Home » Modeling » Epsilon » resolving a reference to an object, instead of obtaining a copy
resolving a reference to an object, instead of obtaining a copy [message #502006] |
Fri, 04 December 2009 12:30  |
Hi Dimitris,
I have a model that stores references to objects in other models.
When I load this model and try to access the referred objects, I
obtain a copy of them instead of the real ones. Do you know how
could I get the real ones?
(All models are passed as parameters to an EOL file that I'm executing).
Thx,
Esther
Re: resolving a reference to an object, instead of obtaining a copy [message #502217 is a reply to message #502041] |
Mon, 07 December 2009 04:22   |
Hi Steffen,
Yes, I was a bit ambiguous... Let's suppose I have two
models A and B, and the objects in A have an attribute
that refers to objects in B. First I store the referred
object in a variable:
var v := object_in_A.referred_object;
Then I traverse the objects in B and compare them with
v by using '=':
for (b in B!v_type.allInstances())
if (b = v)
'I found the object'.println();
The condition evaluates to false in all cases. I also found
that the hashCodes of the elements in B are different from
v's hashCode. Nonetheless, the attribue values in 'v' are what
I expected, it is just that I do not obtain the same object.
Esther
Steffen Zschaler escribió:
> Hi Esther,
> Can you be a bit more specific here: What do you mean when you speak of
> a 'copy'? How do you distinguish these objects from each other?
> Steffen
> Esther wrote:
>> Hi Dimitris,
>> Thx,
>> Esther
Re: resolving a reference to an object, instead of obtaining a copy [message #502231 is a reply to message #502217] |
Mon, 07 December 2009 05:30  |
On an update to this, Esther has now sent me the necessary files
(metamodels/models/eol) so that I can have a closer look at this.
Dimitris
Esther wrote:
> Hi Steffen,
> v by using '=':
> if (b = v)
> Cheers,
> Esther
>> Hi Esther,
>> of a 'copy'? How do you distinguish these objects from each other?
>> Steffen
>> Esther wrote:
>>> Hi Dimitris,
>>> Thx,
>>> Esther
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: resolving a reference to an object, instead of obtaining a copy [message #583485 is a reply to message #502006] |
Fri, 04 December 2009 16:10  |
Hi Esther,
Steffen
Esther wrote:
> Hi Dimitris,
> Thx,
> Esther
Re: resolving a reference to an object, instead of obtaining a copy [message #583569 is a reply to message #502041] |
Hi Steffen,
v by using '=':
if (b = v)
Esther
> Hi Esther,
> Steffen
> Esther wrote:
>> Hi Dimitris,
>> Thx,
>> Esther
Re: resolving a reference to an object, instead of obtaining a copy [message #583582 is a reply to message #502217] |
Dimitris
Esther wrote:
> Hi Steffen,
> v by using '=':
> if (b = v)
> Cheers,
> Esther
>> Hi Esther,
>> Steffen
>> Esther wrote:
>>> Hi Dimitris,
>>> Thx,
>>> Esther
Current Time: Thu Jul 24 22:32:07 EDT 2025
Powered by FUDForum. Page generated in 0.05626 seconds
