Problem with FirstJSFApp Tutorial [message #470896] |
Mon, 30 January 2006 11:55  |
Greetings,
I am trying to work through the JSF tutorial for WTP and am running into
some issues. I am unable to deploy and run my JSP on a server - when I
try to right click on the login.jsp and select 'Run on Server', I get the
following error:
No launchable artifact could be found in the selection.
It seems like some sort of project configuration issue, but I am unable to
determine the cause. I beleive that I have set up my environment as
described in the tutorial (except I am using a 1.5 jdk, instead of 1.4),
and am using the following environment:
Windows XP Pro
Eclipse 3.1.1
JDK 1.5.0_01
WTP 1.0
JSF Tools Milestone 1
Apache Tomcat 5.5
JSF RI 1.1_01
jakarta-taglibs-standard-1.1.2
I am able to launch JSPs in other dynamic web projects, so it seems to be
related to something JSF. I have tried deleting and re-adding the project
from the server, and even deleteing and re-adding the Tomcat server
itself, but with no success.
Any thoughts anyone? Thanks in advance...
Ted Fritsch
Re: Problem with FirstJSFApp Tutorial [message #470897 is a reply to message #470896] |
Mon, 30 January 2006 16:20   |
Hi Ted,
I suspect that you are having this problem because you have not placed the
login.jsp page someplace inside the WebContent folder.
Unfortunately this message is being thrown from the class
org.eclipse.wst.server.ui.internal.actions.RunOnServerAction Delegate and I
am unable to provide a more meaningful message. You may want to file a bug
against the wst.server component on this.
Gerry Kessler
WTP JSF Tools Team
"Ted Fritsch" <tedfritsch@yahoo.com> wrote in message
news:6c0c4e1b39c0fa5b3e30d635fef90b1b$1@www.eclipse.org...
> Greetings,
> following error:
> Windows XP Pro
> Eclipse 3.1.1
> JDK 1.5.0_01
> WTP 1.0
> JSF Tools Milestone 1 Apache Tomcat 5.5 JSF RI 1.1_01
> Ted Fritsch
Re: Problem with FirstJSFApp Tutorial [message #470899 is a reply to message #470898] |
Tue, 31 January 2006 23:40  |
On Tue, 31 Jan 2006 13:48:39 -0500, Ted Fritsch <tedfritsch@yahoo.com> wrote:
> Not sure if that warrants a bug report or not - but a more helpful error
> message would be nice. Maybe it makes sense to modify the JSP wizard to
> default it there as well? What do you guys think?
Well, I'm not on the JSF project per se, but ... sounds like a good bug report to me! :)
Re: Problem with FirstJSFApp Tutorial [message #581851 is a reply to message #470896] |
Hi Ted,
Gerry Kessler
WTP JSF Tools Team
> Greetings,
> following error:
> Windows XP Pro
> Eclipse 3.1.1
> JDK 1.5.0_01
> WTP 1.0
> Ted Fritsch
Re: Problem with FirstJSFApp Tutorial [message #581867 is a reply to message #470897] |
Tue, 31 January 2006 13:48  |
Yes - that was it. Thanks for pointing out my simple error - I just
assumed that the JSP wizard would put it into the WebContent folder. I
guess I'm used to developing with WSAD, where that is the default
behavior. In fact, I don't think that it will let you put them anywhere
else...
Thanks again for the prompt reply,
Ted
Re: Problem with FirstJSFApp Tutorial [message #581891 is a reply to message #470898] |
FUDForum. Page generated in 0.05276 seconds
