Home » Eclipse Projects » DSDP - Target Management » Acess Restriction on rse.subsystems.files.ssh.SftpFileSubSystemConfiguration
Acess Restriction on rse.subsystems.files.ssh.SftpFileSubSystemConfiguration [message #549796] Tue, 27 July 2010 20:41 Go to next message
I'm trying to use RSE to programmatically create a SFTP connection over SSH to view files on a remote server in a RCP application (Eclipse 3.5.1). Here is the code::
IHost host = registry.getHost(profile, hostName);
IRSESystemType systemType = RSECorePlugin.getTheCoreRegistry().getSystemTypeById(IRSESys temType.SYSTEMTYPE_UNIX_ID);
host = registry.createHost(systemType, hostName, hostName, "Remote Connection");
SftpFileSubSystemConfiguration sftpFileSubSystemConfiguration = new SftpFileSubSystemConfiguration();
sftpFileSubSystemConfiguration.getSearchService(host);
ISubSystemConfigurationProxy[] proxies = RSECorePlugin.getDefault().getSubSystemConfigurationProxies( );
sftpFileSubSystemConfiguration.setSubSystemConfigurationProx y(proxies[4]); // Acess restriction error here
FileServiceSubSystem fileService = (FileServiceSubSystem)registry.getSubSystems(host)[0];
fileService.switchServiceFactory(sftpFileSubSystemConfigurat ion);
Is this a valid approach? I am getting a few errors when trying to run it with the RSE-runtime-3.2 jars; before I had checked out all the RSE feature projects from CVS into my Eclipse workspace (and that worked fine).
I can instantiate the SftpFileSubSystemConfiguration class from org.eclipse.rse.subsystems.files.ssh.SftpFileSubSystemConfig uration and use some of its methods such as getSearchService(host), however if I try setSubSystemConfigurationProxy(proxy) I get the following error:
"Access restriction: The method setSubSystemConfigurationProxy(ISubSystemConfigurationProxy) from the type SubSystemConfiguration is not accessible due to restriction on required library ...\eclipse\plugins\org.eclipse.rse.ui_3.1.100.v201005282245 .jar "
If you could point me in the right direction, it would be greatly appreciated.
Re: Acess Restriction on rse.subsystems.files.ssh.SftpFileSubSystemConfiguration [message #556085 is a reply to message #549796] Mon, 30 August 2010 14:10 Go to previous messageGo to next message
If you want to strictly use SSH, I would suggest creating an SSH Only
connection rather than a Unix Connection:
temType.SYSTEMTYPE_SSH_ONLY_ID);
Once you've created the Host, you shouldn't need to instantiate the
FileSubsystem yourself; rather you should do something like this:
IRemoteFileSubSystem ss = RemoteFileUtility.getFileSubSystem(host);
In this case, the subsystem is an RSE-aware wrapper to the lower-level file
service.
Hope that helps!
<mlists@bigrideau.com> wrote in message
news:i2nucl$hcf$1@build.eclipse.org...
> Here is the code::
> Connection");
> fine).
> appreciated.
Re: Acess Restriction on rse.subsystems.files.ssh.SftpFileSubSystemConfiguration [message #557008 is a reply to message #556085] Fri, 03 September 2010 11:35 Go to previous messageGo to next message
It does.
Thanks!
Re: Acess Restriction on rse.subsystems.files.ssh.SftpFileSubSystemConfiguration [message #583743 is a reply to message #556085] Fri, 03 September 2010 11:35 Go to previous message
It does.
Thanks!
Previous Topic:How to export the RSE as an eclipse RCP production?
Next Topic:Execute command or script after SSH connection
Current Time: Sun Jul 27 16:13:43 EDT 2025
Powered by FUDForum. Page generated in 0.03671 seconds
