set authorRoleDisplayName [message #40162] |
Fri, 11 January 2008 06:52  |
Originally posted by: juj.lincoln.fr
hi,
I have a question, I don't know how to create authorRoleDisplayName for
XDSDocumentEntry.
Do you have any example?
Thanks a lot.
jjameau
Re: set authorRoleDisplayName [message #40253 is a reply to message #40246] |
Tue, 15 January 2008 12:09  |
Sorry, my mistake. author role, institution and speciality are many
valued. thus they are implemented as lists
so the code is:
docEntry.getAuthor().getAuthorRole().add("primary care provider");
regards,
- Sarah
exquisitus wrote:
> Thank you for your response.
> But when I set docEntry.getAuthor() the only method that is available is
> .setAuthorPerson() and there isn't the .setAuthorRole() method so it's
> not possible to use docEntry.getAuthor().setAuthorRole().
> Do you know why?
> Thanks.
> JJameau
> Sarah Knoop wrote:
>> Hi jjameau,
>> AuthorRole is just a string, at least in the new version of the OHF
>> code which complies with the newer version of the XDS specification.
>> The code would look something like this
>> docEntry.getAuthor().setAuthorRole("primary care provider");
>> hope this helps,
>> - Sarah
>> exquisitus wrote:
>>> hi,
>>> for XDSDocumentEntry.
>>> Thanks a lot.
>>> jjameau
Re: set authorRoleDisplayName [message #584371 is a reply to message #40162] |
Mon, 14 January 2008 12:44  |
Hi jjameau,
AuthorRole is just a string, at least in the new version of the OHF code
hope this helps,
- Sarah
exquisitus wrote:
> hi,
> XDSDocumentEntry.
> Thanks a lot.
> jjameau
Re: set authorRoleDisplayName [message #584382 is a reply to message #40236] |
Tue, 15 January 2008 09:08  |
it's not possible to use docEntry.getAuthor().setAuthorRole().
Do you know why?
Thanks.
JJameau
Sarah Knoop wrote:
> Hi jjameau,
> hope this helps,
> - Sarah
> exquisitus wrote:
>> hi,
>> Thanks a lot.
>> jjameau
Re: set authorRoleDisplayName [message #584393 is a reply to message #40246] |
so the code is:
regards,
- Sarah
> Do you know why?
> Thanks.
> JJameau
> Sarah Knoop wrote:
>> Hi jjameau,
>> hope this helps,
>> - Sarah
>> exquisitus wrote:
>>> hi,
>>> Thanks a lot.
>>> jjameau
FUDForum. Page generated in 0.04542 seconds
