Home » Archived » OHF » OHF Bridge MESA test 10503
OHF Bridge MESA test 10503 [message #36229] |
Tue, 30 October 2007 13:40  |
All,
I am using the OHF bridge.
I am trying to run MESA test 10503. This test calls for sending a PIX query
"ABC10503^^^XXXX"
I assume the PIX query should look something like
MSH|^~\&|OHFSource1|HIMSSSANDIEGO|HIMSS2005|XDSDEMO|2007 1030100729-0700||QBP^Q23^QBP_Q21|7250571275013314812|P|2.5
QPD|Q23^Get Corresponding IDs|5412693612507688165591841744311|ABC10503^^^XXX
RCP|I
However I am getting
IDs|5412693612507688165591841744311|ABC10503^^^&1.3.6.1. 4.1.21367.2007.1.2.400&ISO
RCP|I
I have configured a new RHIO in the rhioConfig.xml. The rhio is just a copy
of the XDS.a RHIO, but with a pixId of "LocalPIX"
LocalPIX is configured as
<pix>
<id>LocalPIX</id>
<mllp>
<unsecured>mllp://localhost:3600</unsecured>
</mllp>
<pixServerPropertiesId>Local PIX Server</pixServerPropertiesId>
<pixSourcePropertiesId>IBM PIX Server</pixSourcePropertiesId>
<pixConsumerPropertiesId>IBMPIXPDQClient</pixConsumerPropertiesId >
<pdqServerPropertiesId>IBM PIX Server</pdqServerPropertiesId>
<pdqConsumerPropertiesId>IBMPIXPDQClient</pdqConsumerPropertiesId >
</pix>
Local PIX Server is configured as
<pixProperties>
<id>Local PIX Server</id>
<facility>XDSDEMO</facility>
<application>HIMSS2005</application>
<assigningAuthorityNamespaceId>XXXX</assigningAuthorityNamespaceId >
<assigningAuthorityUniversalId></assigningAuthorityUniversalId >
<assigningAuthorityUniversalIdType>ISO</assigningAuthorityUniversalIdType >
</pixProperties>
In the patientIdentifier, I am specifiying the assigningAuthorityNamespaceId
to XXXX and the assigningAuthorityUniversalId is left blank.
Is anyone else having this problem? Am I missing something?
Thank you,
Corey Spears
Re: OHF Bridge MESA test 10503 [message #36295 is a reply to message #36263] |
Tue, 30 October 2007 16:30   |
Also,
It is possible, from the Bridge logs, to tell what the current
configuration setting is so long as you have it on debug logging mode
(should be the default). If you look at your bridge log file
(\tomcat\bridge.log or tomcat\bridge\<rhio name>\<faciltiy name>\<user
name>.log), you will see this line:
[DEBUG][12:41:03][clipse.ohf.bridge.ws.OHFBridge] Starting
PatientInfoType[] SearchPatient(PatientInfoType (
patientIdentifier=[PatientIdType ( idNumber=[ABC10503]
assigningAuthority=[AssigningAuthority ( namespaceId=[XXXX]
universalId=[1.3.6.1.4.1.21367.2005.1.1] universalIdType=[ISO]
useDefaultAssigningAuthority=[true] universalIdTypeCode=[] )]
)] patientName=[PatientNameType ( familyName=[] givenName=[]
otherName=[] suffix=[] prefix=[] )] patientDateOfBirth=[]
patientSex=[] patientAddress=[AddressType ( streetAddress=[]
otherDesignation=[] city=[] stateOrProvince=[]
zipOrPostalCode=[] country=[] countyParishCode=[] )]
patientPhoneHome=[PhoneType ( unformattedTelephoneNumber=[] )]
patientPhoneBusiness=[PhoneType ( unformattedTelephoneNumber=[] )]
genericAdtValues=[] ), PatientSearchPreferencesType (
quantityLimit=[-1] withoutDemographics=[true] ))
Please find this information in your log for the transaction that you
ran regarding 10503. As you can see from the details, it will tell us
whether it's using the default assigning authority or not:
-Matt
Matthew Davis wrote:
> Hi Corey,
> It looks like the default value from your PIX configuration settings are
> being copied into the message. From the OHF Bridge
> AssigningAuthorityType, there is an option
> "useDefaultAssigningAuthority". Make sure this is set to "false".
> From the Bridge MESA Test 1503
> (org.eclipse.ohf.bridge.ws.tests.mesa.TestMESA1053), we have this:
> PatientIdType idType = new PatientIdType("ABC10503");
> idType.getAssigningAuthorityType().setNamespaceId("XXXX");
> idType.getAssigningAuthorityType().setUseDefaultAssigningAut hority(false);
> PatientInfoType infoType = new PatientInfoType();
> infoType.setPatientIdentifier(idType);
> PatientSearchPreferencesType patientSearchPreferencesType = new
> PatientSearchPreferencesType();
> patientSearchPreferencesType.setWithoutDemographics(true);
> -Matt
> Corey Spears wrote:
>> All,
>> query "ABC10503^^^XXXX"
>> RCP|I
>> RCP|I
>> copy of the XDS.a RHIO, but with a pixId of "LocalPIX"
>> <pix>
>> <id>LocalPIX</id>
>> <mllp>
>> </mllp>
>> </pix>
>> <pixProperties>
>> </pixProperties>
>> assigningAuthorityNamespaceId to XXXX and the
>> Thank you,
>> Corey Spears
Re: OHF Bridge MESA test 10503 [message #36328 is a reply to message #36295] |
Tue, 30 October 2007 16:56   |
Corey,
After reviewing the log bit:
2007-10-30T10:07:25.497-07:00 Starting PatientInfoType[]
SearchPatient(PatientInfoType ( patientIdentifier=[PatientIdType (
idNumber=[ABC10503] assigningAuthority=[AssigningAuthority (
namespaceId=[XXXX] universalId=[] universalIdType=[ISO]
useDefaultAssigningAuthority=[false] universalIdTypeCode=[] )]
)] patientName=[PatientNameType ( familyName=[Stein]
givenName=[Richard] otherName=[] suffix=[] prefix=[] )]
patientDateOfBirth=[01/01/1983] patientSex=[M]
patientAddress=[AddressType ( streetAddress=[2401 4th Ave]
otherDesignation=[] city=[Seattle] stateOrProvince=[WA]
zipOrPostalCode=[98121] country=[] countyParishCode=[] )]
quantityLimit=[0] withoutDemographics=[true] ))
This is actually related to the universalIdType being set to "ISO". In
this case, the PIX Consumer is rejecting the the parameter and setting
its default - in this case that is
^^^&1.3.6.1.4.1.21367.2007.1.2.400&ISO instead of ^^^^XXXX. Try setting
the universal id type to "" by setting:
idType.getAssigningAuthorityType().setUniversalIdType("");
And see if it works. We'll find some work around or throw an error if
this case comes out.
Please let me know if this works.
-Matt
> Also,
> -Matt
>> Hi Corey,
>> are being copied into the message. From the OHF Bridge
>> -Matt
>> Corey Spears wrote:
>>> All,
>>> PIX query "ABC10503^^^XXXX"
>>> RCP|I
>>> RCP|I
>>> a copy of the XDS.a RHIO, but with a pixId of "LocalPIX"
>>> <pix>
>>> <id>LocalPIX</id>
>>> <mllp>
>>> </mllp>
>>> </pix>
>>> <pixProperties>
>>> </pixProperties>
>>> Thank you,
>>> Corey Spears
Re: OHF Bridge MESA test 10503 [message #36362 is a reply to message #36328] |
Tue, 30 October 2007 17:07   |
Matt,
It looks like this worked for me.
Is this something that will always have to be done? Is there a rule here
that I am missing? I have been assuming that the universalIdType is always
supposed to be "ISO". Is that not the case?
"Matthew Davis" <mattadav@us.ibm.com> wrote in message
news:fg85qf$f0h$1@build.eclipse.org...
> Corey,
> useDefaultAssigningAuthority=[false] universalIdTypeCode=[] )] )]
> patientName=[PatientNameType ( familyName=[Stein] givenName=[Richard]
> this case, the PIX Consumer is rejecting the the parameter and setting its
> default - in this case that is ^^^&1.3.6.1.4.1.21367.2007.1.2.400&ISO
> instead of ^^^^XXXX. Try setting the universal id type to "" by setting:
> -Matt
>> Also,
>> useDefaultAssigningAuthority=[true] universalIdTypeCode=[] )] )]
>> patientName=[PatientNameType ( familyName=[] givenName=[] otherName=[]
>> suffix=[] prefix=[] )] patientDateOfBirth=[] patientSex=[]
>> patientAddress=[AddressType ( streetAddress=[] otherDesignation=[]
>> city=[] stateOrProvince=[] zipOrPostalCode=[] country=[]
>> countyParishCode=[] )] patientPhoneHome=[PhoneType (
>> unformattedTelephoneNumber=[] )] patientPhoneBusiness=[PhoneType (
>> unformattedTelephoneNumber=[] )] genericAdtValues=[] ),
>> PatientSearchPreferencesType ( quantityLimit=[-1]
>> Please find this information in your log for the transaction that you ran
>> Thanks,
>> -Matt
>>> Hi Corey,
>>> -Matt
>>> Corey Spears wrote:
>>>> All,
>>>> RCP|I
>>>> RCP|I
>>>> <pix>
>>>> <id>LocalPIX</id>
>>>> <mllp>
>>>> </mllp>
>>>> </pix>
>>>> <pixProperties>
>>>> </pixProperties>
>>>> Thank you,
>>>> Corey Spears
Re: OHF Bridge MESA test 10503 [message #36391 is a reply to message #36362] |
Tue, 30 October 2007 18:56  |
Corey,
The following are valid:
a) namespaceId only
b) both universalId and universalIdType
c) all 3
Corey Spears wrote:
> Matt,
Re: OHF Bridge MESA test 10503 [message #582787 is a reply to message #36229] |
Tue, 30 October 2007 15:46  |
Hi Corey,
-Matt
Corey Spears wrote:
> All,
> "ABC10503^^^XXXX"
> RCP|I
> RCP|I
> <pix>
> <id>LocalPIX</id>
> <mllp>
> </mllp>
> </pix>
> <pixProperties>
> </pixProperties>
> Thank you,
> Corey Spears
Re: OHF Bridge MESA test 10503 [message #582800 is a reply to message #36263] |
Also,
-Matt
> Hi Corey,
> -Matt
> Corey Spears wrote:
>> All,
>> RCP|I
>> RCP|I
>> <pix>
>> <id>LocalPIX</id>
>> <mllp>
>> </mllp>
>> </pix>
>> <pixProperties>
>> </pixProperties>
>> Thank you,
>> Corey Spears
Re: OHF Bridge MESA test 10503 [message #582812 is a reply to message #36295] |
Corey,
-Matt
> Also,
> -Matt
>> Hi Corey,
>> -Matt
>> Corey Spears wrote:
>>> All,
>>> RCP|I
>>> RCP|I
>>> <pix>
>>> <id>LocalPIX</id>
>>> <mllp>
>>> </mllp>
>>> </pix>
>>> <pixProperties>
>>> </pixProperties>
>>> Thank you,
>>> Corey Spears
Re: OHF Bridge MESA test 10503 [message #582827 is a reply to message #36328] |
Matt,
> Corey,
> -Matt
>> Also,
>> Thanks,
>> -Matt
>>> Hi Corey,
>>> -Matt
>>> Corey Spears wrote:
>>>> All,
>>>> RCP|I
>>>> RCP|I
>>>> <pix>
>>>> <id>LocalPIX</id>
>>>> <mllp>
>>>> </mllp>
>>>> </pix>
>>>> <pixProperties>
>>>> </pixProperties>
>>>> Thank you,
>>>> Corey Spears
Re: OHF Bridge MESA test 10503 [message #582839 is a reply to message #36362] |
Corey,
a) namespaceId only
c) all 3
Corey Spears wrote:
> Matt,
Current Time: Wed Jul 23 05:26:08 EDT 2025
Powered by FUDForum. Page generated in 0.33470 seconds
