Home » Modeling » Epsilon » [HUTN] Problem Linux with property "upper" of the UML.ecore
[HUTN] Problem Linux with property "upper" of the UML.ecore [message #501872] |
Fri, 04 December 2009 03:57  |
Hi, I am working with epsilon_0.8.8 in linux and I am using eclipse Ganymede 3.4.0.
I have problem with property "upper" of the model "UML.ecore".
I test the same file in Windows XP and I have not any problem.
Thanks!
This file HUTN shows this error: Reason: Expected UnlimitedNatural for: upper.
@Spec {
metamodel "UML" {
nsUri: "http://www.eclipse.org/uml2/2.1.0/UML"
uml {
Model "Model1"{
nestedPackage: Package "Package1"
Package "Package1"{
packagedElement: Class "Class1" {name : "Class1"},
Class "Class2" {name : "Class2"},
Association "Association1" {
ownedEnd: Property "src1" {
type : Class "Class1"
upper : -1
lower : 1
Property "dst1"{
type : Class "Class2"
upper : -1 // FAILS HERE
lower : 1
memberEnd: Property "src2", Property "dst2"
Property "scr2",
Property "dst2"
Property "src2"{
upper : -1
lower : 1
Property "dst2"{
upper : 1
lower : 1
[Updated on: Fri, 04 December 2009 04:03] by Moderator
Re: [HUTN] Problem Linux with property "upper" of the UML.ecore [message #501977 is a reply to message #501872] |
Fri, 04 December 2009 11:08   |
Hi Raul,
Reply below...
Raul wrote on Fri, 04 December 2009 03:57 | Hi, I am working with epsilon_0.8.8 in linux and I am using eclipse Ganymede 3.4.0.
Thanks!
@Spec {
metamodel "UML" {
uml {
Model "Model1"{
Package "Package1"{
upper : -1
lower : 1
Property "dst1"{
lower : 1
Property "scr2",
Property "dst2"
Property "src2"{
upper : -1
lower : 1
Property "dst2"{
upper : 1
lower : 1
The values in the packagedElement slot of Package1 don't look right to me. The first 3 are objects and the last 2 are references to objects. The values in a slot must all be primitives, objects or references, and not a mixture.
Therefore, it seems that the corrected code might be:
@Spec {
metamodel "UML" {
uml {
Model "Model1"{
Package "Package1"{
upper : -1
lower : 1
Property "dst1"{
lower : 1
Property "src2"{
upper : -1
lower : 1
Property "dst2"{
upper : 1
lower : 1
However, in the version of UML that I'm using (3.0.0), Property is not a subclass of PackagableElement, so I get an error for the above code.
A correct specification for me places the properties inside ownedAttribute slots of the classes, like this:
@Spec {
metamodel "UML" {
uml {
Model "Model1"{
Package "Package1"{
ownedAttribute: Property "dst2"{
upper : 1
lower : 1
Class "Class2" {
ownedAttribute: Property "src2"{
upper : -1
lower : 1
upper : -1
lower : 1
Property "dst1"{
lower : 1
The error message that you received seems counter-intuitive. I will investigate, and see if we can produce a better error message when mixed values are provided for a slot.
Hope this helps,
Louis.
Re: [HUTN] Problem Linux with property "upper" of the UML.ecore [message #583432 is a reply to message #501872] |
Hi Raul,
Reply below...
> Thanks!
> @Spec {
> metamodel "UML" {
> uml {
> Model "Model1"{
> Package "Package1"{
> upper : -1
> lower : 1
> Property "dst1"{
> lower : 1
> Property "scr2",
> Property "dst2"
> Property "src2"{
> upper : -1
> lower : 1
> Property "dst2"{
> upper : 1
> lower : 1
@Spec {
metamodel "UML" {
uml {
Model "Model1"{
Package "Package1"{
upper : -1
lower : 1
Property "dst1"{
lower : 1
Property "src2"{
upper : -1
lower : 1
Property "dst2"{
upper : 1
lower : 1
@Spec {
metamodel "UML" {
uml {
Model "Model1"{
Package "Package1"{
upper : 1
lower : 1
Class "Class2" {
upper : -1
lower : 1
upper : -1
lower : 1
Property "dst1"{
lower : 1
Hope this helps,
Louis.
Current Time: Sun Jul 27 22:23:11 EDT 2025
Powered by FUDForum. Page generated in 0.06870 seconds
