Home » Eclipse Projects » DTP » DTP repository
DTP repository [message #23603] Wed, 29 November 2006 23:18 Go to next message
When i try to connect to The DTP CVS repository at dev.eclipse.org
with an anonymous pserver connection i get the following error :
"Could not connect to
:pserver:anonymous@dev.eclipse.org:/home/datatools: I/O exception
occurred: Connection refused: cvs [pserver aborted]: /home/datatools: no
such repository"
Am i missing something
thanks,
chandra
Re: DTP repository [message #23646 is a reply to message #23603] Thu, 30 November 2006 14:58 Go to previous messageGo to next message
You should be using /cvsroot/datatools as the path. This changed awhile
back and the old /home/* locations are in the process of being phased out.
Hope that helps,
Rob
Re: DTP repository [message #23732 is a reply to message #23646] Thu, 30 November 2006 23:13 Go to previous message
Hi Rob,
That helped. thanks a lot.
chandra
> Hope that helps,
> Rob
Re: DTP repository [message #583233 is a reply to message #23603] Thu, 30 November 2006 14:58 Go to previous message
Hope that helps,
Rob
Re: DTP repository [message #583256 is a reply to message #23646] Thu, 30 November 2006 23:13 Go to previous message
Hi Rob,
chandra
> Hope that helps,
> Rob
Previous Topic:DTP repository
Next Topic:Connectivity dbf driver
Current Time: Sun Nov 02 22:57:51 EST 2025
Powered by FUDForum. Page generated in 0.05170 seconds
