Home » Modeling » Epsilon » How to use Native with my own Java classes?
How to use Native with my own Java classes? [message #583097] Mon, 23 November 2009 14:50 Go to next message
I have a short EVL file that looks something like:
var frame := new Native('javax.swing.JFrame');
var v := new Native('my.MyValidator');
The first statement works fine, but the second throws an error:
Type 'my.MyValidator' not found
The EVL file and the my.MyValidator class reside in the same project, and I run the EVL file using the EVL Validation run-configuration.
Any ideas why I cannot use Native('my.MyValidator') ?
Thanks !
Re: How to use Native with my own Java classes? [message #583113 is a reply to message #583097] Mon, 23 November 2009 15:32 Go to previous messageGo to next message
To use a Java class from Epsilon, it needs to either be in the classpath
or to be declared using the org.eclipse.epsilon.common.dt.tool extension
point. You can have a look at these two projects in the SVN for examples:
(tool implementations)
http://dev.eclipse.org/svnroot/modeling/org.eclipse.gmt.epsi lon/trunk/plugins/org.eclipse.epsilon.eol.tools/
(tool declarations)
http://dev.eclipse.org/svnroot/modeling/org.eclipse.gmt.epsi lon/trunk/plugins/org.eclipse.epsilon.eol.dt.tools/
Dimitris
> Thanks !
Re: How to use Native with my own Java classes? [message #583270 is a reply to message #583097] Wed, 25 November 2009 16:23 Go to previous message
Thanks A LOT !
That was very helpful (and quick!)
Previous Topic:How to use Native with my own Java classes?
Next Topic:Showing EVL validation in "Problems" view: how to obtain it?
Current Time: Sun Jul 27 03:26:46 EDT 2025
Powered by FUDForum. Page generated in 1.04924 seconds
