821E820--
| Re: loading embedded schemas from wsdl [message #584634 is a reply to message #39626] |
Wed, 24 March 2004 16:08  |
Muruga,
extensions just as you do for "xsd". For the resulting "wsdl" resource, the
resource's getContents() contains a single schema for the one <schema> in the
..xsd file.
> Hi Ed,
> from a wsdl file.
> <definition>
> <types>
> </schema>
> </schema>
> </types>
> </definition>
> thanks
> -muruga
| Re: loading embedded schemas from wsdl [message #584653 is a reply to message #39655] |
Hi Ed,
problem.
points to
load:
</schema>
thanks,
-muruga
Muruga,
from the answers.
namespace.
Hi Ed,
Thanks for the tip.
from ResourceSet.
<html>
<head>
</head>
<center>
<img height="35"
width="760">
<br>
<tr>
<td>
</td>
</tr>
</table>
</br>
</img>
</center>
</body>
</html>
thanks
-muruga
Muruga,
the
the
..xsd file.
> Hi Ed,
schemas
> from a wsdl file.
> <definition>
> <types>
> </schema>
> </schema>
> </types>
> </definition>
> thanks
> -muruga
(Size: 2.44KB, Downloaded 222 times)
| Re: loading embedded schemas from wsdl [message #584669 is a reply to message #39685] |
Muruaga,
construction. ;-)
> Hi Ed,
> problem.
> points to
> load:
> </schema>
> thanks,
> -muruga
> Muruga,
> from the answers.
> namespace.
> Hi Ed,
> Thanks for the tip.
> from ResourceSet.
> <html>
> <head>
> </head>
> <center>
> <img height="35"
> width="760">
> <br>
> <tr>
> <td>
> </td>
> </tr>
> </table>
> </br>
> </img>
> </center>
> </body>
> </html>
> thanks
> -muruga
> Muruga,
> the
> the
> .xsd file.
> > Hi Ed,
> schemas
> > from a wsdl file.
> > <definition>
> > <types>
> > </schema>
> > </schema>
> > </types>
> > </definition>
> > thanks
> > -muruga
<html>
Muruaga,
location.
construction. ;-)
<br>
<br>problem.
<br>points to
to
<br>load:
<br> </schema>
import
<p>thanks,
<br>-muruga
<br>Muruga,
that
You
below
<br>namespace.
<br>Hi Ed,
<br><html>
<br><head>
<br></head>
<br><center>
<br>width="760">
<br><br>
<br> <tr>
<br> <td>
width="171"/>
<br></td>
<br></tr>
<br></table>
<br></br>
<br></img>
<br></center>
<br></body>
<br></html>
<p>thanks
<br>-muruga
<br>Muruga,
"wsdl"
"wsdl" resource,
<br>the
"xsd"
in
<br>the
<br>.xsd file.
<p>> Hi Ed,
<br>>
<br>schemas
<br>>
<br>>
<br>> <definition>
<br>> <types>
<br>>
<br>> </schema>
xmlns:b="boo"/>
<br>>
<br>>
<br>> </schema>
<br>> </types>
<br>> </definition>
<br>>
<br>>
<br>> thanks
<br>> -muruga
<p>
<br>
</html>
| Re: loading embedded schemas from wsdl [message #584685 is a reply to message #39719] |
thanks,
-muruga
Muruaga,=20
location.=20
=20
Hi Ed,=20
the=20
problem.=20
which=20
points to=20
schemaLocation.=20
tried to=20
load:=20
</schema>=20
import=20
thanks,=20
-muruga=20
Muruga,=20
benefit=20
that=20
You=20
below=20
namespace.=20
=20
Hi Ed,=20
XSDSchema.=20
one=20
<html>=20
<head>=20
</head>=20
<center>=20
width=3D"760">=20
<br>=20
width=3D"436">=20
<tr>=20
<td>=20
width=3D"171"/>=20
</td>=20
</tr>=20
</table>=20
</br>=20
</img>=20
</center>=20
</body>=20
</html>=20
thanks=20
-muruga=20
Muruga,=20
"wsdl"=20
resource,=20
the=20
"xsd"=20
<schema> in=20
the=20
.xsd file.=20
> Hi Ed,=20
>=20
embedded=20
schemas=20
>=20
>=20
> <definition>=20
> <types>=20
> </schema>=20
> </schema>=20
> </types>=20
> </definition>=20
>=20
>=20
> thanks=20
> -muruga=20
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
why i see that=20
as the=20
location.=20
into you=20
<BR> =20
is the=20
have any=20
an=20
tried=20
to <BR>load:=20
<BR> xmlns=3D"<A=20
a</A>"=20
<BR> <import =
namespace=3D"<A=20
<BR> <element=20
<BR> <element=20
<BR> </schema>=20
because the=20
--=20
<BR>Muruga,=20
benefit=20
who's that=20
below. =20
you show=20
location=20
---=20
<BR>Hi Ed,=20
creating=20
XSDSchema.=20
each one=20
resource into=20
ResourceSet.=20
<BR><center>=20
border=3D"0"=20
<BR></table>=20
<BR></body>=20
<BR></html>=20
com</A>...=20
<BR>Muruga,=20
handle=20
all the=20
getContents()=20
<BR>.xsd=20
file.=20
look at on=20
<BR>>=20
; =20
</schema> =
; =20
;=20
</schema>=20
</definition>=20
<P> &nbs=
p; &nbs p;=20
Type:=20
<BR> &nb=
sp; =20
| Re: loading embedded schemas from wsdl [message #584746 is a reply to message #39749] |
Muruga,
> as the location.
> > Hi Ed,
> > Here is the
> > problem.
> > imports which
> > points to
> > schemaLocation.
> > when i tried to
> > load:
> > </schema>
> > because the import
> > thanks,
> > -muruga
> > Muruga,
> > will benefit
> > from the answers.
> > schemas who's that
> > below. You
> > you show below
> > location or
> > namespace.
> > Hi Ed,
> > Thanks for the tip.
> > creating
> > XSDSchema.
> > printing each one
> > from ResourceSet.
> > <html>
> > <head>
> > </head>
> > <center>
> > <img height="35"
> > width="760">
> > <br>
> > width="436">
> > <tr>
> > <td>
> > width="171"/>
> > </td>
> > </tr>
> > </table>
> > </br>
> > </img>
> > </center>
> > </body>
> > </html>
> > thanks
> > -muruga
> > Muruga,
> > to handle "wsdl"
> > "wsdl" resource,
> > the
> > just as the "xsd"
> > one <schema> in
> > the
> > .xsd file.
> > > Hi Ed,
> > the embedded
> > schemas
> > > from a wsdl file.
> > > <definition>
> > > <types>
> > > </schema>
> > > </schema>
> > > </types>
> > > </definition>
> > > thanks
> > > -muruga
<html>
Muruga,
<br>
<blockquote dir=ltr
location.
<br>
<br>problem.
<br>points to
to
<br>load:
<br> </schema>
import
<p>thanks,
<br>-muruga
<br>Muruga,
that
You
below
<br>namespace.
<br>Hi Ed,
<br><html>
<br><head>
<br></head>
<br><center>
<br>width="760">
<br><br>
<br> <tr>
<br> <td>
width="171"/>
<br></td>
<br></tr>
<br></table>
<br></br>
<br></img>
<br></center>
<br></body>
<br></html>
<p>thanks
<br>-muruga
<br>Muruga,
"wsdl"
"wsdl" resource,
<br>the
"xsd"
in
<br>the
<br>.xsd file.
<p>> Hi Ed,
<br>>
<br>schemas
<br>>
<br>>
<br>> <definition>
<br>> <types>
<br>>
<br>> </schema>
xmlns:b="boo"/>
<br>>
<br>>
<br>> </schema>
<br>> </types>
<br>> </definition>
<br>>
<br>>
<br>> thanks
<br>> -muruga
<p>
<br>
</blockquote>
</blockquote>
</body>
</html>
| Re: loading embedded schemas from wsdl [message #584769 is a reply to message #39842] |
Ed,
thanks
-muruga
Muruga,=20
=20
location.=20
=20
Hi Ed,=20
is the=20
problem.=20
which=20
points to=20
schemaLocation.=20
i tried to=20
load:=20
</schema>=20
import=20
thanks,=20
-muruga=20
Muruga,=20
benefit=20
who's that=20
You=20
show below=20
or=20
namespace.=20
=20
Hi Ed,=20
XSDSchema.=20
each one=20
<html>=20
<head>=20
</head>=20
<center>=20
width=3D"760">=20
<br>=20
width=3D"436">=20
<tr>=20
<td>=20
width=3D"171"/>=20
</td>=20
</tr>=20
</table>=20
</br>=20
</img>=20
</center>=20
</body>=20
</html>=20
thanks=20
-muruga=20
Muruga,=20
handle "wsdl"=20
resource,=20
the=20
the "xsd"=20
<schema> in=20
the=20
.xsd file.=20
> Hi Ed,=20
>=20
embedded=20
schemas=20
>=20
>=20
> <definition>=20
> <types>=20
> </schema>=20
> </schema>=20
> </types>=20
> </definition>=20
>=20
>=20
> thanks=20
> -muruga=20
<HTML><HEAD>
in one=20
wsdl.</FONT></DIV>
could use=20
physical=20
<STYLE></STYLE>
Thats why i=20
Merks" <<A =
namespace as=20
the location.=20
that into=20
Here is=20
don't=20
location. But i=20
when i=20
<BR> =20
<BR> xmlns=3D"<A=20
a</A>"=20
<BR> <import =
namespace=3D"<A=20
<BR> <element=20
<BR> <element=20
<BR> </schema>=20
because=20
--=20
<BR>Muruga,=20
will=20
who's=20
show=20
with the=20
include with=20
---=20
<BR>Hi Ed,=20
creating=20
XSDSchema.=20
each=20
extra=20
<BR><html>=20
<BR><center>=20
border=3D"0"=20
<BR></table>=20
<BR></body>=20
<BR></html>=20
com</A>...=20
<BR>Muruga,=20
handle=20
the=20
contain all=20
<schema> in=20
to look=20
file.=20
<BR>>=20
<schema=20
; =20
</schema> =
; =20
;=20
</schema>=20
</definition>=20
<BR>>=20
<P> &nbs=
p; &nbs p;=20
<BR> &nb=
sp; =20
Encoding:=20
</HTML>
| Re: loading embedded schemas from wsdl [message #584803 is a reply to message #39873] |
Muruga,
answer is yes.
> wsdl. thanks-muruga
> > thanks,-muruga
> > > Hi Ed,
> > > problem.
> > > points to
> > > load:
> > > <import
> > > </schema>
> > > thanks,
> > > -muruga
> > > Muruga,
> > > from the answers.
> > > namespace.
> > > Hi Ed,
> > > Thanks for the tip.
> > > from ResourceSet.
> > > ResourceSet.
> > > <html>
> > > <head>
> > > </head>
> > > <center>
> > > <img height="35"
> > > width="760">
> > > <br>
> > > <tr>
> > > <td>
> > > width="171"/>
> > > </td>
> > > </tr>
> > > </table>
> > > </br>
> > > </img>
> > > </center>
> > > </body>
> > > </html>
> > > thanks
> > > -muruga
> > > Muruga,
> > > the
> > > the
> > > .xsd file.
> > > > Hi Ed,
> > > schemas
> > > > from a wsdl file.
> > > > <definition>
> > > > <types>
> > > > </schema>
> > > xmlns:b="boo"/>
> > > > <element name="e1"
> > > type="b:booType"/>
> > > > </schema>
> > > > </types>
> > > > </definition>
> > > > thanks
> > > > -muruga
<html>
Muruga,
is yes.
<br>
<blockquote dir=ltr
<br>
<blockquote dir=ltr
location.
<br>
<br>problem.
<br>points to
to
<br>load:
<br> </schema>
import
<p>thanks,
<br>-muruga
<br>Muruga,
that
You
below
<br>namespace.
<br>Hi Ed,
<br><html>
<br><head>
<br></head>
<br><center>
<br>width="760">
<br><br>
<br> <tr>
<br> <td>
width="171"/>
<br></td>
<br></tr>
<br></table>
<br></br>
<br></img>
<br></center>
<br></body>
<br></html>
<p>thanks
<br>-muruga
<br>Muruga,
"wsdl"
"wsdl" resource,
<br>the
"xsd"
in
<br>the
<br>.xsd file.
<p>> Hi Ed,
<br>>
<br>schemas
<br>>
<br>>
<br>> <definition>
<br>> <types>
<br>>
<br>> </schema>
xmlns:b="boo"/>
<br>>
<br>>
<br>> </schema>
<br>> </types>
<br>> </definition>
<br>>
<br>>
<br>> thanks
<br>> -muruga
<p>
<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</body>
</html>
| Re: loading embedded schemas from wsdl [message #584836 is a reply to message #39937] |
Hi Ed,
the ResourceSet.=20
-Muruga
Muruga,=20
answer is yes.=20
=20
thanks-muruga=20
=20
the location.=20
=20
Hi Ed,=20
Here is the=20
problem.=20
imports which=20
points to=20
schemaLocation.=20
when i tried to=20
load:=20
</schema>=20
the import=20
thanks,=20
-muruga=20
Muruga,=20
will benefit=20
below. You=20
you show below=20
location or=20
namespace.=20
=20
Hi Ed,=20
creating=20
XSDSchema.=20
<html>=20
<head>=20
</head>=20
<center>=20
width=3D"760">=20
<br>=20
width=3D"436">=20
<tr>=20
<td>=20
width=3D"171"/>=20
</td>=20
</tr>=20
</table>=20
</br>=20
</img>=20
</center>=20
</body>=20
</html>=20
thanks=20
-muruga=20
Muruga,=20
handle "wsdl"=20
"wsdl" resource,=20
the=20
as the "xsd"=20
one <schema> in=20
the=20
.xsd file.=20
> Hi Ed,=20
>=20
the embedded=20
schemas=20
>=20
>=20
> <definition>=20
> <types>=20
> </schema>=20
> </schema>=20
> </types>=20
> </definition>=20
>=20
>=20
> thanks=20
> -muruga=20
<HTML><HEAD>
see any=20
to the=20
answer is=20
yes. <BR> =20
for the=20
Merks" <<A =
could=20
to the=20
<STYLE></STYLE>
Oh. Thats why=20
kind of=20
Merks" <<A =
namespace=20
as the location.=20
type that=20
under=20
group. Here=20
sure i=20
schema=20
reason when i=20
<BR> =20
<BR> xmlns=3D"<A=20
a</A>"=20
<BR> <import=20
<BR> <element=20
<BR> <element=20
<BR> </schema>=20
is=20
attribute.=20
--=20
<BR>Muruga,=20
people will=20
schemas=20
HTML you=20
resource=20
import or=20
---=20
<BR>Hi Ed,=20
and=20
element=20
with XSDSchema.=20
printing=20
doc as=20
<BR><html>=20
<BR>src=3D"<A=20
border=3D"0"=20
<BR></table>=20
<BR><A=20
com</A>...=20
<BR>Muruga,=20
to=20
"xsd". =20
will=20
the one=20
code to=20
from a wsdl=20
<BR>>=20
<types>=20
<schema=20
; =20
</schema>=20
<schema=20
; =20
;=20
<BR>>=20
on the=20
<P> &nbs=
p; &nbs p;=20
PayFlow.wsdl =20
<BR> &nb=
sp; =20
Encoding:=20
Current Time: Thu Nov 06 21:13:43 EST 2025
Powered by FUDForum. Page generated in 0.30282 seconds
