Home » Modeling » Epsilon » Null Pointer Exception when invoking .asOrderedSet in EOL query
Null Pointer Exception when invoking .asOrderedSet in EOL query [message #581643] Thu, 08 October 2009 08:07 Go to next message
Hello Dimitris,
The query in EOL File is:
operation InitialisationDataSet getTimeslotsNot TransmittableTo(other:InitialisationDataSet) : OrderedSet(TimeslotBlock) {
var myTxBs: OrderedSet(TimeslotBlock) := self.getTimeslotBlocks().select(b|b.isExplicitTransmit());
var allTransmittableBs: OrderedSet(TimeslotBlock) := self.getAllTimeslotsTransmittableTo(other);
myTxBs.println();
allTransmittableBs.println();
return myTxBs.reject(b|allTransmittableBs.includes(b));
The statement to execute query using EOL is:
timeslots := ids1.getTimeslotsNotTransmittableTo(ids2).asOrderedSet();
timeslots.println();
The above statement gives the required output. But when executed in Java it throws null pointer exception.
The code in Java is:
EolOperation getAllTimeslotsNotTransmittableTo = module.getOperations().getOperation("getAllTimeslotsNotTransmittableTo ");
List idsList = new ArrayList();
idsList.add(ids2);
EolOrderedSet timeSlots = (EolOrderedSet) getAllTimeslotNotTransmittableTo.execute(ids1, idsList, module.getContext());
The above line gives null pointer exception.
Sajit
Re: Null Pointer Exception when invoking .asOrderedSet in EOL query [message #581663 is a reply to message #581643] Thu, 08 October 2009 09:16 Go to previous message
Hi Sajit,
Could you please check if getAllTimeslotNotTransmittableTo is null? If
so this may be due to the extra space in
getOperation("getAllTimeslotsNotTransmittableTo "); <-
Dimitris
Sajit wrote:
> Hello Dimitris,
> myTxBs.println();
> idsList.add(ids2);
> Sajit
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Previous Topic:Explicit invocation of ETL rule
Next Topic:Explicit invocation of ETL rule
Current Time: Wed Jul 23 05:29:10 EDT 2025
Powered by FUDForum. Page generated in 0.08223 seconds
