Home » Archived » XML Schema Definition (XSD) » xmleditor
xmleditor [message #36201] Sun, 18 January 2004 22:01 Go to next message
Originally posted by: crscca.bol.net.in
Is there any simple texteditor code/plugin that uses the xsd api which is
free to use and modify and which provides codeassist, syntax highlighting
on xsd schema based xml files?
Re: xmleditor [message #36235 is a reply to message #36201] Sun, 18 January 2004 22:16 Go to previous messageGo to next message
It should also generate sample xml from an xsd.
It should be free to use and modify
I will list what I need together.
1. XML editor with code assist, syntax highlighting and sample xml
generation from xsd
2. free to use and modify code
3. it should use the xsd api of eclipse
We would be able to save some time in our plugin code if we can reuse such
a code. Our plugin would probably include this code. It would be only a
secondary functionality in our plugin code. We can declare in our plugin
that it reuses code from elsewhere.
Re: xmleditor [message #36268 is a reply to message #36235] Mon, 19 January 2004 09:17 Go to previous message
Originally posted by: nex8.gmx.net
Hello, Raster!
There is a free XML editor, X-Men which also features code assist,
syntax highlighting, and some basic XML Schema support. It also uses the
XSD plugin.
You can check it out at: http://xmen.sourceforge.net/
Hope that one helps,
Tommy
> generation from xsd
Re: xmleditor [message #582939 is a reply to message #36201] Sun, 18 January 2004 22:16 Go to previous message
generation from xsd
Re: xmleditor [message #582967 is a reply to message #36235] Mon, 19 January 2004 09:17 Go to previous message
Hello, Raster!
XSD plugin.
Tommy
> generation from xsd
Previous Topic:xmleditor
Next Topic:Possible errors in the XSD facet item providers
Current Time: Wed Jul 23 08:15:28 EDT 2025
Powered by FUDForum. Page generated in 0.31357 seconds
