Home » Eclipse Projects » Plugin Development Environment (PDE) » Where to specify allowBinaryCycles=true?
Where to specify allowBinaryCycles=true? [message #30708] Mon, 03 November 2008 08:17 Go to next message
I'm using Eclipse 3.4 (build id: I20080617-2000) and trying to use the
allowBinaryCycles=true option described in bug 208011
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=208011). The bug report
mentions putting this in the "top level build configuration properties."
Is this the build.properties for a plug-in?
Ultimately I'd like to build an application using the Eclipse Product
export wizard. Is it possible to use this option for that?
I put allowBinaryCycles = true in each of my plug-in's build.properties
files. My plug-ins depend on some binaries (plug-ins in my target
environment) that are contain cycles but none of my workspace plug-ins
contain cycles.
I tried building the product but wasn't able to. I then tried building
a plug-in and got the same cycles error. The plug-in references 17
plug-ins of which only one is a workspace plug-in. That workspace
plug-in has no references.
I've tried searching around for more details on this property, however,
I've only been able to find comments about it being available and how
it's useful and not about the mechanics of using it.
-Ryan Norris
Re: Where to specify allowBinaryCycles=true? [message #30752 is a reply to message #30708] Mon, 03 November 2008 09:14 Go to previous messageGo to next message
> contain cycles.
In 3.5M3, you can use the export wizards in PDE UI to enable this option
(it's actually enabled by default now).
http://code9.com/2008/10/28/tip-pde-build-and-binary-cycles/
~ Chris
Re: Where to specify allowBinaryCycles=true? [message #30785 is a reply to message #30752] Mon, 03 November 2008 10:09 Go to previous messageGo to next message
Thanks! I saw that article but unfortunately I haven't switched to 3.5
yet. I probably won't be able to for a while either. It sounds like
the option should be available in my version of Eclipse. I don't mind
manually adding if only I could figure out where.
-Ryan
>> report mentions putting this in the "top level build configuration
>> properties." Is this the build.properties for a plug-in?
>> build.properties files. My plug-ins depend on some binaries (plug-ins
>> in my target environment) that are contain cycles but none of my
>> workspace plug-ins contain cycles.
>> building a plug-in and got the same cycles error. The plug-in
>> references 17 plug-ins of which only one is a workspace plug-in. That
>> workspace plug-in has no references.
>> however, I've only been able to find comments about it being available
>> and how it's useful and not about the mechanics of using it.
> Cheers,
> ~ Chris
Re: Where to specify allowBinaryCycles=true? [message #30820 is a reply to message #30785] Mon, 03 November 2008 11:30 Go to previous message
The "top level build configuration" is not available in the UI. It is
part of setting up a headless automated build. During export, the UI
generates this configuration for you behind the scenes.
In 3.4 there is no way to turn on allowBinaryCycles for export, you must
instead set up a headless build.
http://help.eclipse.org/ganymede/topic/org.eclipse.pde.doc.u ser/tasks/pde_product_build.htm
-Andrew
> -Ryan
>>> the allowBinaryCycles=true option described in bug 208011
>>> (plug-ins in my target environment) that are contain cycles but none
>>> of my workspace plug-ins contain cycles.
>>> That workspace plug-in has no references.
>>> available and how it's useful and not about the mechanics of using it.
>> option (it's actually enabled by default now).
>> Cheers,
>> ~ Chris
Re: Where to specify allowBinaryCycles=true? [message #584109 is a reply to message #30708] Mon, 03 November 2008 09:14 Go to previous message
> contain cycles.
~ Chris
Re: Where to specify allowBinaryCycles=true? [message #584120 is a reply to message #30752] Mon, 03 November 2008 10:09 Go to previous message
-Ryan
> Cheers,
> ~ Chris
Re: Where to specify allowBinaryCycles=true? [message #584133 is a reply to message #30785] Mon, 03 November 2008 11:30 Go to previous message
-Andrew
> -Ryan
>> Cheers,
>> ~ Chris
Previous Topic:Where to specify allowBinaryCycles=true?
Next Topic:Plug in with cyclic dependencies?
Current Time: Wed Nov 05 07:50:59 EST 2025
Powered by FUDForum. Page generated in 0.05697 seconds
