Re: About the compatibility between Eclipse3.02 and ECF [message #607701 is a reply to message #582006] |
Fri, 10 November 2006 15:30  |
Hi Seariver,
We haven't been doing building and testing on Eclipse 3.0x for some
time, and so I wouldn't bet that it will work properly for all parts of ECF.
OTOH, for the refactoring effort just completed, I think the core
plugins are fairly likely to be able to run on 3.0x...but I would
suspect that the example apps would still be unlikely to run on 3.0X
(because of the changes in the Eclipse 3.1+ UI code).
So we can't make any guarantees RE: 3.0x as it depends upon which parts
of ECF you would want to use.
Scott
seariver wrote:
> Hi, all
> In the ECF documentation,
> It is required eclipse 3.1M7
> Can ECF runs on Eclipse3.0x?
> Thank you very much!
> Seariver
FUDForum. Page generated in 0.25546 seconds
