Home » Eclipse Projects » DTP » MSSQL Connectivity
MSSQL Connectivity [message #23517] Tue, 28 November 2006 10:36 Go to next message
I'm trying to use the MSSQL support in DTP 1.0 RC 0.
Does anyone know if MSSQL DSE tree-viewer support is fully implemented?
Nothing appears below "schemas" in the tree-viewer.
Has anyone had more luck?
Really appreciate your help,
Karim
Re: MSSQL Connectivity [message #23901 is a reply to message #23517] Mon, 04 December 2006 12:20 Go to previous messageGo to next message
Originally posted by: john.graham.sybase.com
Karim Fateem wrote:
> Karim
Hi Karim,
I was able to get a DSE tree for MySQL 5.0 using the latest (12/1) DTP
build. The following link from our Wiki might help too:
http://wiki.eclipse.org/index.php/Connecting_to_MySQL_4.x_an d_5.x
I suspect that MySQL is not fully supported (in the sense that the tree
shows all the expected db objects and properties), but perhaps it is
enough for basic SQL query building and testing using our editor. In
general, DTP provides this base support for a number of data sources, and
looks to the community to flesh out the offering through our Enablement
project.
John Graham
Eclipse Data Tools Platform PMC Chair
Re: MSSQL Connectivity [message #23941 is a reply to message #23901] Tue, 05 December 2006 16:34 Go to previous messageGo to next message
Hi John - Looking for MS SQL Server 2000/2005 support.
Thank you for your help,
Karim
Re: MSSQL Connectivity [message #23978 is a reply to message #23901] Tue, 05 December 2006 16:46 Go to previous messageGo to next message
Hi John - Would there happen to be DSE support for MS SQL Server 2000 &
2005?
Karim
Re: MSSQL Connectivity [message #28206 is a reply to message #23978] Mon, 26 March 2007 17:15 Go to previous messageGo to next message
I would also like to know the answer to this question.
I've installed DTP 1.5M5 on top of Eclipse 3.3M5eh (Europa).
I defined a connection profile to view the standard Northwind database. When
I connect to the database in the Data Source Explorer window, I don't see
any schema information.
Chuck
"Karim Fateem" <karim.fateem@hotmail.com> wrote in message
news:962b464fce76b71a7361c311fcd53487$1@www.eclipse.org...
> 2005?
> Karim
Re: MSSQL Connectivity [message #28972 is a reply to message #28206] Fri, 06 April 2007 15:42 Go to previous messageGo to next message
> Chuck
>> 2005?
>> Karim
Chuck, Karim:
We do have a database definition for SQL Server, but apparently it is not
working with the later versions. We'll take a look at this for anything
obvious, but it is likely to require DTP specialization by some one (or
group) that knows this server well.
-- John Graham
Re: MSSQL Connectivity [message #29163 is a reply to message #28972] Tue, 10 April 2007 11:29 Go to previous messageGo to next message
But - I am using SQL 2000, not SQL 2005.
What versions of MS SQL Server do you support?
Chuck
"John Graham" <john.graham@sybase.com> wrote in message
news:8ba2915488891f75f591c14c8e61f34e$1@www.eclipse.org...
>> When I connect to the database in the Data Source Explorer window, I
>> don't see any schema information.
>> Thanks,
>> Chuck
>>> 2005?
>>> Karim
> Chuck, Karim:
> -- John Graham
Re: MSSQL Connectivity [message #29201 is a reply to message #28206] Tue, 10 April 2007 18:12 Go to previous message
Originally posted by: unineurone.gmail.com
What drivers are you using ?
I have the same issue (nothing under any schema, even when logged as "sa")
using jtds1.2 + 3.3M6/Europa
Note that I do see the schemas when using the quantumdb plugin.
Re: MSSQL Connectivity [message #583337 is a reply to message #23517] Mon, 04 December 2006 12:20 Go to previous message
Karim Fateem wrote:
> Karim
Hi Karim,
project.
John Graham
Re: MSSQL Connectivity [message #583349 is a reply to message #23901] Tue, 05 December 2006 16:34 Go to previous message
Karim
Re: MSSQL Connectivity [message #583365 is a reply to message #23901] Tue, 05 December 2006 16:46 Go to previous message
2005?
Karim
Re: MSSQL Connectivity [message #584937 is a reply to message #23978] Mon, 26 March 2007 17:15 Go to previous message
Chuck
> 2005?
> Karim
Re: MSSQL Connectivity [message #585086 is a reply to message #28206] Fri, 06 April 2007 15:42 Go to previous message
> Chuck
>> 2005?
>> Karim
Chuck, Karim:
-- John Graham
Re: MSSQL Connectivity [message #585152 is a reply to message #28972] Tue, 10 April 2007 11:29 Go to previous message
Chuck
>> Thanks,
>> Chuck
>>> 2005?
>>> Karim
> Chuck, Karim:
> -- John Graham
Re: MSSQL Connectivity [message #585164 is a reply to message #28206] Tue, 10 April 2007 18:12 Go to previous message
Previous Topic:ODA driver for EJB access
Next Topic:ODA driver for EJB access
Current Time: Sat Jul 26 12:44:43 EDT 2025
Powered by FUDForum. Page generated in 0.07694 seconds
