Home » Archived » Riena » Remote Services + https ?
Remote Services + https ? [message #27095] Sun, 21 June 2009 01:56 Go to next message
Originally posted by: eclipse-dev.volanakis.de
just curious: is it possible to use Riena Remote Services with https out
of the box?
I'm looking for something like this:
https://localhost:8080/hessian/PingPongWS
Elias.
Re: Remote Services + https ? [message #27134 is a reply to message #27095] Sun, 21 June 2009 06:50 Go to previous messageGo to next message
Elias Volanakis schrieb:
> of the box?
> Elias.
Yes you can. You just need to setup your server with HTTPs and use an SSL certificate. There is even in
o.e.r.communication.core a class SSLConfiguration which allows you to configure cacerts for clients. That is a
certifacte server with servers you trust as a client.
I guess Stefan could shed some more light on the SSLConfiguraation thing. I am not sure if also allows client
certificates (that is a client has a certificate that a server has to trust) but client certificates are not that
common. (browsers for example allways only use server certifacats).
But that server certifact use case should work out of the box.
christian
Re: Remote Services + https ? [message #27173 is a reply to message #27134] Wed, 24 June 2009 07:30 Go to previous message
Hi Elias,
Currently we only support server certificates.
You can configure your ssl configuration with the
"org.eclipse.riena.communication.core.ssl" extension point.
This may look like this:
<extension
id="org.eclipse.riena.communication.core.ssl.test"
<sslconfig protocol="TLSv1" keystore="#jre-cacerts#"
password="changeit"/>
</extension>
This special value of the key-store attribute means take the certificate
of the running JRE.
The key-store may define the certificate as a file, a resource local to
the contributing bundle or a URL.
HTH,
Stefan
>> Hi,
>> out of the box?
>> Elias.
> SSL certificate. There is even in o.e.r.communication.core a class
> is a certifacte server with servers you trust as a client.
> thing. I am not sure if also allows client certificates (that is a
> certificates are not that common. (browsers for example allways only use
> christian
Re: Remote Services + https ? [message #582890 is a reply to message #27095] Sun, 21 June 2009 06:50 Go to previous message
> of the box?
> Elias.
christian
Re: Remote Services + https ? [message #582901 is a reply to message #27134] Wed, 24 June 2009 07:30 Go to previous message
Hi Elias,
<extension
</extension>
of the running JRE.
HTH,
Stefan
>> Hi,
>> out of the box?
>> Elias.
> christian
Previous Topic:Remote Services + https ?
Next Topic:Riena 1.1.0.0 Targetplatform download zip
Current Time: Sat Jul 26 01:06:58 EDT 2025
Powered by FUDForum. Page generated in 0.06618 seconds
