Home » Modeling » UML2 » private package imports
private package imports [message #469902] Sat, 03 February 2007 00:42 Go to next message
I am trying to handle private package imports, with no success.
Let's say we have a model "modelA" that declares a class named "Class1":
<uml:Model xmi:version="2.1"
xmlns:xmi="http://schema.omg.org/spec/XMI/2.1"
xmlns:uml="http://www.eclipse.org/uml2/2.0.0/UML"
xmi:id="_2lOwILNDEduNmdZ-0W_wwA" name="modelA">
<packagedElement xmi:type="uml:Class"
xmi:id="_5ddhgLNDEduNmdZ-0W_wwA" name="Class1">
</packagedElement>
</uml:Model>
And another model "modelB" that all it does is to import "modelA" with a
private PackageImport:
xmi:id="_S7eQILNIEduJpMikpuhDAQ" name="
<packageImport xmi:id="_S7qdYbNIEduJpMikpuhDAQ" visibility="private">
<importedPackage xmi:type="uml:Model"
href="modelA.uml#_S7L8QLNIEduJpMikpuhDAQ"/>
</packageImport>
</uml:Model>
So that tells me that all elements imported from modelA into modelB are
private to modelB (section 7.3.39 - "If the PackageImport is public, the
imported elements will be visible outside the package, while if it is
private they will not.").
I am trying to honor the UML spec and prevent people from creating
models that import modelB to make references to Class1, but the problem
is that the visibility of modelB::Class1 (in other words, modelA::Class1
as imported into modelB) is public. Shouldn't it be private instead? Is
this a bug in UML2? Any workarounds?
Rafael
Re: private package imports [message #470061 is a reply to message #469902] Mon, 05 February 2007 15:23 Go to previous messageGo to next message
Hi Rafael,
The PackageOperations::getAllImportedPackages() does consider visibility
kind when returning the list of imported packages.
Also, the PackageOperations::visibleMembers() convenience method uses only
publicly available members.
Try using that PackageOperations::visible() query.
- James.
"Rafael Chaves" <chaves@inf.ufsc.nospam.br> wrote in message
news:eq17b5$uvm$1@utils.eclipse.org...
> </packagedElement>
> </uml:Model>
> </packageImport>
> </uml:Model>
> Rafael
Re: private package imports [message #470064 is a reply to message #470061] Mon, 05 February 2007 15:25 Go to previous messageGo to next message
.... I meant PackageOperations::visibleMembers() query...
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:eq83og$i8t$2@utils.eclipse.org...
> Hi Rafael,
> Regards,
> - James.
> > <?xml version="1.0" encoding="UTF-8"?>
> > </packagedElement>
> > </uml:Model>
> > </packageImport>
> > </uml:Model>
> > Thanks,
> > Rafael
Re: private package imports [message #470076 is a reply to message #470064] Mon, 05 February 2007 16:16 Go to previous message
Actually, PackageOperations::visibleMembers(Package) is not API (it's
internal) - use Package#visibleMembers() instead.
Kenn
news:eq83qs$ids$2@utils.eclipse.org...
>> Hi Rafael,
>> only
>> Regards,
>> - James.
>> > "Class1":
>> > </packagedElement>
>> > </uml:Model>
>> > a
>> > </packageImport>
>> > </uml:Model>
>> > the
>> > modelA::Class1
>> > Thanks,
>> > Rafael
Re: private package imports [message #582047 is a reply to message #469902] Mon, 05 February 2007 15:23 Go to previous message
Hi Rafael,
- James.
> </packagedElement>
> </uml:Model>
> </packageImport>
> </uml:Model>
> Rafael
Re: private package imports [message #582062 is a reply to message #470061] Mon, 05 February 2007 15:25 Go to previous message
> Hi Rafael,
> Regards,
> - James.
> > </packagedElement>
> > </uml:Model>
> > </packageImport>
> > </uml:Model>
> > Thanks,
> > Rafael
Re: private package imports [message #582167 is a reply to message #470064] Mon, 05 February 2007 16:16 Go to previous message
Kenn
>> Hi Rafael,
>> only
>> Regards,
>> - James.
>> > "Class1":
>> > </packagedElement>
>> > </uml:Model>
>> > a
>> > </packageImport>
>> > </uml:Model>
>> > the
>> > modelA::Class1
>> > Thanks,
>> > Rafael
Previous Topic:UML2 installation question
Next Topic:strange behavior when defining a profile
Current Time: Sun Jul 27 10:12:57 EDT 2025
Powered by FUDForum. Page generated in 0.03702 seconds
