Home » Eclipse Projects » DSDP - Target Management » Still having problems with rseserver
Still having problems with rseserver [message #24890] |
Tue, 22 July 2008 15:36  |
It's been about two months since I first posed this problem. Got
distracted by other issues and am just now getting back to DSDP and TM.
I'm trying to start a dstore server on a Linux box. When I run daemon.pl,
I get "Networking problem, can't resolve local host". server.pl starts
correctly on port 4033, but when I try to connect to it from Eclipse
(Ganymede) on another machine, I get
"A socket connection to 192.168.1.11 could not be established. If you are
connecting via the communications daemon make sure the daemon is running
on the remote system. If you are connecting directly to the
communications server make sure the server is started on the remote
system. If you are connecting using REXEC, make sure that the server is
installed on the remote system and that the REXEC service is running on
that system."
The Launcher property is set to Running. What else am I missing?
Doug
Re: Still having problems with rseserver [message #25105 is a reply to message #24912] |
Fri, 25 July 2008 15:06   |
Hi David,
Thanks for the clue. Turns out the firewall is disabled, but SE Linux was
enabled on the system running the server. Nevertheless, turning off SE
Linux didn't change anything. And no, I don't get any messages from the
server when I try to connect.
Doug
David McKnight wrote:
> When you try to connect, are there are messages in the console where you
> started the server? Is there a firewall that could be preventing the
> connect?
> "Doug Abbott" <doug@intellimetrix.us> wrote in message
> news:6df933883e1727b729abb786a3f614e5$1@www.eclipse.org...
>> that system."
>> Thanks,
>> Doug
Re: Still having problems with rseserver [message #25312 is a reply to message #25105] |
Thu, 31 July 2008 10:59   |
Hi Doug,
I don't know much about SELinux but to rule it out interference but it,
could you see if you can connect after you disable SELinux.
I think to disable it you need to edit /ect/selinux/config to have:
SELINUX=disabled
news:7bb3a6d30ca4cad81bd37f1d5b0ddf5f$1@www.eclipse.org...
> Hi David,
> Doug
>> connect?
>>> daemon.pl, I get "Networking problem, can't resolve local host".
>>> server.pl starts correctly on port 4033, but when I try to connect to it
>>> from Eclipse (Ganymede) on another machine, I get
>>> are connecting via the communications daemon make sure the daemon is
>>> running on the remote system. If you are connecting directly to the
>>> that system."
>>> Thanks,
>>> Doug
Re: Still having problems with rseserver [message #25635 is a reply to message #24890] |
Wed, 06 August 2008 13:36   |
Ok,
so you launched server.pl on the remote and set the Client's
launcher type to "Running". Have you also looked at the Subsystem
Properties (Right-click > Properties) and adjusted the Port
to be 4033 ? When that's also done, you just need to be quick
enough on the client, and connect to the server before it times
out. By default you have about 30 seconds before the server times
out (timeout value can be changed).
Your daemon.pl issue might be related to an invalid setting
in /etc/hosts, or invalid DNS configuration. Try commands
such as
hostname
uname -a
domainname
nslookup localhost
/usr/sbin/ifconfig
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
> that system."
> Doug
Re: Still having problems with rseserver [message #576159 is a reply to message #24912] |
Hi David,
Doug
> connect?
>> that system."
>> Thanks,
>> Doug
Re: Still having problems with rseserver [message #576285 is a reply to message #25105] |
Hi Doug,
SELINUX=disabled
> Hi David,
> Doug
>> connect?
>>> that system."
>>> Thanks,
>>> Doug
Re: Still having problems with rseserver [message #576533 is a reply to message #24890] |
Ok,
such as
hostname
uname -a
domainname
nslookup localhost
/usr/sbin/ifconfig
> that system."
> Doug
Re: Still having problems with rseserver [message #583283 is a reply to message #25635] |
Tue, 11 May 2010 05:23  |
Sorry to drag up an old topic, but....
I had the same problem as the OP - rseserver failing to start with the error message: "Networking problem, can't resolve local host".
In my case at least it was becase the hostname of the target was not in its /etc/hosts
-John
Current Time: Sat Jul 19 02:28:45 EDT 2025
Powered by FUDForum. Page generated in 0.04737 seconds
