Home » Eclipse Projects » DSDP - Target Management » How to export the RSE as an eclipse RCP production?
Re: How to export the RSE as an eclipse RCP production? [message #556139 is a reply to message #556086] |
Mon, 30 August 2010 22:02   |
Thank you for your reply!!
I have done the following step:
1.Launch the eclipse and load all the RSE SDK source(org.eclipse.tm.rse).
2.Open the package org.eclipse.rse.ui and open the plugin.xml in eclipse.
3.In the Extensions,I add an extension point named org.eclipse.core.runtime.applications,and create a new Application class extends from IApplication.
4.Add ApplicationWorkbenchAdvisor,ApplicationWorkbenchWindowAdviso r,ApplicationActionBarAdvisor to make this plugin as a RCP Application.
5.In the ApplicationWorkbenchAdvisor add one line code:
private static final String PERSPECTIVE_ID = "org.eclipse.rse.ui.view.SystemPerspective";
to take the RSE's Perspective as the initial window perspective.
6.Add a new production configuration file name rse.rcp.production. and add all the rse's plugin package and required plugin to the production's dependencies.
Now some problems arised:
1.In step 6,The Overview's Procduct Definition,I can't find a proper Application I have created in the drop-down list.
2.I choose a Application named org.eclipse.ui.ide.workbench to run this RCP,when I export the RCP production and run it.An error show me:
!SESSION 2010-08-31 09:55:03.531 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_20
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_CN
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 4 0 2010-08-31 09:55:05.578
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "org.eclipse.ui.ide.workbench" could not be found in the registry. The applications available are: org.eclipse.equinox.app.error, org.eclipse.equinox.p2.artifact.repository.mirrorApplication , org.eclipse.equinox.p2.metadata.repository.mirrorApplication
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:242)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
[Updated on: Mon, 30 August 2010 22:04] by Moderator
Re: How to export the RSE as an eclipse RCP production? [message #556574 is a reply to message #556139] |
Wed, 01 September 2010 16:40  |
From what I can see here, it doesn't look like this is an issue with RSE.
Perhaps you aren't including the plugin that defines
"org.eclipse.ui.ide.workbench" - I think that's the
org.eclipse.ui.ide.application plugin.
"boyeestudio" <gaoyuanxue118@gmail.com> wrote in message
news:i5hnsj$k1c$1@build.eclipse.org...
> extends from IApplication. 4.Add
> dependencies.
> !SESSION 2010-08-31
> !STACK 1
> tarter.java:368)
> tarter.java:179)
Re: How to export the RSE as an eclipse RCP production? [message #583702 is a reply to message #556086] |
!STACK 1
Re: How to export the RSE as an eclipse RCP production? [message #583733 is a reply to message #583702] |
> dependencies.
> !SESSION 2010-08-31
> !STACK 1
> tarter.java:368)
> tarter.java:179)
Current Time: Wed Jul 23 06:02:28 EDT 2025
Powered by FUDForum. Page generated in 0.10973 seconds
