Home » Eclipse Projects » DSDP - Target Management » TM3.1 Problem with "Export to Remote File System"
TM3.1 Problem with "Export to Remote File System" [message #481907] Mon, 24 August 2009 13:07 Go to next message
Originally posted by: edvREMOVE.THISerik-reischl.de
I recently installed Eclipse Galileo PDT which has TM3.1 included. I noticed
that when you export something and save in rexpfd, choosing "Export to
Remote File System" doen't react at all. (In Ganymede with TM3.0 it worked
fine, I updated to TM3.1, and there it didn't work either, so it's a problem
of TM3.1).
Now I took TM 3.1.1 Stream Integration Build (I20090806-1212) and did the
same. Confusingly, when I right-click on the rexpfd and chose "Export to
Remote File System", now it asks me to open the "Team Synchronizing"
perspective.
Did I find a bug here?
Please don't hesitate to contact me, if you need further information.
Erik
Re: TM3.1 Problem with "Export to Remote File System" [message #482479 is a reply to message #481907] Wed, 26 August 2009 14:06 Go to previous messageGo to next message
Hi Erik,
It looks like you've found a bug. Could you please open a bugzilla for
this?
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Target%2 0Management
Dave
"Erik Reischl" <edvREMOVE@THISerik-reischl.de> wrote in message
news:h6uhd3$kpp$1@build.eclipse.org...
> Hello,
> noticed that when you export something and save in rexpfd, choosing
> "Export to Remote File System" doen't react at all. (In Ganymede with
> TM3.0 it worked fine, I updated to TM3.1, and there it didn't work either,
> so it's a problem of TM3.1).
> perspective.
> Cheers,
> Erik
Re: TM3.1 Problem with "Export to Remote File System" [message #482881 is a reply to message #482479] Fri, 28 August 2009 08:37 Go to previous messageGo to next message
"David McKnight" <dmcknigh@ca.ibm.com> schrieb im Newsbeitrag
news:h73tik$b3l$1@build.eclipse.org...
> Hi Erik,
> this?
Done. I'm looking forward to the fix in a new version. Thanks,
Erik
Re: TM3.1 Problem with "Export to Remote File System" [message #484113 is a reply to message #482881] Fri, 04 September 2009 07:07 Go to previous message
Hello David,
just wanted to confirm that with the new nightly build it now works
perfectly. Thanks!
Erik
"Erik Reischl" <edvREMOVE@THISerik-reischl.de> schrieb im Newsbeitrag
news:h78j2q$9kb$1@build.eclipse.org...
>> Hi Erik,
>> this?
> Erik
Re: TM3.1 Problem with "Export to Remote File System" [message #582280 is a reply to message #481907] Wed, 26 August 2009 14:06 Go to previous message
Hi Erik,
this?
Dave
> Hello,
> perspective.
> Cheers,
> Erik
Re: TM3.1 Problem with "Export to Remote File System" [message #582371 is a reply to message #482479] Fri, 28 August 2009 08:37 Go to previous message
> Hi Erik,
> this?
Erik
Re: TM3.1 Problem with "Export to Remote File System" [message #582414 is a reply to message #482881] Fri, 04 September 2009 07:07 Go to previous message
Hello David,
perfectly. Thanks!
Erik
>> Hi Erik,
>> this?
> Erik
Previous Topic:persistence of IHost custom properties
Next Topic:isLink not returning correct value for IRemoteFile
Current Time: Sun Jul 27 11:57:00 EDT 2025
Powered by FUDForum. Page generated in 0.05001 seconds
